- What's New
- Product Bulletin
- Billing
- Getting Started
User Guide
- Function Overview
- Kernel Version Notes
- Permissions Management
Instance Management
- Instance Statuses
- Buying a DDM instance
- Splitting Read-only and Read-Write Services
- Changing Node Class
- Scaling Out a DDM Instance
- Scaling In a DDM Instance
- Restarting a DDM Instance or an Instance Node
- Deleting Pay-per-Use Instances
- Reloading Table Data
- Changing a Parameter Template
- Modifying Parameters of a DDM Instance
- Rolling Back the Version of a DDM Instance
- Upgrading the Version of a DDM Instance
- Upgrading the DDM Engine and OS
- Connection Management
- Schema Management
- Shard Configuration
- Data Nodes
Parameter Template Management
- Instance Parameters
- Creating a Parameter Template
- Modifying a Custom Parameter Template
- Comparing Two Parameter Templates
- Viewing Parameter Change History
- Replicating a Parameter Template
- Applying a Parameter Template
- Viewing Application Records of a Parameter Template
- Modifying the Description of a Parameter Template
- Deleting a Parameter Template
- Account Management
- Backups and Restorations
Data Migration
- Overview
- Migration Evaluation
- Scenario 1: Migrating Data from an On-Premises MySQL Instance to DDM
- Scenario 2: Migrating Data from a Third-Party Cloud MySQL Instance to DDM
- Scenario 3: Migrating Data from an ECS-hosted MySQL Instance on Huawei Cloud to DDM
- Scenario 4: Exporting Data from a DDM Instance
- Scenario 5: Migrating Data from Heterogeneous Databases to DDM
- Scenario 6: Migrating Data from Huawei Cloud RDS for MySQL to DDM
- Session Management
- Slow Queries
- Monitoring and Alarm Reporting
- Task Center
- Tags
- Auditing
SQL Syntax
- Introduction
- DDL
- DML
- Online DDL
- Functions
- Unsupported Objects and Use Constraints
- Supported SQL Statements
- Global Sequence
- Database Management Syntax
- Advanced SQL Functions
- Quotas
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs (Recommended)
DDM Instances
- Querying DDM Instances
- Querying Details of a DDM Instance
- Modifying the Name of a DDM Instance
- Changing the Security Group of a DDM Instance
- Deleting a DDM Instance
- Scaling in a DDM instance
- Modifying the Read Policy of the Associated DB Instance
- Synchronizing Data Node Information
- Querying Nodes of a DDM Instance
- Querying Details of a DDM Instance Node
- Querying Parameters of a Specified DDM Instance
- Querying DDM Engine Information
- Querying DDM Node Classes Available in an AZ
- Changing the Node Class of a DDM Instance
- Obtaining the Instance Group Information
- Creating an Instance Group
- Schemas
- Accounts
- Monitoring
- Application Examples
DDM Instances
- Appendix
- SDK Reference
Best Practices
- Overview
- Formulating Sharding Rules
- Determining the Number of Shards in a Schema
- Using Broadcast and Unsharded Tables
- Transaction Models
- SQL Standards
- Migrating an Entire RDS Database to DDM
- Migrating an Entire MyCat Database to DDM
- Accessing DDM Using a JDBC Connection Pool
- Logging In to a DDM Instance Using Navicat
- Migrating Data from RDS for MySQL to DDM Using DRS
- Sharding Database and Table Data of an RDS for MySQL Instance
- Performance White Paper
- General Questions
DDM Usage
- How Does DDM Perform Sharding?
- What Do I Do If I Fail to Connect to a DDM Instance Using the JDBC Driver?
- Why It Takes So Long Time to Export Data from MySQL Using mysqldump?
- What Do I Do If a Duplicate Primary Key Error Occurs When Data Is Imported into DDM?
- What Should I Do If an Error Message Is Returned When I Specify an Auto-Increment Primary Key During Migration?
- What Do I Do If an Error Is Reported When Parameter Configuration Does Not Time Out?
- Which Should I Delete First, a Schema or its Associated RDS Instances?
- Can I Manually Delete Databases and Accounts Remained in Data Nodes After a Schema Is Deleted?
- SQL Syntax
RDS-related Questions
- Is the Name of a Database Table Case-Sensitive?
- What Risky Operations on RDS for MySQL Will Affect DDM?
- How Do I Handle Data with Duplicate Primary Keys in a Table?
- How Can I Query RDS for MySQL Information by Running Command show full innodb status?
- What Should I Pay Attention to When Selecting RDS for MySQL Instance Specifications?
- Resource Freezing, Release, Deletion, and Unsubscription
- Videos
More Documents
- Getting Started
- Function Overview
- Instance Management
- Editing a Parameter Template
- Task Center
- Schema Management
- Backup Management
- Monitoring Management
- Auditing
SQL Syntax
- Introduction
- DDL
- DML
- Functions
- Unsupported Items
- Global Sequence
- General Questions
DDM Usage
- How Can I Rectify a Fault in Accessing DDM by Using the JDBC Driver?
- What Version and Parameters Should I Select?
- How Should I Handle the Duplicate Primary Key Error Occurring After Data Is Imported into DDM?
- What Should I Do If an Error Message Is Returned After I Specify an Auto-Increment Primary Key?
- How Do I Handle the Error Reported When Parameter Configuration Does Not Time Out?
- Which Should I Delete First, Schema or Associated RDS DB Instances?
