Help Center/
Cloud Container Engine/
User Guide (ME-Abu Dhabi Region)/
FAQs/
Billing/
How Is CCE Billed?
How Is CCE Billed?
Billing Mode
There is only one billing mode for CCE: pay-per-use.
Pay-per-use is a postpaid billing mode. You pay as you go and just pay for what you use.
Billing Items
You will be billed for clusters, nodes, and other cloud service resources.
- Clusters: the cost of resources used by master nodes. It varies with the cluster type (VMs or BMSs and the number of master nodes) and size (the number of worker nodes).
- Other cloud resources: the cost of IaaS resources in use. Such resources, which are created either manually or automatically during cluster creation, include ECSs, EVS disks, EIPs, bandwidth, and load balancers.
Parent topic: Billing
