Mounting Object Storage Across Accounts
Application Scenarios
  • Cross-account data sharing. For example, multiple teams within a company need to share data, but each team uses a different account.
  • Cross-account data migration and backup. When account A is about to be disabled, all data stored in the account needs to be transferred to a new account (account B).
  • Data processing and analysis. For example, account B is an external data processor and needs to access raw data from account A to perform tasks such as big data analysis and machine learning.
By linking object storage across accounts, you can share data, lower storage and transmission expenses, and guarantee data security and consistency. This enables various teams or organizations to securely and conveniently access each other's data resources, eliminating the need for repeated storage and redundant transmission. Additionally, data is kept current and compliant, enhancing overall service efficiency and security.
Assume that account B needs to access and use an OBS bucket of account A. For details, see Figure 1 and Table 1.
Figure 1 Mounting an OBS bucket across accounts
Table 1 Process description
Step 1: Create an OBS Bucket Policy and ACL
Configure an OBS bucket policy and ACL using account A and grant account B required permissions like the read and write permissions.
Step 2: Create a Workload with an OBS Volume Mounted
Create a PV and a PVC based on the OBS bucket of account A using account B and mount the PVC to the required workload.
Step 3: Check the Pod Actions on the OBS Bucket
Check whether the pod created by account B has the required permissions based on the bucket policy.
Step 4: Clear Resources
Once you have studied this example, delete any associated resources to prevent incurring settlement fees.
  • The involved accounts are in the same region.
  • You have created a cluster where the CCE Container Storage (Everest) add-on is installed. The add version must be 1.1.11 or later, and the cluster version must be 1.15 or later.
  • An ECS with an EIP bound has been created in the same VPC as the cluster, and the ECS has been connected to the cluster through kubectl.
  1. Configure the parameters. In this example, only some mandatory parameters are described. You can keep the default values for other parameters.
    Table 2 Bucket policy parameters
    Example
    Policy Name
    Enter a name.
    example01
    Effect
    Specify the behavior of a policy.
    • Allow: The actions defined in the policy are allowed.
    • Deny: The actions defined in the policy are denied.
    Allow
    Principal
    Specify authorized accounts. (Multiple accounts can be selected.) For different types of authorized accounts, the OBS console provides different templates for authorizations.
    • All accounts: Any account can execute the current bucket policy without identity authentication, which may pose data security risks.
    • Current account: Grant permissions to a specific IAM account under the current account.
    • Other accounts: Grant permissions to a specific IAM account under another account.
    Other accounts
    XXX(account ID)/XXX (IAM ID)
    Resources
    Specify the authorized resources.
    • Entire bucket (including the objects in it): Allow authorized accounts to perform certain actions on a bucket and the objects in it.
    • Current bucket: Allow authorized accounts to perform certain actions on the current bucket.
    • Specific objects: Allow authorized accounts to perform certain actions on the specified objects in a bucket.
    Actions
    Specify actions.
    • Use a template: Use a permission template preset on the OBS console. If you selected Bucket Read/Write, the Specified actions option will be selected by default in the Advanced Settings area.
    • Customize: Customize the actions.
    Use a template > Bucket Read/Write
  2. In the navigation pane, choose Permissions > Bucket ACL. In the right pane, click Add under User Access. Enter the account ID of the authorized user, select Read and Write for Access to Bucket, select Read for Access to Objects, select Read and Write for Access to ACL, and click OK.
  1. Create a ConfigMap named paas-obs-endpoint and configure the region and endpoint of OBS.
    vim config.yaml
    The content is as follows: (For details about the parameters, see Table 3.)
    apiVersion: v1
    kind: ConfigMap
      name: paas-obs-endpoint   # The value must be paas-obs-endpoint.
      namespace: kube-system    # The value must be kube-system.
    data:
      obs-endpoint: |
        {"<region_name>": "<endpoint_address>"}
    Create the ConfigMap using config.yaml.
    kubectl create -f config.yaml
    Table 3 ConfigMap parameters
    ConfigMap
    metadata.name
    ConfigMap name, which is fixed at paas-obs-endpoint and cannot be changed
    metadata.namespace
    Namespace, which is fixed at kube-system and cannot be changed
    data.obs-endpoint
    Region names and endpoints are in key-value pairs. Replace <region_name> and <endpoint_address> with specific values. If multiple values are needed, use commas (,) to separate them.
