- What's New
- Function Overview
- Product Bulletin
- Billing
- Getting Started
- User Guide
Best Practices
- Direct Connect Best Practices
- Connecting an On-Premises Data Center to a VPC over a Single Connection and Using Static Routing to Route Traffic
- Connecting an On-Premises Data Center to a VPC over a Single Connection and Using BGP Routing to Route Traffic
- Connecting an On-Premises Data Center to a VPC over Two Connections in Load Balancing Mode (Virtual Gateway)
- Connecting an On-Premises Data Center to a VPC over Two Connections in an Active/Standby Pair (Virtual Gateway)
- Connecting an On-Premises Data Center to Multiple VPCs that Do Not Need to Communicate with Each Other
- Connecting an On-Premises Data Center to Multiple VPCs in the Same Region Using Direct Connect and VPC Peering
- Using a Public NAT Gateway and Direct Connect to Accelerate Internet Access
- Allowing On-Premises Servers to Access Cloud Services Using Direct Connect and VPC Endpoint
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Connections
- Virtual Gateways
Virtual Interfaces
- Creating a Virtual Interface
- Querying the Virtual Interface List
- Querying Details About a Virtual Interface
- Updating a Virtual Interface
- Deleting a Virtual Interface
- Creating a Virtual Interface Peer
- Updating a Virtual Interface Peer
- Deleting a Virtual Interface Peer
- Performing a Virtual Interface Switchover Test
- Querying the List of Virtual Interface Switchover Test Records
- Tag Management
- Quota Management
- Global DC Gateways
- Peer Links
- Connect Gateways
- Global EIPs
- Global DC Gateway Route Tables
- Public Parameters
- Appendix
- SDK Reference
- Troubleshooting
Popular Questions
- What Are the Network Requirements for Connections?
- What Locations Are Available for Direct Connect?
- How Do I Select a Carrier When Purchasing a Connection?
- How Will I Be Billed for Direct Connect?
- How Do I Submit a Service Ticket?
- How Do I Test the Network Connectivity Between a Location and the Cloud?
- What Do I Do If I Select the Wrong Carrier When Creating a Connection?
Product Consultation
- What Are 1GE and 10GE?
- Is BGP Routing Supported in Direct Connect?
- What Is Full-Service Installation Statement?
- What Are the Network Latency and Packet Loss Rate of a Connection?
- Are the Uplink and Downlink Bandwidths of a Direct Connect Connection the Same?
- How Do I Plan the VPCs for a New Connection?
- What Are Local and Remote Gateways (Interconnection IP Addresses)?
- How Do I Configure BFD for a Connection?
- Leased Line
Interconnection with the Cloud
- Can I Access the Same VPC over Multiple Connections?
- How Do I Plan the CIDR Blocks for a Connection?
- What Should I Consider When I Use Direct Connect to Access the Cloud?
- Does Direct Connect Support NAT?
- Can the VLAN of the On-premises Network Be Used in the VPC Through Direct Connect?
- Can My On-Premises Data Center Access Multiple VPCs Through One Connection?
- Can Direct Connect Be Used with Similar Services of Other Cloud Service Providers?
Networking and Scenarios
- Can Multiple Connections Access the Same VPC?
- Can I Limit the Bandwidth Available on Each Hosted Connection?
Related Console Operations
- How Can I Unsubscribe from Direct Connect?
- What Parameters Can Be Modified After I Have Created a Virtual Interface?
- Do I Need to Delete the Virtual Gateway and Virtual Interface Before Deleting a Hosted Connection?
- How Do I Change the Routing Mode of a Connection?
- How Do I Delete a Hosted Connection?
- What Is the BGP ASN Used by Huawei Cloud?
- Troubleshooting
- Billing
- Resource Monitoring
- Quota
Popular Questions
More Documents
- User Guide (ME-Abu Dhabi Region)
- User Guide (Paris Region)
- eu-west-0-api
- User Guide (Kuala Lumpur Region)
- Before You Start
- API Overview
- Calling APIs
- API Usage
API
- Connection
- Virtual Gateway
Virtual Interface
- Querying the Switchover Test Records of a Virtual Interface
- Tag management
- Quota Management
- Public Parameters
- Appendixes
- Change History
Help Center/
Direct Connect/
User Guide (ME-Abu Dhabi Region)/
Management/
Managing Virtual Interfaces/
Modifying a Virtual Interface
Modify the name, remote subnet, description, of a virtual interface.
- In the service list, choose Network > Direct Connect.
- In the navigation pane on the left, choose Direct Connect > Virtual Interfaces.
- Locate the virtual interface you want to modify and click Modify in the Operation column.
- Modify the virtual interface and click OK.
Parent topic: Managing Virtual Interfaces
