- What's New
- Function Overview
- Getting Started
- User Guide
- Best Practices
- API Reference
- SDK Reference
- Must I Use an IAM User (Sub Account) to Configure Transfer on CTS and Perform Operations on an OBS Bucket?
- What Information Is on the Trace List?
- How Will CTS Be Affected If My Account Balance Is Insufficient?
- What Are the Recommended Users of CTS?
- What Will Happen If I Have Enabled Trace Transfer But Have Not Configured an Appropriate Policy for an OBS Bucket?
- Does CTS Support Integrity Verification of Trace Files?
- Why Are There Some Null Fields on the View Trace Page?
- Why Is an Operation Recorded Twice in the Trace List?
- What Services Are Supported by Key Event Notifications?
- How Can I Store Trace Files for a Long Time?
- Why Are user and source_ip Null for Some Traces with trace_type as SystemAction?
- How Do I Find Out Who Created a Specific ECS?
- How Do I Find Out the Login IP Address of an IAM User?
- Why Are Two deleteMetadata Traces Generated When I Buy an ECS in Pay-per-Use or Yearly/Monthly?
- What If I Cannot Query Traces?
- Can I Disable CTS?
- How Do I Make the Log Retention Period 180 Days?
- What Can I Do If a Tracker Cannot Be Created on the CTS Console?
- What Should I Do If I Cannot Enable CTS as an IAM User?
- How Do I Enable Alarm Notifications for EVS?
- Can I Receive Duplicate Traces?
- What Should I Do If I Fail to Transfer Data to an OBS Bucket Authorized by a Key of Another Tenant?
- Does the cts_admin_trust Agency Include OBS Authorization?
- Does CTS Record ECS Creation Failures?
- Glossary
More Documents
- Getting Started
- Querying Traces
- Management Trackers
- Data Trackers
- Application Examples
- Trace References
- Cross-Tenant Transfer Authorization
- Verifying Trace File Integrity
- Auditing
- Permissions Management
- Supported Services and Operations
- Why Are Two deleteMetadata Traces Generated When I Buy an ECS?
- API Reference (ME-Abu Dhabi Region)
User Guide (Paris)
- Getting Started
- Querying Traces
- Trace References
- Auditing
- API Reference (Paris)
- Getting Started
- Querying Traces
- Trackers
- Organization Trackers
- Trace References
- Auditing
- API Reference (Kuala Lumpur Region)
- Videos
Show all
Configuring a Tracker
You can configure key event notifications of trackers on the CTS console no matter whether the trackers are enabled or not. For enabled trackers, you can also configure Transfer to OBS or Transfer to LTS for trace transfer.
- You can select an existing OBS bucket for trace transfer. CTS will automatically attach a required policy to the OBS bucket.
- If you modify the trace file prefix of a tracker, the OBS bucket policy will not be affected.
There are three storage classes of OBS buckets, Standard, Infrequent Access, and Archive. You must use Standard OBS buckets for trace transfer because CTS needs to frequently access the OBS buckets.
The configuration will take effect immediately after it is complete.
This section describes how to configure a data tracker.
You have enabled CTS and created a data tracker.
- Click
in the upper left corner to select the desired region and project.
- Click
in the upper left corner and choose Management & Deployment > Cloud Trace Service. The CTS console is displayed.
- Choose Tracker List in the left navigation pane.
- Click Configure in the Operation column in the row of the target data tracker.
- In the Select Trace step, the name of the current OBS bucket is displayed by default for OBS Bucket under Data Trace Source and cannot be changed. In the Configure Transfer step, you can modify the transfer settings of the tracker. For details about the parameters, see Table 1.
Table 1 Parameters for configuring a transfer Parameter
Transfer to OBS
If you select Yes, select an existing OBS bucket or create one on the Configure Tracker page and set File Prefix.
When Transfer to OBS is disabled, no operation is required.
Create a cloud service agency.
(Mandatory) If you select this check box, CTS automatically creates a cloud service agency when you create a tracker. The agency authorizes you to use OBS.
OBS Bucket
New: If this function is enabled, an OBS bucket will be created automatically with the name you enter.
Select Existing: Select an existing OBS bucket.
Select Bucket
When you select New, enter an OBS bucket name. The OBS bucket name cannot be empty. It can contain 3 to 63 characters, including only lowercase letters, digits, hyphens (-), and periods (.). It cannot contain two consecutive periods (for example, my..bucket). A period (.) and a hyphen (-) cannot be adjacent to each other (for example, my-.bucket and my.-bucket). Do not use an IP address as a bucket name.
When you select Existing, select an existing OBS bucket.
Retention Period
The duration for storing traces in the OBS bucket. This configuration will apply to the selected bucket and all files in it. Different compliance standards require different trace retention periods. You are advised to set the retention period to at least 180 days.- For a data tracker, you can set the duration to 30 days, 60 days, 90 days, 180 days, 3 years, or the same as that of OBS.
File Prefix
A prefix is used to mark a transferred trace file. Your specified prefix will be automatically added to the beginning of the name of a transferred file, helping you quickly filter files. Enter 0 to 64 characters. Only letters, digits, hyphens (-), underscores (_), and periods (.) are allowed.
Transfer to LTS
When Transfer to LTS is enabled, traces are transferred to the log stream.
Log group name
When Transfer to LTS is enabled, the default log group name CTS is set. When Transfer to LTS is disabled, no operation is required.
- Click Next > Configure to complete the configuration of the data tracker.
You can then view the tracker details on the Tracker List page.
Traces recorded by CTS are delivered periodically to the OBS bucket for storage. If you configure an OBS bucket for a tracker, traces generated during the current cycle (usually several minutes) will be delivered to the configured OBS bucket. For example, if the current cycle is from 12:00:00 to 12:05:00 and you configure an OBS bucket for a tracker at 12:02:00, traces received from 12:00:00 to 12:02:00 will also be delivered to the configured OBS bucket for storage at 12:05:00.
