Reloading Table Data
You have logged in to the DDM console.
Data has been migrated to a new DDM instance using DRS.
If you want to deploy a DDM instance across regions for DR, use DRS to migrate service data and then reload table data after the migration is complete so that DDM can detect where logical table information is located.
- In the instance list, locate the DDM instance whose table data you want to reload.
- Choose More > Reload Table Data in the Operation column.
    A message is displayed, indicating that table data of instance XXX has been reloaded.Figure 1 Example message