    For details about its value, see Regions and Endpoints.
  2. Create a secret named test-user. (This secret is used to provide access credentials when volumes are mounted to CSI, and its name can be customized.)
    1. Obtain the AK. Go back to the management console, hover the cursor over the username in the upper right corner and choose My Credentials from the drop-down list.
      In the navigation pane, choose Access Keys. On the page displayed, click Create Access Key.
      Click OK and download the AK.
    2. Encode the AK using Base64 and save the encoded AK and SK. If the AK obtained is xxx and the SK is yyy, run the following commands:
      echo -n xxx|base64
      echo -n yyy|base64
    3. Create a secret YAML file, for example, test_user.yaml.
      vim test_user.yaml
      The content is as follows: (For details about the parameters, see Table 4.)
      apiVersion: v1
      data:
        access.key: QUxPQUlJU******
        secret.key: aVMwZkduQ******
      kind: Secret
        namespace: default
      type: cfe/secure-opaque
      Create a secret using test_user.yaml.
      kubectl create -f test_user.yaml
      Table 4 Secret parameters
      Example
      access.key
      A Base64-encoded AK
      QUxPQUlJU******
      secret.key
      A Base64-encoded SK
      aVMwZkduQ******
      type
      Key type, which is fixed at cfe/secure-opaque and cannot be changed
      When this type is used, the data entered by users will be automatically encrypted.
      cfe/secure-opaque
  3. Create a PV named testing_abc and mount the secret named test_user to the PV.
    vim testing_abc.yaml
    The content is as follows: (For details about the parameters, see Table 5.)
    kind: PersistentVolume
    apiVersion: v1
      annotations:
        pv.kubernetes.io/bound-by-controller: 'yes'
        pv.kubernetes.io/provisioned-by: everest-csi-provisioner
      capacity:
        storage: 1Gi
      mountOptions:
      - default_acl=bucket-owner-full-control      #New OBS mounting parameters
      csi:
        driver: obs.csi.everest.io
        volumeHandle: obs-cce-test                 # Name of the OBS bucket to be mounted
        fsType: s3fs                               # obsfs indicates a parallel file system, and s3fs indicates an OBS bucket.
        volumeAttributes:
          everest.io/obs-volume-type: STANDARD     # Bucket type, which can be STANDARD or WARM when an OBS bucket is used
          everest.io/region: <region_name>         # Region where the OBS bucket is located (Replace it with the actual value.)
          storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner
        nodePublishSecretRef:                      # AK/SK used for mounting the OBS bucket
          namespace: default
      accessModes:
        - ReadWriteMany
      persistentVolumeReclaimPolicy: Retain        # PV reclaim policy
      storageClassName: csi-obs                    # csi-obs specifies an OBS storage class that is automatically created. You can customize it as required.
      volumeMode: Filesystem
    Create the PV using testing_abc.yaml.
    kubectl create -f testing_abc.yaml
    Table 5 PV parameters
    Example
    mountOptions.default_acl
    Specify access control policies for a bucket and objects in the bucket. In this example, account A owns the bucket, and both account A and account B have the ability to upload data.
    • private: The bucket or objects can only be fully accessed by the owner of the bucket.
    • public-read: The owner of the bucket has complete control over both the bucket and its objects. While other users can read data from the bucket, they are unable to modify, delete, or upload any data within it.
    • public-read-write: The owner of the bucket has complete control over the bucket and its objects. Other users can read and write data from and to the bucket.
    • bucket-owner-read: Users who have uploaded objects to the bucket has complete control over the objects, while the bucket owner is only granted read permissions for said objects. This mode is usually used in cross-account sharing scenarios.
    • bucket-owner-full-control: Users who have uploaded objects to the bucket are granted write permissions for those specific objects, but not read permissions by default. The bucket owner has complete control over all objects within the bucket. This mode is usually used in cross-account sharing scenarios.
    Due to the bucket policy that was configured using account A, account B has been granted read and write permissions for the entire bucket, including objects uploaded by both account A and B.
    csi.nodePublishSecretRef
    Specify the secret to be mounted.
