Help Center/
      Distributed Database Middleware/
        User Guide (ME-Abu Dhabi Region)/
        Getting Started/
      Overview
        Updated on 2022-12-08 GMT+08:00
Overview
This section uses an RDS DB instance as an example to describe how to use DDM.
Process of Using DDM
Step 1: Log In to the DDM Console
Step 3: Create an RDS DB Instance
   Step 6: Log In to the DDM Instance or Schema
    Figure 1 Flowchart for using DDM
   Parent topic: Getting Started
