Help Center/
      Distributed Database Middleware/
        User Guide (ME-Abu Dhabi Region)/
        SQL Syntax/
      Database Management Syntax
Supported Database Management Syntax
- SHOW Syntax
- SHOW COLUMNS Syntax
- SHOW CREATE TABLE Syntax
- SHOW TABLE STATUS Syntax
- SHOW TABLES Syntax
- SHOW DATABASES
- SHOW INDEX FROM
- SHOW VARIABLES Syntax
Supported Database Tool Commands
Unsupported Database Management Syntax
| Item | Restriction |
| Database administration statements |
 The following SHOW statements are randomly sent to a physical shard. If physical shards are on different RDS MySQL DB instances, the returned variables or table information may be different.
   Parent topic: SQL Syntax
