- What's New
- Function Overview
- Getting Started
User Guide
- Overview
- Permissions Management
Cloud Resource Monitoring
- Resource Groups
Server Monitoring
- Overview
- Cloud Eye Plug-in (Agent)
- Process Monitoring
- Viewing Server Monitoring Metrics
- Creating an Alarm Rule to Monitor a Server
- Viewing Server Monitoring Details
- Cloud Service Monitoring
- Task Center
- Visualization (Dashboards)
Alarm Management
- Overview
- Alarm Rules
- Alarm Records
Alarm Templates
- Viewing Alarm Templates
- Creating a Custom Template or Custom Event Template
- Modifying a Custom Template or Custom Event Template
- Deleting a Custom Template or Custom Event Template
- Copying a Custom Template or Custom Event Template
- Associating a Custom Template with a Resource Group
- Importing and Exporting Custom Template or Custom Event Templates
- Alarm Notifications
- Example: Creating an Alarm Rule to Monitor ECS CPU Usage
- One-Click Monitoring
- Alarm Masking
- Event Monitoring
- Access Center
- Data Dump
- Quotas and Audit
- Cloud Product Metrics
- Change History
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
API V1
- API Version Management
- Metrics
Alarm Rules
- Querying Alarm Rules
- Querying Details of an Alarm Rule
- Enabling or Disabling an Alarm Rule
- Deleting an Alarm Rule
- Creating a Custom Alarm Template
- Deleting a Custom Alarm Template
- Querying the Alarm History of an Alarm Rule
- Querying Custom Alarm Templates
- Updating a Custom Alarm Template
- Modifying an Alarm Rule
- Monitoring Data
- Quotas
- Resource Groups
- Event Monitoring
API V2
- Alarm Rules
- Resources in an Alarm Rule
- Alarm Policies
- Alarm Records
- Alarm Templates
- Alarm Rules Associated with an Alarm Template
- Resource Groups
- Resources in a Resource Group
- Enabling One-Click Monitoring
- Querying Services and Resources That Support One-Click Monitoring
- Querying Alarm Rules of One Service in One-Click Monitoring
- Batch Enabling or Disabling Alarm Rules of One Service in One-Click Monitoring
- Batch Disabling One-Click Motoring
- Batch Modifying Alarm Notifications in Alarm Rules for One Service That Has One-Click Monitoring Enabled
- Batch Enabling or Disabling Alarm Policies in Alarm Rules for One Service That Has One-Click Monitoring Enabled
Alarm Notification Masking
- Creating Alarm Notification Masking Rules in Batches
- Modifying the Masking Time of Alarm Notification Masking Rules in Batches
- Modifying an Alarm Notification Masking Rule
- Deleting Alarm Notification Masking Rules in Batches
- Querying Alarm Notification Masking Rules
- Querying Resources for Which Alarm Notifications Have Been Masked
- Dashboards
- Graphs
- Resource Tags
- Metric Management
- API V3
Permissions Policies and Supported Actions
- Introduction
- Supported Actions of the API Version Management APIs
- Supported Actions of the Metric Management API
- Supported Actions of the Alarm Rule Management APIs
- Supported Actions of the Monitoring Data Management APIs
- Supported Actions of the Quota Management API
- Supported Actions of the Event Monitoring API
- Common Parameters
- Appendix
- Change History
- SDK Reference
General Consulting
- What Is Rollup?
- How Long Is Metric Data Retained?
- How Many Rollup Methods Does Cloud Eye Support?
- How Can I Export Collected Data?
- What Should I Do If I See Garbled Chinese Characters in an Exported CSV File?
- Why Can't a User of an Enterprise Project View the One-Click Monitoring Function?
- Why Can't a User of an Enterprise Project Select All Resources When Configuring Alarm Rules?
Server Monitoring
Agent Installation
- How Do I Configure DNS and Security Groups?
- How Do I Configure an Agency?
- How Does the Cloud Eye Agent Obtain a Temporary AK/SK by Authorization?
- What OSs Does the Agent Support?
- Resource Usage and Circuit Breaker Pattern of Agent
- What Should I Do If the Monitoring Is Periodically Interrupted or the Agent Status Keeps Changing?
- What Should I Do If a Service Port Is Used by the Agent?
- Troubleshooting Agent One-Click Restoration Failures
- No Monitoring Data Is Displayed After One-Click Restoration Performed for the Agent
- Does the Server Monitoring Agent Affect Server Performance?
- Troubleshooting the Problem of Reported Metrics Being Discarded
- Metrics
Agent Statuses
- How Can I Quickly Restore Agent Configurations?
- What Should I Do If the Agent Status Is Faulty?
- What Should I Do If the Agent Status Is Stopped?
- What Should I Do If the Agent Status Is Running But There Is No Monitoring Data?
- What Can I Do If No Monitoring Data Is Displayed After One-Click Agent Restoration? (Old Agent)
- How Can I Enable the OS Monitoring for a New ECS?
- Agent Status Description and Troubleshooting Methods
- How Do I Obtain Debug Logs of the Agent?
Agent Installation
Alarm Notifications or False Alarms
- What Is an Alarm Notification? How Many Types of Alarm Notifications Are There? How Can I Configure an Alarm Notification?
- What Alarm Status Does Cloud Eye Support?
