- What's New
- Function Overview
- Getting Started
- User Guide
- Best Practices
- API Reference
- SDK Reference
- Must I Use an IAM User (Sub Account) to Configure Transfer on CTS and Perform Operations on an OBS Bucket?
- What Information Is on the Trace List?
- How Will CTS Be Affected If My Account Balance Is Insufficient?
- What Are the Recommended Users of CTS?
- What Will Happen If I Have Enabled Trace Transfer But Have Not Configured an Appropriate Policy for an OBS Bucket?
- Does CTS Support Integrity Verification of Trace Files?
- Why Are There Some Null Fields on the View Trace Page?
- Why Is an Operation Recorded Twice in the Trace List?
- What Services Are Supported by Key Event Notifications?
- How Can I Store Trace Files for a Long Time?
- Why Are user and source_ip Null for Some Traces with trace_type as SystemAction?
- How Do I Find Out Who Created a Specific ECS?
- How Do I Find Out the Login IP Address of an IAM User?
- Why Are Two deleteMetadata Traces Generated When I Buy an ECS in Pay-per-Use or Yearly/Monthly?
- What If I Cannot Query Traces?
- Can I Disable CTS?
- How Do I Make the Log Retention Period 180 Days?
- What Can I Do If a Tracker Cannot Be Created on the CTS Console?
- What Should I Do If I Cannot Enable CTS as an IAM User?
- How Do I Enable Alarm Notifications for EVS?
- Can I Receive Duplicate Traces?
- What Should I Do If I Fail to Transfer Data to an OBS Bucket Authorized by a Key of Another Tenant?
- Does the cts_admin_trust Agency Include OBS Authorization?
- Does CTS Record ECS Creation Failures?
- Glossary
More Documents
- Getting Started
- Querying Traces
- Management Trackers
- Data Trackers
- Application Examples
- Trace References
- Cross-Tenant Transfer Authorization
- Verifying Trace File Integrity
- Auditing
- Permissions Management
- Supported Services and Operations
- Why Are Two deleteMetadata Traces Generated When I Buy an ECS?
- API Reference (ME-Abu Dhabi Region)
User Guide (Paris)
- Getting Started
- Querying Traces
- Trace References
- Auditing
- API Reference (Paris)
- Getting Started
- Querying Traces
- Trackers
- Organization Trackers
- Trace References
- Auditing
- API Reference (Kuala Lumpur Region)
- Videos
Show all
Management Trackers
CTS provides two types of trackers: a management tracker and multiple data trackers. The management tracker records management traces, which are operations on all cloud resources, such as creation, login, and deletion. Data trackers record data traces, which are operations performed by tenants on data in OBS buckets, such as upload and download.
This section describes how to use the management tracker.
