Updated on 2025-10-13 GMT+08:00
Creating a Tracker
If you log in to CTS for the first time, click Enable CTS on the Tracker List page. A management tracker named system will be automatically created. The management tracker identifies and associates with all cloud services your tenant account is using, and records all operations of your tenant account.
  • CTS records operations performed in the last 90 days. To store traces for a longer period, configure a tracker to transfer them to OBS or LTS. The tracker will then continuously transfer traces to your specified OBS bucket or LTS log stream for storage.
  • CTS can have only one management tracker. The stored historical traces are retained even after the management tracker is deleted. When you enable CTS again, the management tracker is restored.