- What Alarm Severities Does Cloud Eye Support?
- When Will an "Insufficient data" Alarm Be Triggered?
- How Do I Monitor and View the Disk Usage?
- How Can I Change the Phone Number and Email Address for Receiving Alarm Notifications?
- How Can a User Account Receive Alarm Notifications?
- Why Did I Receive a Bandwidth Overflow Notification While There Being No Bandwidth Overflow Record in the Monitoring Data?
Monitored Data Exceptions
- Why Is the Monitoring Data Not Displayed on the Cloud Eye Console?
- Why I Cannot See the Monitoring Data on the Cloud Eye Console After Purchasing Cloud Service Resources?
- Why Doesn't the Cloud Eye Console Display the OS Monitoring Data or Why Isn't the Data Displayed Immediately After the Agent Is Installed and Configured on an ECS?
- Why Is Basic Monitoring Data Inconsistent with Data Monitored by the OS?
- Why Are the Network Traffic Metric Values in Cloud Eye Different from Those Detected in ECS?
- Why Is the Metric Collection Point Lost During Certain Periods of Time?
- Why Are the Four Metrics Memory Usage, Disk Usage, Inband Incoming Rate, and Inband Outgoing Rate Not Displayed for an ECS?
- What Are the Impacts on ECS Metrics If UVP VMTools Is Not Installed on ECSs?
- Why Are the Inbound Bandwidth and Outbound Bandwidth Negative?
- Metric Descriptions
User Permissions
- What Should I Do If the IAM Account Permissions Are Abnormal?
- What Can I Do If the System Displays a Message Indicating Insufficient Permissions When I Access Cloud Eye?
- What Can I Do If the System Displays a Message Indicating Insufficient Permissions When I Click Configure on the Server Monitoring Page?
General Consulting
- Videos
More Documents
- Product Introduction
- Getting Started
- Dashboards
- Resource Groups
- Using the Alarm Function
Server Monitoring
- Introduction to Server Monitoring
- Agent Installation and Configuration
- Agent Features per Version
- Installing and Configuring the Agent on a Linux ECS or BMS
- Installing and Configuring the Agent on a Windows ECS
- Installing the Agents in Batches on Linux ECSs
- Managing the Agent
- Installing the Direct Connect Metric Collection Plug-ins
- Custom Monitoring
- Event Monitoring
- Task Center
- Data Dump
- Auditing Operation Records on Cloud Eye
- Quota Adjustment
- Services Interconnected with Cloud Eye
General Consulting
- What Is Rollup?
- Which Services Does Cloud Eye Support Permission- and Region-based Monitoring in the Enterprise Project Dimension?
- Which Cloud Eye Resources Support the Enterprise Project Feature?
- Why Can a User of an Enterprise Project View the Resource Information of the Account on the Overview Page?
Server Monitoring
- How Can I Quickly Restore the Agent Configuration?
- How Can I Make a Newly Purchased ECS Monitor Its OS?
- Why Is a BMS with the Agent Installed Displayed in the ECS List on the Server Monitoring Page?
- What Statuses Does the Agent Have?
- What Should I Do If the Monitoring Period Is Interrupted or the Agent Status Keeps Changing?
- What Should I Do If the Service Port Is Used by the Agent?
- How Can I Create an Agency?
- What Can't I Create Another Agency?
- What Should I Do If Agency CESAgentAutoConfigAgency Failed to Be Automatically Created?
- What Can I Do If Agency CESAgentAutoConfigAgency Is Invalid?
- Will the Agent Affect the Server Performance?
- How Do I Troubleshoot the Agent One-Click Restoration Failure?
- How Can I Change the Mobile Number and Email Address for Receiving Alarm Notifications?
- How Can an IAM User Receive Alarm Notifications?
- Why Is OS Monitoring Data Not Displayed or Not Displayed Immediately After the Agent Is Installed and Configured on a server?
- Why Is Basic Monitoring Data Inconsistent with the Data Monitored by the OS?
- Why Is the Metric Collection Point Lost During a Certain Period of Time?
- Why Are Memory Usage, Disk Usage, Inband Incoming Rate, and Inband Outgoing Rate Not Displayed for an ECS?
- User Permissions
General Consulting
- Before You Start
- API Overview
- Calling APIs
- API DescriptionAPI V1
- API v2
- Introduction
- Common Parameters
- Appendix
- Change History
User Guide (Paris Region)
- Getting Started
- Monitoring Panels
- Custom Monitoring
- FAQs
- Change History
- API Reference (Paris Region)
- Getting Started
- Dashboards
- Resource Groups
Server Monitoring
- Custom Monitoring
- Event Monitoring
- Data Dump
- Quota Adjustment
- General Consulting
Server Monitoring
- User Permissions
- Change History
- API Reference (Kuala Lumpur Region)
User Guide (Ankara Region)
- Getting Started
- Dashboards
- Resource Groups
Server Monitoring
- Custom Monitoring
- Event Monitoring
- Quota Adjustment
Server Monitoring
- How Do I Query the Current Agent Version?
- Alarm Notifications or False Alarms
- Monitored Data Exceptions
- User Permissions
- Change History
- API Reference (Ankara Region)
On this page
Show all
General Consulting
- What Is Rollup?
Parent topic: FAQs
