Modifying Node Pool Configurations
Notes and Constraints
The default node pool does not support the following management operations.
Configuration Management
CCE allows you to highly customize Kubernetes parameter settings on core components in a cluster. For more information, see kubelet.
This function is supported only in clusters of v1.15 and later. It is not displayed for versions earlier than v1.15.
- Log in to the CCE console.
- Click the cluster name to access the cluster console. Choose Nodes in the navigation pane. In the right pane, click the Node Pools tab.
- Click Manage in the Operation column of the target node pool
- On the Manage Components page on the right, change the values of Kubernetes parameters.
Table 1 kubelet Item
Value
Modification
CPU management policy
cpu-manager-policy
CPU management policy configuration. For details, see CPU Scheduling.
- none: disables pods from exclusively occupying CPUs. Select this value if you want a large pool of shareable CPU cores.
- static: enables pods to exclusively occupy CPUs. Select this value if your workload is sensitive to latency in CPU cache and scheduling.
- enhanced-static: allows burstable pods to preferentially use CPU cores. Select this value if your workload has huge peak-trough difference and is in the trough state most of the time.
Default: none
None
QPS for requests to kube-apiserver
kube-api-qps
Number of queries per second for communication with the API server.
Default: 100
None
Burst for requests to kube-apiserver
kube-api-burst
Maximum number of burst requests sent to the API server per second.
Default: 100
None
Limit on the pods managed by kubelet
max-pods
Maximum number of pods that can run on a node.
- For a CCE standard cluster, the maximum number of pods is determined based on the maximum number of pods on a node.
- For a CCE Turbo cluster, the maximum number of pods is determined based on the number of NICs on a CCE Turbo cluster node.
None
Limited number of processes in a pod
pod-pids-limit
Maximum number of PIDs that can be used in each pod.
Default: -1, which indicates that the number of PIDs is not limited
None
Whether to use a local IP address as a node's ClusterDNS
with-local-dns
The default ENI IP address of the node will be automatically added to the node's kubelet configuration as the preferred DNS address.
Default: false
None
QPS limit on creating events
event-qps
Number of events that can be generated per second.
Default: 5
None
Upper Limit for Burst Events
event-burst
Upper limit for burst event creation. The number of burst events can be temporarily increased to the specified value.
Default: 10
None
Allowed unsafe sysctls
allowed-unsafe-sysctls
Insecure system configuration allowed.
Starting from v1.17.17, CCE enables pod security policies for kube-apiserver. Add corresponding configurations to allowedUnsafeSysctls of a pod security policy to make the policy take effect. (This configuration is not required for clusters earlier than v1.17.17.) For details, see Example of Enabling Unsafe Sysctls in Pod Security Policy.
Default: []
None
Node oversubscription
over-subscription-resource
Whether to enable node oversubscription.
If this parameter is set to true, node oversubscription is enabled on nodes.
- For clusters of versions earlier than v1.23.9-r0 or v1.25.4-r0: enabled (true) by default
- Disabled by default if the cluster version is v1.23.9-r0, v1.25.4-r0, v1.27-r0, or later
None
Hybrid deployment
colocation
Whether to enable hybrid deployment on nodes.
If this parameter is set to true, hybrid deployment is enabled on nodes.
None
Topology management policy
topology-manager-policy
Set the topology management policy.
Valid values are as follows:
- restricted: kubelet accepts only pods that achieve optimal NUMA alignment on the requested resources.
- best-effort: kubelet preferentially selects pods that implement NUMA alignment on CPU and device resources.
- none (default): The topology management policy is disabled.
- single-numa-node: kubelet allows only pods that are aligned to the same NUMA node in terms of CPU and device resources.
Default: none
NOTICE:Modifying topology-manager-policy and topology-manager-scope will restart kubelet, and the resource allocation of pods will be recalculated based on the modified policy. In this case, running pods may restart or even fail to receive any resources.
Topology management scope
Configure the resource alignment granularity of the topology management policy. Valid values are as follows:
- container (default)
- pod
Default: container
Specified DNS configuration file
resolv-conf
DNS resolution configuration file specified by the container
Default: null
None
Timeout for all runtime requests except long-running requests
runtime-request-timeout
Timeout interval of all runtime requests except long-running requests (pull, logs, exec, and attach).
Default: 2m0s
This parameter is available only in clusters of v1.21.10-r0, v1.23.8-r0, v1.25.3-r0, or later versions.
Whether to allow kubelet to pull only one image at a time
serialize-image-pulls
Pull an image in serial mode.
- false: recommended configuration so that an image can be pulled in parallel mode to improve pod startup.
- true: allows images to be pulled in serial mode.
