Global Sequence
Updated on 2022-12-08 GMT+08:00
Global sequences are mainly database-based global sequences.
  • The start auto-increment SN can be modified.
  • Global sequence provides sequence numbers that are globally unique but may not increase continuously.
Table 1 Tables supported by global sequence
Table Type
Sharded Table
Broadcast Table
Unsharded Table
DB-based
Supported
Supported
Not supported
Creating an Auto-Increment Sequence
  1. Connect to the target DDM instance using a client.
  2. Open the target schema.
  3. Run the following command to create an auto-increment sequence:
    create sequence xxxxx ;
    • xxxxx indicates the sequence name.
Deleting an Auto-Increment Sequence
  3. Run show sequences to view all global sequences.
  4. Run the following command to delete an auto-increment sequence:
    drop sequence xxxxx ;
    drop sequence DB.xxx;
    • The sequence name is case-insensitive.
    • If an auto-increment sequence is inherent to a table, the sequence cannot be deleted.
Modifying the Start Value of an Auto-Increment Global Sequence
  4. Run the command to change the start value:
    alter sequence xxxxx START WITH yyyyy;
    • yyyyy indicates the start value of the target sequence.
Querying an Auto-Increment Sequence
  3. Run the following command to view all global sequences:
    show sequences;
Modifying the Auto-Increment Cache Value
NOTICE:
Only kernel 3.0.3 and later versions are supported.
  3. Run command alter sequence test cache 5000 to modify the global sequence cache value of table test.
  4. Run command show sequences to view the cache value (INCREMENT value) of table test.
