- What's New
- Function Overview
- Getting Started
- User Guide
- Best Practices
- API Reference
- SDK Reference
- Must I Use an IAM User (Sub Account) to Configure Transfer on CTS and Perform Operations on an OBS Bucket?
- What Information Is on the Trace List?
- How Will CTS Be Affected If My Account Balance Is Insufficient?
- What Are the Recommended Users of CTS?
- What Will Happen If I Have Enabled Trace Transfer But Have Not Configured an Appropriate Policy for an OBS Bucket?
- Does CTS Support Integrity Verification of Trace Files?
- Why Are There Some Null Fields on the View Trace Page?
- Why Is an Operation Recorded Twice in the Trace List?
- What Services Are Supported by Key Event Notifications?
- How Can I Store Trace Files for a Long Time?
- Why Are user and source_ip Null for Some Traces with trace_type as SystemAction?
- How Do I Find Out Who Created a Specific ECS?
- How Do I Find Out the Login IP Address of an IAM User?
- Why Are Two deleteMetadata Traces Generated When I Buy an ECS in Pay-per-Use or Yearly/Monthly?
- What If I Cannot Query Traces?
- Can I Disable CTS?
- How Do I Make the Log Retention Period 180 Days?
- What Can I Do If a Tracker Cannot Be Created on the CTS Console?
- What Should I Do If I Cannot Enable CTS as an IAM User?
- How Do I Enable Alarm Notifications for EVS?
- Can I Receive Duplicate Traces?
- What Should I Do If I Fail to Transfer Data to an OBS Bucket Authorized by a Key of Another Tenant?
- Does the cts_admin_trust Agency Include OBS Authorization?
- Does CTS Record ECS Creation Failures?
- Glossary
More Documents
- Getting Started
- Querying Traces
- Management Trackers
- Data Trackers
- Application Examples
- Trace References
- Cross-Tenant Transfer Authorization
- Verifying Trace File Integrity
- Auditing
- Permissions Management
- Supported Services and Operations
- Why Are Two deleteMetadata Traces Generated When I Buy an ECS?
- API Reference (ME-Abu Dhabi Region)
User Guide (Paris)
- Getting Started
- Querying Traces
- Trace References
- Auditing
- API Reference (Paris)
- Getting Started
- Querying Traces
- Trackers
- Organization Trackers
- Trace References
- Auditing
- API Reference (Kuala Lumpur Region)
- Videos
Show all
Trace Structure
A trace consists of multiple key fields shown in Table 1.
- This section describes the key trace fields displayed on the CTS console.
- When some fields are displayed on the CTS console, their formats are optimized for easy understanding.
Field |
Mandatory |
Type |
Description |
time |
Yes |
Date |
Time when a trace occurred When the field is displayed on the console, its value is the local standard time (in GMT time), for example, Dec 8, 2016 11:24:04 GMT+08:00. However, this field is transmitted and stored as a timestamp in APIs. In this case, the value is the number of milliseconds since 00:00:00 on January 1, 1970 (GMT). |
user |
Yes |
Structure |
Cloud account used to perform an operation The value is also displayed in the Operator column on the Trace List page. This field is transmitted and stored as a string in APIs. |
request |
No |
Structure |
Requested operation This field is transmitted and stored as a string in APIs. |
response |
No |
Structure |
Response to a request This field is transmitted and stored as a string in APIs. |
service_type |
Yes |
String |
Operation source |
resource_type |
Yes |
String |
Resource type |
resource_name |
No |
String |
Resource name |
resource_id |
No |
String |
Unique resource ID |
source_ip |
Yes |
String |
IP address of the user that performed an operation The value of this field is empty if the operation was triggered by system. |
trace_name |
Yes |
String |
Operation name |
trace_rating |
Yes |
String |
Trace status. The value can be normal, warning, or incident.
trace_type |
Yes |
String |
Operation type There are types of operations:
api_version |
No |
String |
Version of the cloud service API which was called to perform an operation |
message |
No |
Structure |
Remarks |
record_time |
Yes |
Number |
Time when the operation was recorded, in the form of a timestamp |
trace_id |
Yes |
String |
Unique operation ID |
