Help Center/
Cloud Certificate & Manager/
User Guide (ME-Abu Dhabi Region)/
Private Certificate Management/
Deleting a Private Certificate
Updated on 2022-12-22 GMT+08:00
This topic describes how to delete a private certificate. A deleted private certificate remains valid and trusted.
You can delete a certificate that is no longer needed.
The private certificate is in the Issued, Expired, or Revoked state.
- A deleted certificate cannot be restored. Exercise caution with the deletion.
- After you submit a certificate deletion application, you cannot cancel it. Exercise caution when performing this operation.
- Click
in the upper left corner of the page and choose Security > Cloud Certificate Management Service. In the navigation pane, choose Private Certificate Management.
- Locate the row of the private certificate to be deleted and click Delete in the Operation column.
- In the displayed dialog box, enter DELETE to confirm the deletion.
- Click OK. If message "Certificate xxx deleted successfully." is displayed in the upper right corner of the page, the private certificate is deleted successfully.
Parent topic: Private Certificate Management