- Enabled by default if the cluster version is earlier than v1.21.12-r0, v1.23.11-r0, v1.27.3-r0 or v1.25.6-r0
- Disabled by default if the cluster version is v1.21.12-r0, v1.23.11-r0, v1.25.6-r0, v1.27.3-r0, or later
Image repository pull limit per second
registry-pull-qps
QPS upper limit of an image repository.
Default: 5
The value ranges from 1 to 50.
Upper limit of burst image pull
registry-burst
Maximum number of burst image pulls.
Default: 10
The value ranges from 1 to 100 and must be greater than or equal to the value of registry-pull-qps.
Maximum Number of Container Log Files
container-log-max-files
Maximum number of container log files. When the number of existing log files exceeds this value, the earliest log file will be deleted to release space for new log files.
Default: 10
Value range: 2 to 100
This parameter is available only in clusters of v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later versions.
Maximum Container Log File Size
container-log-max-size
Maximum size of a single container log file. When the size of a log file reaches this value, the current log file will be closed and a new log file will be created to continue logging.
Default: 50
Value range: 1 to 4096
Upper Limit for Image Garbage Collection
image-gc-high-threshold
When the kubelet disk usage reaches this value, kubelet starts to collect image garbage.
Default: 80
Value range: 1 to 100
To disable image garbage collection, set this parameter to 100.
Lower Limit for Image Garbage Collection
image-gc-low-threshold
When the disk usage reduces to this value, image garbage collection stops.
Default: 70
The value of this parameter cannot be greater than the upper limit for image garbage collection.
Node memory reservation
system-reserved-mem
System memory reservation reserves memory resources for OS system daemons such as sshd and udev.
Default value: automatically calculated, which varies depending on node flavors. For details, see Node Resource Reservation Policy.
Optional configurations are as follows:- Automatically calculated reserved memory: Use this function for node stability.
The reserved value varies depending on node flavors. For details, see Node Resource Reservation Policy.
- Custom reserved memory: The reserved node memory is customized.
The sum of kube-reserved-mem and system-reserved-mem must be less than 50% of the minimum memory of nodes in the node pool.
kube-reserved-mem
Kubernetes memory reservation reserves memory resources for Kubernetes daemons such kubelet and container runtime.
Hard eviction
memory.available
Available memory on a node.
The value is fixed at 100 MiB.
For details, see Node-pressure Eviction.
NOTICE:Exercise caution when modifying an eviction configuration item. Improper configuration may cause pods to be frequently evicted or fail to be evicted when the node is overloaded.
kubelet can identify the following specific file system identifiers:
- nodefs: main file system of a node. It is used for local disk volumes, emptyDir volumes that are not supported by memory, and log storage. For example, nodefs contains /var/lib/kubelet/.
- imagefs: file system partition used by a container engine.
nodefs.available
Percentage of the available capacity in the filesystem used by kubelet.
Default: 10%
Value range: 1% to 99%
nodefs.inodesFree
Percentage of available inodes in the filesystem used by kubelet.
Default: 5%
imagefs.available
Percentage of the available capacity in the filesystem used by container runtimes to store resources such as images.
Default: 10%
imagefs.inodesFree
Percentage of available inodes in the filesystem used by container runtimes to store resources such as images.
This parameter is left blank by default.
pid.available
Percentage of allocatable PIDs reserved for pods.
Default: 10%
Soft eviction
memory.available
The value must be greater than the hard eviction value of the same parameter, and the eviction grace period (evictionSoftGracePeriod) must be configured accordingly.
Value range: 100 to 1000000
nodefs.available
nodefs.inodesFree
imagefs.available
imagefs.inodesFree
pid.available
Table 2 kube-proxy Item
Value
Modification
Maximum number of connection tracking entries
conntrack-min
To obtain the value, run the following command:
sysctl -w net.nf_conntrack_max
Default: 131072
None
Wait time of a closed TCP connection
conntrack-tcp-timeout-close-wait
sysctl -w net.netfilter.nf_conntrack_tcp_timeout_close_wait
Default: 1h0m0s
None
Table 3 Network components (available only for CCE Turbo clusters) Item
Value
Modification
Node pool ENI pre-binding
enable-node-nic-configuration
Whether to enable ENI pre-binding in a node pool.
Default: false
After network component configuration is disabled in a node pool, the dynamic container ENI pre-binding parameter settings of the node pool are the same as those of cluster-level parameter settings.
Minimum number of ENIs bound to a node in a node pool
nic-minimum-target
Minimum number of container ENIs bound to a node.
The parameter value must be a positive integer. The value 10 indicates that at least 10 container ENIs must be bound to a node. If the number you specified exceeds the container ENI quota of the node, the ENI quota will be used.
Default: 10
Configure these parameters based on the number of pods typically running on most nodes.
