Viewing Metrics
The DDM console supports monitoring and management of DDM instances, including the read/write ratio and slow SQL logs. You can optimize databases based on the monitoring results.
- Slow SQL refers to SQL statements that take a long time to run on your database. Statistical analysis of SQL helps you locate performance bottlenecks of your database.
- The read/write ratio is the proportion of read requests to read and write requests on a logical table.
- You have logged in to the DDM console.
- There is a DDM instance available, which has available schemas.
- In the instance list, locate the DDM instance whose metrics you want to view and click its name.
- In the navigation pane, choose Monitoring Management.
- Select Slow SQL Log and Read/Write Ratio tabs to view monitoring details as follows:
- Slow SQL logs
Specify a time range to filter logs. After you locate the required log, view the account, schema, SQL statement, execution start time, execution duration, shard, and affected lines.
Figure 1 Slow SQL log information
Table 1 Parameter description Parameter
Account
DDM account used for executing SQL statements
Schema
Name of the schema
SQL Statement
SQL statements that take a long time to run on a DDM instance
Executed
Time when the first slow SQL statement is executed within the specified period of time
Execution Time (ms)
Unit of milliseconds
Shard
All shards involved in the SQL execution
Affected Lines
Lines involved in SQL execution
- Read/Write ratio
Specify a time range to filter read/write ratio information. Obtain the reads, writes, and the last execution time.
Figure 2 Read/Write ratio information
Table 2 Parameter description Parameter
Reads
Number of read operations on a logical table. You can specify a period of time for querying and collecting reads.
Writes
Number of write operations on a logical table. You can specify a period of time for querying and collecting reads.
Executed
Time when the last SQL statement is executed within the specified period of time
- Slow SQL logs
- Click View Metric in the upper right corner. Figure 3 View Metric
- On the Cloud Eye console, view monitoring metrics of the DDM instance.
- In the navigation pane, choose Cloud Service Monitoring > Distributed Database Middleware.
- In the instance list, locate the target DDM instance, click
to view instance details, and click View Metric in the Operation column. - On the displayed page, select the required monitoring period to view metric information.
