Functions
| Function | Description |
| Horizontal sharding | Select a sharding key when creating a distributed database. DDM will generate a sharding rule and horizontally shard data. |
| Scaling | DDM supports both compute and storage scaling. You can scale up or out a DDM instance dynamically with zero downtime. Compute scaling is undetectable to your applications, and storage scaling minimizes service interruption to seconds. Storage scaling can be actualized with two methods: rebalancing or resharding.
| Distributed transactions | DDM processes three types of transactions, including single-shard, FREE, and Extended Architecture (XA).
| Data import and export | External data can be imported into DDM to help you migrate databases to the cloud, and DDM instance data can be exported based on requirements. |
| SQL syntax | DDM is highly compatible with the MySQL licenses and syntaxes. |
| Read and write splitting | Read and write requests can be split without modifying the application code, and this is totally transparent to applications. You only need to create read replicas for a MySQL DB instance associated with your DDM instance and configure a read policy, so a large number of concurrent requests can read data from those read replicas. |
| Global sequence | DDM allows you to use globally unique, distributed, and ascending SNs as primary or unique keys or to meet your requirements in specific scenarios. |
| DDM console | The DDM console enables you to manage and maintain DDM instances and schemas. |
Related Services
- VPC
    DDM instances are deployed in an isolated VPC and you can configure IP addresses and bandwidth for accessing these DDM instances and use a security group to control access to them.
- ECS
    You can access your DDM instance through an ECS.
- Relational Database Service (RDS)
    After creating a DDM instance, you can associate it with RDS for MySQL DB instances in the same VPC to obtain separated storage resources.
- Cloud Trace Service (CTS)
    CTS records operations on DDM resources for query, audit, and backtrack.
- Elastic Load Balance (ELB)
    Elastic Load Balance (ELB) is a traffic distribution control service. It distributes incoming traffic to multiple backend servers based on the forwarding policy to balance workloads. So, it can expand external service capabilities of DDM and eliminate single points of failure (SPOFs) to improve service availability.
