Step 6: Log In to the DDM Instance or Schema
Updated on 2022-12-08 GMT+08:00
After you create a DDM instance, you can log in to it using a client such as Navicat, or connect to the required schema in the instance using the CLI or JDBC driver.
This section describes how to log in to a DDM instance or a schema.
Preparations
Before login to your DDM instance or schema, you have to obtain the connection address of your DDM instance or schema.
Obtaining the Instance Connection Address
  2. Hover on the left menu to display Service List and choose Database > Distributed Database Middleware.
  3. In the navigation pane, choose Instances. In the instance list, locate the required instance and click its name.
  4. In the Network Information area, view the connection address.
    If you enter an incorrect password for five times or more when attempting to access your DDM instance, the system will be locked for 20 minutes.
Obtaining the Schema Connection Address
  3. In the navigation pane, choose Instances. In the instance list, locate the required DDM instance and click its name.
  4. In the navigation pane, choose Schemas.
  5. In the schema list, locate the required schema and click its name.
  6. At the Connection Address area, view the CLI and JDBC connection addresses.
    Figure 1 Schema connection address
Connection Methods
For details about method 1, see Using Navicat to Log In to a DDM Instance.
For details about method 2, see Using the MySQL CLI to Log In to a Schema.
For details about method 3, see Using a JDBC Driver to Log In to a Schema.
For details about method 4, see Log In to a DDM Instance on the DDM Console.
  1. For security purposes, use an ECS in the same VPC as your DDM instance.
  2. Ensure that a MySQL client has been installed on the required ECS or the MySQL connection driver has been configured.
  3. Before you log in to a DDM instance, configure its information on the client or connection driver.
  1. Log in to the DDM console, locate the required DDM instance, and click its name.
  2. In the Instance Information area, click Bind and select an EIP available.
  3. In the left pane, click the VPC icon and choose Access Control > Security Groups.
  4. On the Security Groups page, locate the required security group and click Manage Rule in the Operation column. On the displayed page, click Add Rule. Configure the security group rule as needed and click OK.
    After binding an EIP to your DDM instance, set strict inbound and outbound rules for the security group to enhance database security.
  5. Open Navicat and click Connection. In the displayed dialog box, enter the host IP address (EIP), username, and password (DDM account).
  6. Click Test Connection. If a message is returned indicating that the connection is successful, click OK. The connection will succeed 1 to 2 minutes later. If the connection fails, the failure cause is displayed. Modify the required information and try again.
Using Navicat to access a DDM instance is similar to using other visualized MySQL tools such as MySQL Workbench. Therefore, the procedure of using other visualized MySQL tools to connect to a DDM instance has been omitted.
  1. Log in to the required ECS, open the CLI, and run the following command:
    mysql -h ${DDM_SERVER_ADDRESS} -P${DDM_SERVER_PORT} -u${DDM_USER} -p [-D${DDM_DBNAME}] [--default-character-set=utf8][--default_auth=mysql_native_password]
    Table 1 Parameter description
    Example Parameter
    Example Value
    DDM_SERVER_ADDRESS
    IP address of the DDM instance
    192.168.0.200
    DDM_SERVER_PORT
    Connection port of the DDM instance
    5066
    DDM_USER
    Account of the DDM instance
    dbuser01
    DDM_DBNAME
    (Optional) Name of the target schema in the DDM instance
    (Optional) Select character set UTF-8 for encoding.
    Configure this parameter if garbled characters are displayed during parsing due to inconsistency between MySQL connection code and actually used code.
    The password authentication plug-in is used by default.
    If you use the MySQL 8.0 client, set default_auth to mysql_native_password.
  2. View the command output. The following is an example output of running a MySQL command in the Windows CLI.
    C:\Users\testDDM>mysql -h192.168.0.200 -P5066 -Ddb_5133 -udbuser01 -p
    Enter password:
    Reading table information for completion of table and column names
    You can turn off this feature to get a quicker startup with -A
    Welcome to the MySQL monitor.  Commands end with ;or \g.
    Your MySQL connection id is 5
    Server version: 5.6.29
    Copyright (c) 2000, 2016, Oracle and/or its affiliates. All rights reserved.
    Oracle is a registered trademark of Oracle Corporation and/or its
    affiliates. Other names may be trademarks of their respective
    owners.
    Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
    mysql>
  1. Load the required JDBC driver.
    Class.forname(com.mysql.jdbc.Driver);
    JDBC drivers 5.1.35 to 5.1.45 are recommended.
  2. Create a database connection.
    String username = "dbuser01" ;
    String password = "xxxxxx" ;
    String url = "jdbc:mysql://192.168.0.200:5066/db_5133";
    Connection con = DriverManager.getConnection(url , username , password);
  3. Create a Statement object.
    Statement stmt = con.createStatement();
  4. Execute the required SQL statement.
    ResultSet rs = stmt.executeQuery("select now() as Systemtime");
    con.close();
  5. (Optional) Optimize code as needed.
    loadBalanceAutoCommitStatementThreshold=5&loadBalanceHostRemovalGracePeriod=15000&loadBalanceBlacklistTimeout=60000&loadBalancePingTimeout=5000&retriesAllDown=10&connectTimeout=10000";
    • Parameters loadBalanceAutoCommitStatementThreshold and retriesAllDown must be configured based on the example in 5. Otherwise, an infinite loop may occur during the connection switchover, resulting in stack overflow.
    • loadBalanceAutoCommitStatementThreshold: defines the number of matching statements which will trigger the driver to potentially swap physical server connections.
    • loadBalanceHostRemovalGracePeriod: indicates the grace period to wait for a host being removed from a load-balanced connection, to be released when it is the active host.
    • loadBalanceBlacklistTimeout: indicates the time in milliseconds between checks of servers which are unavailable, by controlling how long a server lives in the global blacklist.
    • loadBalancePingTimeout: indicates the time in milliseconds that the connection will wait for a response to a ping operation when you set loadBalanceValidateConnectionOnSwapServer to true.
    • retriesAllDown: indicates the maximum number of connection attempts before an exception is thrown when a valid host is searched. SQLException will be returned if the threshold of retries is reached with no valid connections obtained.
    • connectTimeout: indicates the maximum amount of time in milliseconds that the JDBC driver is willing to wait to set up a socket connection. 0 indicates that the connection does not time out. Only JDK-1.4 or later is supported. The default value 0.
  1. Log in to the DDM console.
  2. In the navigation pane, choose Instances.
  3. In the instance list, locate the required instance and click Log In in the Operation column.
    On the displayed page, enter the required username and password.
  4. On the displayed page, enter username and password of the DDM account.
  5. Click Test Connection.
  6. (Optional) Enable Collect Metadata Periodically and Show Executed SQL Statements.
  7. Ensure that all settings are correct and click Log In.
