- What's New
- Getting Started
- User Guide
- What Is DCC?
- How Is a DCC Billed?
- What Steps Will Be Taken by Huawei Cloud to Handle a Server Fault in a DCC?
- How Do I Select a Region?
- How Is the Memory Allocation Rate in a DCC Computing Resource Pool Calculated?
- FAQs About ECSs
- What Are the Characteristics of ECSs in a DeC?
- How Is an ECS in a DeC Billed?
- API Reference
- Glossary
- More Documents
On this page
Help Center/
Dedicated Computing Cluster/
User Guide (ME-Abu Dhabi Region)/
Provisioning and Usage/
Querying the DeC Information
You can view DeCs you have enabled in your region. You can also view information about basic service resources, such as ECSs, in a specific DeC.
Querying DeCs in all Regions
- Click the region name in the upper left corner to view the DeCs you have enabled in all regions.
Querying DeCs in a Specified Region
- Click the region name in the upper left corner and select the required region.
- Click Service List, and choose Compute > Dedicated Cloud. The DeC page is displayed.
Querying Information About a Specified DeC
- Switch to the DeC page by following the instructions provided in Querying DeCs in a Specified Region.
- Click the name of your desired DeC to view the monitoring information about devices and the resources in the DeC, such as ECSs.
- In the My Resources area, click a resource name to view details about the resource in the DeC.
Parent topic: Provisioning and Usage
