Downloading a Private Certificate
Updated on 2023-07-26 GMT+08:00
Before using a private certificate, you need to download it. Only downloaded certificate can be assigned to the corresponding certificate subject so that they can install and use the certificate.
This topic describes how to download a private certificate. Only certificates in the Issued state can be downloaded.
Your private certificate is in the Issued state. For details, see Applying for a Private Certificate.
  2. Click in the upper left corner of the page and choose Security > Cloud Certificate Management Service. In the navigation pane, choose Private Certificate Management.
  3. Locate the row of the desired private certificate and click Download in the Operation column.
  4. Click the target tab based on your server type and click Download Certificate.
    When you click OK, CCM will use the download tool provided by the browser to download the private certificate to the specified local directory.
Installing a Private Certificate
After downloading the private certificate, install it on the client or server.
Description of Downloaded Certificate Files
The downloaded certificate files vary depending on the CSR file type (System generated CSR or Upload a CSR) configured when you apply for a private certificate.
  • System generated CSR
    Table 2 describes the downloaded files.
    Table 2 Description of downloaded files (1)
    Server Type
    Files in the Package
    Tomcat
    keystorePass.txt: certificate password
    server.jks: certificate file
    Nginx
    server.crt: certificate files, containing the server certificate and certificate chain
    server.key: certificate private key file
    Apache
    chain.crt: certificate chain file
    IIS
    server.pfx: certificate file
    chain.pem: certificate chain file
    server.pem: certificate file
  • Upload a CSR
    Table 3 describes the downloaded files.
    Table 3 Description of downloaded files (2)
    Server Type
    Tomcat
    Nginx
    Apache
    IIS
    cert.pem: certificate file
