- What's New
- Getting Started
- User Guide
- What Is DCC?
- How Is a DCC Billed?
- What Steps Will Be Taken by Huawei Cloud to Handle a Server Fault in a DCC?
- How Do I Select a Region?
- How Is the Memory Allocation Rate in a DCC Computing Resource Pool Calculated?
- FAQs About ECSs
- What Are the Characteristics of ECSs in a DeC?
- How Is an ECS in a DeC Billed?
- API Reference
- Glossary
- More Documents
On this page
Show all
Help Center/
Dedicated Computing Cluster/
User Guide (ME-Abu Dhabi Region)/
Provisioning and Usage/
Releasing DeC Resources
If you do not need DeC resources any more, you can submit a request for releasing DeC resources. Contact customer support and submit the following information:
- Username
- Name of the DeC to be released
Parent topic: Provisioning and Usage
