- What's New
- Function Overview
- Getting Started
- User Guide
- Best Practices
- API Reference
- SDK Reference
- Must I Use an IAM User (Sub Account) to Configure Transfer on CTS and Perform Operations on an OBS Bucket?
- What Information Is on the Trace List?
- How Will CTS Be Affected If My Account Balance Is Insufficient?
- What Are the Recommended Users of CTS?
- What Will Happen If I Have Enabled Trace Transfer But Have Not Configured an Appropriate Policy for an OBS Bucket?
- Does CTS Support Integrity Verification of Trace Files?
- Why Are There Some Null Fields on the View Trace Page?
- Why Is an Operation Recorded Twice in the Trace List?
- What Services Are Supported by Key Event Notifications?
- How Can I Store Trace Files for a Long Time?
- Why Are user and source_ip Null for Some Traces with trace_type as SystemAction?
- How Do I Find Out Who Created a Specific ECS?
- How Do I Find Out the Login IP Address of an IAM User?
- Why Are Two deleteMetadata Traces Generated When I Buy an ECS in Pay-per-Use or Yearly/Monthly?
- What If I Cannot Query Traces?
- Can I Disable CTS?
- How Do I Make the Log Retention Period 180 Days?
- What Can I Do If a Tracker Cannot Be Created on the CTS Console?
- What Should I Do If I Cannot Enable CTS as an IAM User?
- How Do I Enable Alarm Notifications for EVS?
- Can I Receive Duplicate Traces?
- What Should I Do If I Fail to Transfer Data to an OBS Bucket Authorized by a Key of Another Tenant?
- Does the cts_admin_trust Agency Include OBS Authorization?
- Does CTS Record ECS Creation Failures?
- Glossary
More Documents
- Getting Started
- Querying Traces
- Management Trackers
- Data Trackers
- Application Examples
- Trace References
- Cross-Tenant Transfer Authorization
- Verifying Trace File Integrity
- Auditing
- Permissions Management
- Supported Services and Operations
- Why Are Two deleteMetadata Traces Generated When I Buy an ECS?
- API Reference (ME-Abu Dhabi Region)
User Guide (Paris)
- Getting Started
- Querying Traces
- Trace References
- Auditing
- API Reference (Paris)
- Getting Started
- Querying Traces
- Trackers
- Organization Trackers
- Trace References
- Auditing
- API Reference (Kuala Lumpur Region)
- Videos
On this page
Show all
Help Center/
Cloud Trace Service/
User Guide (ME-Abu Dhabi Region)/
Trace References/
Example Traces
Example Traces
This section provides two example traces and describes their key fields to help you better understand traces. You can read other traces in a similar way as shown below.
For details on the fields in a trace file, see Trace Structure.
ECS Server Creation
{ "time": "2016/12/08 11:07:28 GMT+08:00", "user": { "name": "aaa/op_service", "id": "f2fe9fac63414a35a7d03108d5f1ea73", "domain": { "name": "aaa", "id": "1f9b9ba51f6b4061bd5c1736b28469f8" } }, "request": { "server": { "name": "as-config-15f1_XWO68TFC", "imageRef": "b2b2c7dc-bbb0-4d6b-81dd-f0904023d54f", "flavorRef": "m1.tiny", "personality": [], "vpcid": "e4c374b9-3675-482c-9b81-4acd59745c2b", "nics": [ { "subnet_id": "fff89132-88d4-4e5b-9e27-d9001167d24f", "nictype": null, "ip_address": null, "binding:profile": null, "extra_dhcp_opts": null } ], "adminPass": "********", "count": 1, "metadata": { "op_svc_userid": "26e96eda18034ae9a44130bacb967b96" }, "availability_zone": "az1.dc1", "root_volume": { "volumetype": "SATA", "extendparam": { "resourceSpecCode": "SATA" }, "size": 40 }, "data_volumes": [], "security_groups": [ { "id": "dd597fd7-d119-4994-a22c-891fcfc54be1" } ], "key_name": "KeyPair-3e51" } }, "response": { "status": "SUCCESS", "entities": { "server_id": "42d39b4a-19b7-4ee2-b01b-a9f1353b4c54" }, "job_id": "4010b39d58b855980158b8574b270018", "job_type": "createSingleServer", "begin_time": "2016-12-01T03:04:38.437Z", "end_time": "2016-12-01T03:07:26.871Z", "error_code": null, "fail_reason": null }, "service_type": "ECS", "resource_type": "ecs", "resource_name": "as-config-15f1_XWO68TFC", "resource_id": "42d39b4a-19b7-4ee2-b01b-a9f1353b4c54", "source_ip": "", "trace_name": "createSingleServer", "trace_rating": "normal", "trace_type": "SystemAction", "api_version": "1.0", "record_time": "2016/12/08 11:07:28 GMT+08:00", "trace_id": "4abc3a67-b773-11e6-8412-8f0ed3cc97c6" }
You can pay special attention to the following fields:
- time indicates the time when the trace occurred. In this example, the time is 11:07:28 on December 8.
- user indicates the user who performed the operation. In this example, the user is aaa (name field) under the enterprise account aaa (domain field).
- request indicates the request to create an ECS server. It contains basic information about the ECS server, such as its name (as-config-15f1_XWO68TFC) and VPC ID (e4c374b9-3675-482c-9b81-4acd59745c2b).
- response indicates the response to the ECS creation request. It contains status (SUCCESS in this example), error_code (null in this example), and fail_reason (null in this example).
EVS Disk Creation
{ "time": "2016/12/08 11:24:04 GMT+08:00", "user": { "name": "aaa", "id": "26e96eda18034ae9a44130bacb967b96", "domain": { "name": "aaa", "id": "1f9b9ba51f6b4061bd5c1736b28469f8" } }, "request": "", "response": "", "service_type": "EVS", "resource_type": "evs", "resource_name": "volume-39bc", "resource_id": "229142c0-2c2e-4f01-a1b4-2dfdf1c678c7", "source_ip": "10.146.230.124", "trace_name": "deleteVolume", "trace_rating": "normal", "trace_type": "ConsoleAction", "api_version": "1.0", "record_time": "2016/12/08 11:24:04 GMT+08:00", "trace_id": "c529254f-bcf5-11e6-a89a-7fc778a6c92c" }
- time indicates the time when the trace occurred. In this example, the time is 11:24:04 on December 8.
- request: optional. It is null in this example.
- response: optional. It is null in this example.
- trace_rating indicates the trace status. It can replace the response field to indicate the operation result. In this example, the value is normal, indicating that the operation was successful according to Trace Structure.
Parent topic: Trace References
