- What's New
- Getting Started
- User Guide
- What Is DCC?
- How Is a DCC Billed?
- What Steps Will Be Taken by Huawei Cloud to Handle a Server Fault in a DCC?
- How Do I Select a Region?
- How Is the Memory Allocation Rate in a DCC Computing Resource Pool Calculated?
- FAQs About ECSs
- What Are the Characteristics of ECSs in a DeC?
- How Is an ECS in a DeC Billed?
- API Reference
- Glossary
- More Documents
Help Center/
Dedicated Computing Cluster/
User Guide (ME-Abu Dhabi Region)/
Provisioning and Usage/
Enabling a DeC
Enabling a DeC
The DeC service is provisioned offline.
- To request DeC, contact customer support.
- Verify that DeC is available. If you have any question, contact customer service or refer to the Dedicated Cloud User Guide.
Parent topic: Provisioning and Usage