    • name: name of a secret
    • namespace: namespace where the secret is in
    test-user
    default
    csi.volumeHandle
    Specify the name of the OBS bucket to be mounted.
    obs-cce-test (OBS bucket name authorized by account A)
    csi.fsType
    Specify the file type.
    • obsfs: Create an OBS parallel file system.
    • s3fs: Create an OBS bucket.
    s3fs
    NOTICE:
    The file type specified by the PV and the PVC must match in order for the PV to be bound to the corresponding PVC. If they do not match, the binding cannot occur.
    accessModes
    Specify the access mode of the storage volume. OBS supports only ReadWriteMany.
    • ReadWriteOnce: A storage volume can be mounted to a single node in read-write mode.
    • ReadWriteMany: A storage volume can be mounted to multiple nodes in read-write mode.
    ReadWriteMany
    Specify the reclaim policy for the PV.
    • Delete: When a PVC is deleted, both the PV and underlying storage resources will be deleted. If the everest.io/reclaim-policy: retain-volume-only annotation is added to the YAML file, the underlying storage resources will be retained.
    • Retain: When a PVC is deleted, both the PV and underlying storage resources will be retained. You need to manually delete them. After the PVC is deleted, the PV is in the Released state and cannot be bound to a PVC again.
    Retain
    If multiple PVs use the same OBS volume, use Retain to prevent the underlying volume from being deleted with one of the PV.
  4. Create a PVC named pvc-test-abc and bind the new PV testing_abc to it.
    vim pvc_test_abc.yaml
    The file content is as follows:
    apiVersion: v1
    kind: PersistentVolumeClaim
      namespace: default
      annotations:
        csi.storage.k8s.io/node-publish-secret-name: test-user      # Mount a secret.
        csi.storage.k8s.io/node-publish-secret-namespace: default   # Namespace of the secret
        csi.storage.k8s.io/fstype: s3fs            # File type. obsfs indicates a parallel file system, and s3fs indicates an OBS bucket.
        volume.beta.kubernetes.io/storage-provisioner: everest-csi-provisioner
      accessModes:
      - ReadWriteMany             # The value must be ReadWriteMany for object storage.
      resources:
        requests:
          storage: 1Gi            # Storage capacity of a PVC. This parameter is valid only for verification (fixed to 1, cannot be empty or 0). The value setting does not take effect for OBS buckets.
      volumeName: testing-abc     # PV name
    Create the PVC using pvc_test_abc.yaml.
    kubectl create -f pvc_test_abc.yaml
  5. Create a workload and mount the PVC to it. The following uses an Nginx Deployment as an example.
    vim obs_deployment_example.yaml
    apiVersion: apps/v1
    kind: Deployment
      name: obs-deployment-example                  # Workload name, which can be customized
      namespace: default
      replicas: 1
      selector:
        matchLabels:
          app: obs-deployment-example              # Label, which can be customized
      template:
          labels:
          containers:
          - image: nginx
            volumeMounts:
            - mountPath: /tmp                       # PVC mount path, which can be customized as required
          restartPolicy: Always
          imagePullSecrets:
            - name: default-secret
          volumes:
          - name: pvc-obs-example
            persistentVolumeClaim:
              claimName: pvc-test-abc               # PVC name
    Create the workload named obs-deployment-example using obs_deployment_example.yaml.
    kubectl create -f obs_deployment_example.yaml
    Check whether the workload has been created.
    kubectl get pod
    If information similar to the following is displayed and the workload is in the Running state, the workload has been created.
    NAME                                      READY   STATUS              RESTARTS        AGE
    obs-deployment-example-6b4dfd7b57-frfxv   1/1     Running             0               22h
  1. Check whether the pod can read and write objects in the OBS bucket created by account A and assume that a test.txt file is present in the OBS bucket.
    Run the following command to access the created workload. (You can press Ctrl+D to exit the current workload.)
    kubectl -n default exec -it obs-deployment-example-6b4dfd7b57-frfxv -c container-0 -- bash
    Run the following command to check the pod actions on test.txt. /tmp specifies the PVC mount path.
    ls -l /tmp/test.txt
    If information similar to the following is displayed, the pod has the read and write permissions on the test.txt file, which is related to the bucket policy set by account A.
