Installing a Private Certificate on an Nginx Server
This topic describes how to install a private certificate on an Nginx 1.7.8 server running CentOS 7.
The installation procedure in this topic is for your reference only as the commands executed and configuration file modified during the installation may vary depending on OS types and server configurations.
- The certificate has been issued.
- You have downloaded the private certificate in the format that is supported by Nginx. For details, see Downloading a Certificate.
- You have used a system-generated CSR to apply for the certificate.
- Before installing the certificate, enable port 443 on the server where the private certificate is installed and add port 443 to the security group. Otherwise, HTTPS cannot be enabled after the installation.
- A root CA must be added to the trusted client CA list so that all server certificates issued by the root CA can be trusted by the client. For details, see Trusting a Private Root CA.
- If a domain name maps to multiple servers, deploy the certificate on each server.
- A private certificate can only be installed on the server that maps to the domain name associated with the certificate. Otherwise, the web browser will display a message indicating that the domain name is insecure.
The installation process is as follows (for Nginx 1.7.8 servers running CentOS 7):
Step 1: Obtaining Files → Step 2: Creating a Directory → Step 3: Modifying Configuration Files → Step 4: Verifying the Configuration → Step 5: Restarting Nginx → Verifying the Result
Decompress the downloaded certificate file on your local PC.
You will obtain certificate file server.crt and private key file server.key.
- The server.crt file contains two segments of certificate code: -----BEGIN CERTIFICATE----- and -----END CERTIFICATE-----, which are the server certificate and intermediate CA certificate respectively.
- server.key contains one segment of private key code: -----BEGIN RSA PRIVATE KEY----- and -----END RSA PRIVATE KEY-----.
Create a cert directory in the Nginx installation directory, and copy the server.key and server.crt files to the cert directory.
Before modifying the configuration file, back up the configuration file. You are advised to deploy the configuration file in the test environment and then configure it on the production environment to avoid service interruptions caused by incorrect configurations.
Configure the nginx.conf file in the conf directory of Nginx.
- Find the following configuration:
#server { # listen 443 ssl; # server_name localhost; # ssl_certificate cert.pem; # ssl_certificate_key cert.key; # ssl_session_cache shared:SSL:1m; # ssl_session_timeout 5m; # ssl_ciphers HIGH:!aNULL:!MD5; # ssl_prefer_server_ciphers on; # location / { # root html; # index index.html index.htm; # } #} - Delete comment tags (#) at the beginning of the lines.
server { listen 443 ssl; server_name localhost; ssl_certificate cert.pem; ssl_certificate_key cert.key; ssl_session_cache shared:SSL:1m; ssl_session_timeout 5m; ssl_ciphers HIGH:!aNULL:!MD5; ssl_prefer_server_ciphers on; location / { root html; index index.html index.htm; } } - Modify the following parameters according to Table 1.
ssl_certificate cert/server.crt; ssl_certificate_key cert/server.key;
The complete configuration is as follows. Modify other parameters based on your needs.
server { listen 443 ssl; # Set the default HTTPS port to 443. If the default HTTPS port is not configured, Nginx may fail to start. server_name www.domain.com; #Replace www.domain.com with the domain name associated with your certificate. ssl_certificate cert/server.crt; #Replace cert/server.crt with the path of the certificate file. ssl_certificate_key cert/server.key; #Replace cert/server.key with the path of the private key. ssl_session_cache shared:SSL:1m; ssl_session_timeout 5m; ssl_ciphers HIGH:!aNULL:!MD5; #Encryption suite ssl_prefer_server_ciphers on; location / { root html; #Site directory index index.html index.htm; #Add attributes. } }
Do not directly copy all configuration. Only attributes starting with ssl are directly related to the certificate configuration. Modify other parameters based on site requirements.
Table 1 Parameters Parameter
listen
SSL access port number. Set the value to 443.
server_name
Domain name which the certificate is used for. Example: www.domain.com
ssl_certificate
Certificate file server.crt
Set the value to the path of the server.crt file. An example of the path is cert/server.crt.
ssl_certificate_key
Private key file server.key
Set the value to the path of the server.key file. An example of the path is cert/server.key.
- Save the configuration file.
Go to the execution directory of Nginx and run the following command:
sbin/nginx -t
nginx.conf syntax is ok nginx.conf test is successful