Maximum number of ENIs pre-bound to a node in a node pool
nic-maximum-target
After the number of ENIs bound to a node exceeds the nic-maximum-target value, CCE will not proactively pre-bind ENIs.
Checking the upper limit of pre-bound container ENIs is enabled only when the value of this parameter is greater than or equal to the minimum number of container ENIs (nic-minimum-target) bound to a node.
The parameter value must be a positive integer. The value 0 indicates that checking the upper limit of pre-bound container ENIs is disabled. If the number you specified exceeds the container ENI quota of the node, the ENI quota will be used.
Default: 0
Configure these parameters based on the maximum number of pods running on most nodes.
Number of ENIs dynamically pre-bound to a node in a node pool
nic-warm-target
Extra ENIs will be pre-bound after the nic-minimum-target is used up in a pod. The value can only be a number.
When the sum of the nic-warm-target value and the number of ENIs bound to the node is greater than the nic-maximum-target value, CCE will pre-bind the number of ENIs specified by the difference between the nic-maximum-target value and the current number of ENIs bound to the node.
Default: 2
Set the parameter value to the number of pods that can be scaled out instantaneously within 10 seconds on most nodes.
Threshold for reclaiming the ENIs pre-bound to a node in a node pool
nic-max-above-warm-target
Only when the difference between the number of idle ENIs on a node and the nic-warm-target value is greater than the threshold, the pre-bound ENIs will be unbound and reclaimed. The value can only be a number.
- A large value will accelerate pod startup but slow down the unbinding of idle container ENIs and decrease the IP address usage. Exercise caution when performing this operation.
- A small value will speed up the unbinding of idle container ENIs and increase the IP address usage but will slow down pod startup, especially when a large number of pods increase instantaneously.
Default: 2
Set the parameter value to the difference between the number of pods that are frequently scaled on most nodes within minutes and the number of pods that are instantly scaled out on most nodes within 10 seconds.
Table 4 Pod security group in a node pool (available only for CCE Turbo clusters) Item
Value
Modification
Default security group used by pods in a node pool
security_groups_for_nodepool
You can enter the security group ID. If this parameter is not configured, the default security group of the cluster container network will be used, and a maximum of five security group IDs that are separated by semicolons (;) can be specified at a time.
The priority of the security group is lower than that of the security group configured for SecurityGroups.
None
None
Table 5 Docker (available only for node pools that use Docker) Item
Value
Modification
Container umask
native-umask
The default value normal indicates that the umask value of the started container is 0022.
Default: normal
The parameter value cannot be changed.
Available data space for a single container
docker-base-size
Maximum data space that can be used by each container.
Default: 0
Insecure image source address
insecure-registry
Whether an insecure image source address can be used.
false
Maximum size of a container core file
limitcore
Maximum size of a core file in a container. The unit is byte.
If not specified, the value is infinity.
Default: 5368709120
None
Limit on the number of handles in a container
default-ulimit-nofile
Maximum number of handles that can be used in a container.
Default: {soft}:{hard}
The value cannot exceed the value of the kernel parameter nr_open and cannot be a negative number.
You can run the following command to obtain the kernel parameter nr_open:
sysctl -a | grep nr_open
Image pull timeout
image-pull-progress-timeout
If the image fails to be pulled before time outs, the image pull will be canceled.
Default: 1m0s
This parameter is supported in v1.25.3-r0 and later.
Maximum Number of Concurrent Requests for Downloading an Image at a Time
max-concurrent-downloads
This parameter specifies the maximum number of concurrent requests for downloading an image at a time.
Default: 3
Value range: 1 to 20
If this parameter is set to a large value, the network performance of other services on the node may be affected or the disk I/O and CPU usage may increase.
max-size
Maximum size of a container log file to be dumped. When the size of a log file reaches this value, the current log file will be closed and a new log file will be created to continue logging.
Default: 50
If this parameter is set to a small value, important logs may be lost. If this parameter is set to a large value, too much disk space may be occupied.
max-file
Maximum number of log files that can be retained in a container. When the number of existing log files exceeds this value, the earliest log file will be deleted to release space for new log files.
Default: 20
Table 6 containerd (available only for node pools that use containerd) Item
Value
Modification
devmapper-base-size
Default: 0
limitcore
Default: 5368709120
None
Default: 1048576
Image pull timeout
Default: 1m0s
Verification on insure skips
insecure_skip_verify
Whether to skip repository certificate verification.
Default: false
Default: 3
Maximum Container Log Line Size
max-container-log-line-size
Maximum log line size of a container, in the unit of bytes. The log lines exceeding the limit will be split into multiple lines.
Default: 16384
Value range: 1 to 2097152
A larger value will lead to more containerd memory consumption.
- Click OK.