    -rwxrwxrwx 1 root root 4 Sep  5 09:09 /tmp/test.txt
  2. Check whether the pod can read and write data from and to the objects uploaded by itself in the OBS bucket.
    Create a test01.txt file in /tmp and write test\n into the file.
    echo -e "test\n" > /tmp/test01.txt
    Run the following command to check the test01.txt content and check whether the pod can read and write new objects uploaded by itself: (Account A can check the new objects in the OBS bucket.)
    cat /tmp/test01.txt
    If information similar the following is displayed, the pod has the read and write permissions on the objects uploaded by itself.
    test
Once you have studied this example, delete any associated resources to prevent incurring settlement fees. If you plan to learn other examples, wait until they are finished before doing any clean-up.
  1. Run the following command to delete the workload:
    kubectl delete -f obs_deployment_example.yaml
    Information similar to the following is displayed:
    deployment.apps "obs-deployment-example" deleted
  2. Run the following command to delete the PVC:
    kubectl delete -f pvc_test_abc.yaml
    persistentvolumeclaim "pvc-test-abc" deleted
  3. Run the following command to delete the PV:
    kubectl delete -f testing_abc.yaml
    persistentvolume "testing-abc" deleted
  4. Run the following command to delete the secret:
    kubectl delete -f test_user.yaml
    secret "test-user" deleted
  5. Run the following command to delete the ConfigMap:
    kubectl delete -f config.yaml
    configmap "paas-obs-endpoint" deleted
Common Issues
If a workload fails to be created, locate the fault based on the error information in the pod events. For details, see Table 6.
Table 6 Locating the fault
Error
Possible Cause
Fault Locating
0/4 nodes are available: pod has unbound immediate PersistentVolumeClaims. preemption: 0/4 nodes are available: 4 Preemption is not helpful for scheduling.
The PVC is not bound to any PV.
  1. Run the following command to check the PVC status:
    kubectl get pvc
    If the PVC is in the Pending state, it is not bound to any PV.
  2. Check the PVC details and locate the cause of the binding failure.
    kubectl describe pvc <pvc_name>
  3. Modify the YAML file to rectify the fault if the fault is caused by any of the following reasons:
    • The PVC is not bound to the proper PV.
    • The PVC and PV parameters do not match. This includes fsType, StorageClass, accessModes, and storage. The StorageClass must be object storage, and accessModes must be set to ReadWriteMany because OBS buckets only support this mode. Additionally, the storage value requested by the PVC must be equal to or less than the storage value provided by the PV.
MountVolume.SetUp failed for volume "obs-cce-example": rpc error: code = Unknown desc = failed to get secret(paas.longaksk), err: get secret(paas.longaksk) failed: get secret paas.longaksk from namespace kube-system failed: secrets "paas.longaksk" not found
The required secret cannot be found when the storage volume is mounted to the workload.
  1. Check whether the mounted secret is present.
    kubectl get secret
    If it is present, the secret may be incorrectly configured. If it is not present, you can create one by referring to 2.
  2. Check the secret parameter configurations. The following shows the common issues:
    • The access.key and secret.key parameters are not set to the AK and SK encoded using Base64.
    • The type parameter is not set to cfe/secure-opaque.
MountVolume.SetUp failed for volume "pv-obs-example": rpc error: code = Internal desc = [8032c354-4e1b-41b0-81ce-9d4b3f8c49c9] get obsUrl failed before mount bucket obs-cce-example, get configMap paas-obs-endpoint from namespace kube-system failed: configmaps "paas-obs-endpoint" not found
The ConfigMap that stores the OBS endpoint is not present or is incorrectly configured.
  1. Check whether the ConfigMap is present.
    kubectl get configmap -n kube-system
    If it is present, the ConfigMap may be incorrectly configured. If it is not present, you can create one by referring to 1.
  2. Check the ConfigMap parameter configurations. The following shows the common issues:
    • The name parameter is not set to paas-obs-endpoint.
    • The namespace parameter is not set to kube-system.
    • The region name is not set to the region where the OBS bucket is located.
