- What's New
- Function Overview
- Getting Started
- User Guide
- Best Practices
- API Reference
- SDK Reference
- Must I Use an IAM User (Sub Account) to Configure Transfer on CTS and Perform Operations on an OBS Bucket?
- What Information Is on the Trace List?
- How Will CTS Be Affected If My Account Balance Is Insufficient?
- What Are the Recommended Users of CTS?
- What Will Happen If I Have Enabled Trace Transfer But Have Not Configured an Appropriate Policy for an OBS Bucket?
- Does CTS Support Integrity Verification of Trace Files?
- Why Are There Some Null Fields on the View Trace Page?
- Why Is an Operation Recorded Twice in the Trace List?
- What Services Are Supported by Key Event Notifications?
- How Can I Store Trace Files for a Long Time?
- Why Are user and source_ip Null for Some Traces with trace_type as SystemAction?
- How Do I Find Out Who Created a Specific ECS?
- How Do I Find Out the Login IP Address of an IAM User?
- Why Are Two deleteMetadata Traces Generated When I Buy an ECS in Pay-per-Use or Yearly/Monthly?
- What If I Cannot Query Traces?
- Can I Disable CTS?
- How Do I Make the Log Retention Period 180 Days?
- What Can I Do If a Tracker Cannot Be Created on the CTS Console?
- What Should I Do If I Cannot Enable CTS as an IAM User?
- How Do I Enable Alarm Notifications for EVS?
- Can I Receive Duplicate Traces?
- What Should I Do If I Fail to Transfer Data to an OBS Bucket Authorized by a Key of Another Tenant?
- Does the cts_admin_trust Agency Include OBS Authorization?
- Does CTS Record ECS Creation Failures?
- Glossary
More Documents
- Getting Started
- Querying Traces
- Management Trackers
- Data Trackers
- Application Examples
- Trace References
- Cross-Tenant Transfer Authorization
- Verifying Trace File Integrity
- Auditing
- Permissions Management
- Supported Services and Operations
- Why Are Two deleteMetadata Traces Generated When I Buy an ECS?
- API Reference (ME-Abu Dhabi Region)
User Guide (Paris)
- Getting Started
- Querying Traces
- Trace References
- Auditing
- API Reference (Paris)
- Getting Started
- Querying Traces
- Trackers
- Organization Trackers
- Trace References
- Auditing
- API Reference (Kuala Lumpur Region)
- Videos
On this page
Show all
Help Center/
Cloud Trace Service/
User Guide (ME-Abu Dhabi Region)/
Verifying Trace File Integrity/
Digest Files/
Digest File Signature
The digital signature information of a digest file is in two metadata attributes of the digest file object. Each digest file has the following two metadata items:
- meta-signature
Hexadecimal encoded value of the digest file signature. Example:
7af7cbef4f3c78eab5048030d402810841400cf70eb22f93d4fedd13b13a8208a5dc04ce2f8bd0a4918f933ca3fcb17595ae59386a2dc3e3046fa97688a9815a2d036fa10193534c0ebbecff67221e22ac9cf8b781cbae3a81eaccfc0a2bd1a99081b1e4fe99b19caa771876ba7cce16d002feb4578cd89bc6f1faaca639ab48f3cb56007bcc5e248968f4a17a95b8cdbc7d8bbd7c63630da878cd4d471fc75c60bac5f730d94fefe8fdd2f2fa8accd62dbe100eab7773e7915e91be4474291b9dacea63a8267390bcb4855b5825554ebb07d4a29ce077c364213c575c461d1e9fafa0c29fde1c6de1d5630e015200821b2f3ae91e53cd8591433dd7c0b4c8bc
Parent topic: Digest Files