- Should I Manually Delete Databases and Accounts Remained in the Associated RDS DB Instances After a Schema Is Deleted?
- SQL Syntax
- RDS-related Questions
- Getting Started
- Function Overview
- Task Center
- Schema Management
- Backup Management
- Auditing
SQL Syntax
- Introduction
- DDL
- DML
- Functions
- Unsupported Items
- Global Sequence
- General Questions
DDM Usage
- SQL Syntax
- Before You Start
- API Overview
- Calling APIs
DDM Instance Management
- Querying the Quota of Classes Available in Each AZ
- Creating a DDM Instance
- Viewing Details of a DDM Instance
- Modifying the Security Group of a DDM Instance
- Scaling Out a DDM instance
- Scaling In a DDM instance
- Synchronizing DB Instance Data
- Schema Management
- Appendix
- Change History
Functions
Supported Functions
Expression |
Example |
IN |
SELECT * FROM Products WHERE vendor_id IN ( 'V000001', 'V000010' ) ORDER BY product_price |
NOT IN |
SELECT product_id, product_name FROM Products WHERE NOT vendor_id IN ('V000001', 'V000002') ORDER BY product_id |
BETWEEN |
SELECT id, product_id, product_name, product_price FROM Products WHERE id BETWEEN 000005 AND 000034 ORDER BY id |
NOT...BETWEEN |
SELECT product_id, product_name FROM Products WHERE NOT vendor_id BETWEEN 'V000002' and 'V000005' ORDER BY product_id |
IS NULL |
SELECT product_name FROM Products WHERE product_price IS NULL |
IS NOT NULL |
SELECT id, product_name FROM Products WHERE product_price IS NOT NULL ORDER BY id |
AND |
SELECT * FROM Products WHERE vendor_id = 'V000001' AND product_price <= 4000 ORDER BY product_price |
OR |
SELECT * FROM Products WHERE vendor_id = 'V000001' OR vendor_id = 'V000009' |
NOT |
SELECT product_id, product_name FROM Products WHERE NOT vendor_id = 'V000002' |
LIKE |
SELECT * FROM Products WHERE product_name LIKE 'NAME%' ORDER BY product_name |
NOT LIKE |
SELECT * FROM Products WHERE product_name NOT LIKE 'NAME%' ORDER BY product_name |
CONCAT |
SELECT product_id, product_name, Concat( product_id , '(', product_name ,')' ) AS product_test FROM Products ORDER BY product_id |
SELECT 3 * 2+5-100/50 |
SELECT order_num, product_id, quantity, item_price, quantity*item_price AS expanded_price FROM OrderItems WHERE order_num BETWEEN 000009 AND 000028 ORDER BY order_num |
UPPER |
SELECT id, product_id, UPPER(product_name) FROM Products WHERE id > 10 ORDER BY product_id |
LOWER |
SELECT id, product_id, LOWER(product_name) FROM Products WHERE id <= 10 ORDER BY product_id |
SOUNDEX |
SELECT * FROM Vendors WHERE SOUNDEX(vendor_name) = SOUNDEX('Huawee') ORDER BY vendor_name |
IFNULL |
SELECT IFNULL(product_id, 0) FROM Products;
Function Expression |
Example |
DAY() |
SELECT * FROM TAB_DT WHERE DAY(dt)=21 SELECT * FROM TAB_DT WHERE dt='2018-12-21' INSERT INTO TAB_DT(id,dt) VALUES(1,'2018-05-22') |
MONTH() |
SELECT * FROM TAB_DT WHERE MONTH(dt)=12 SELECT * FROM TAB_DT WHERE dt='2018-12-21' INSERT INTO TAB_DT(id,dt) VALUES(1,'2018-05-22') |
YEAR() |
SELECT * FROM TAB_DT WHERE YEAR(dt)=2018 SELECT * FROM TAB_DT WHERE dt='2018-12-21' INSERT INTO TAB_DT(id,dt) VALUES(1,'2018-05-22') |
DAYOFYEAR() |
SELECT * FROM TAB_DT WHERE DAYOFYEAR(dt)=365 SELECT * FROM TAB_DT WHERE dt='2018-12-31' INSERT INTO TAB_DT(id,dt) VALUES(1,'2018-05-22') |
DAYOFWEEK() |
SELECT * FROM TAB_DT WHERE DAYOFWEEK(dt)=6 SELECT * FROM TAB_DT WHERE dt='2018-12-21' INSERT INTO TAB_DT(id,dt) VALUES(1,'2018-05-22') |
WEEKOFYEAR() |
SELECT * FROM TAB_DT WHERE WEEKOFYEAR(dt)=51 SELECT * FROM TAB_DT WHERE dt='2018-12-21' INSERT INTO TAB_DT(id,dt) VALUES(1,'2018-05-22') |
Expression |
Example |
SQRT() |
SELECT id, product_price, SQRT(product_price) AS price_sqrt FROM Products WHERE product_price < 4000 ORDER BY product_price |
AVG() |
SELECT AVG(product_price) AS avg_product FROM Products |
COUNT() |
SELECT COUNT(*) AS num_product FROM Products |
MAX() |
SELECT id, product_id, product_name, MAX(product_price) AS max_price FROM Products ORDER BY id |
MIN() |
SELECT id, product_id, product_name, MIN(product_price) AS min_price FROM Products ORDER BY id |
SUM() |
SELECT SUM(product_price) AS sum_product FROM Products |
Unsupported Functions
Item |
Restriction |
Functions |
Function row_count() is not supported. |
