Help Center/
      Distributed Database Middleware/
        User Guide (ME-Abu Dhabi Region)/
        SQL Syntax/
        DML/
      REPLACE
REPLACE
REPLACE is used to insert rows into or replace rows in a table.
Common Syntax
replace into table(col1,col2,col3) values(value1,value2,value3)
Syntax Restrictions
- PARTITION syntax is not supported.
- If an auto-increment table has no ID, you can insert a data record with a specified ID using REPLACE, but no ID is generated.
   Parent topic: DML
