- What's New
- Getting Started
- User Guide
- What Is DCC?
- How Is a DCC Billed?
- What Steps Will Be Taken by Huawei Cloud to Handle a Server Fault in a DCC?
- How Do I Select a Region?
- How Is the Memory Allocation Rate in a DCC Computing Resource Pool Calculated?
- FAQs About ECSs
- What Are the Characteristics of ECSs in a DeC?
- How Is an ECS in a DeC Billed?
- API Reference
- Glossary
- More Documents
Show all
FAQs About ECSs
- How Do I Determine the Number of ECSs Required?
You can summarize the computing resources (such as CPU and memory) occupied by your application software and estimate the number of required ECSs based on the computing resources provided by each ECS.
- Can I Exclusively Use the Resources of ECSs?
Yes.
The computing resources provided on public cloud are exclusive for your own use. And the resource will not be shared with other users.
- Can ECSs in a Shared Resource Pool Be Added to a DeC Cluster?
- Can I Use the Hard Disks on Physical Servers as My Storage Resources?
No. You can only use the compute resources provided by physical servers. Specifically, the hard disks on the servers cannot be used as your storage resources.
