Using an Existing SFS Turbo File System Through a Static PV
SFS Turbo is a shared file system with high availability and durability. It is suitable for applications that contain massive small files and require low latency, and high IOPS. This section describes how to use an existing SFS Turbo file system to statically create PVs and PVCs for data persistence and sharing in workloads.
- You have created a cluster and installed the CCE Container Storage (Everest) add-on in the cluster.
- To create a cluster using commands, ensure kubectl is used. For details, see Accessing a Cluster Using kubectl.
- You have created an available SFS Turbo file system, and the SFS Turbo file system and the cluster are in the same VPC.
Notes and Constraints
- Multiple PVs can use the same SFS or SFS Turbo file system with the following restrictions:
- Do not mount multiple PVCs or PVs that use the same underlying SFS or SFS Turbo volume to a single pod. Doing so will cause pod startup failures, as not all PVCs can be mounted due to identical volumeHandle value.
- The persistentVolumeReclaimPolicy parameter in the PVs must be set to Retain. Otherwise, when a PV is deleted, the associated underlying volume may be deleted. In this case, other PVs associated with the underlying volume malfunction.
- When the underlying volume is repeatedly used, enable isolation and protection for ReadWriteMany at the application layer to prevent data overwriting and loss.
Using an Existing SFS Turbo File System on the Console
- Statically create a PVC and PV.
- Choose Storage in the navigation pane. In the right pane, click the PVCs tab. Click Create PVC in the upper right corner. In the dialog box displayed, configure PVC parameters.
PVC Type
In this example, select SFS Turbo.
PVC Name
Enter the PVC name, which must be unique in a namespace.
Creation Method
You can create a storage volume or use an existing storage volume to statically create a PVC based on whether a PV has been created.
In this example, select Create new to create both a PV and PVC on the console.
PVa
Select an existing PV in the cluster. For details about how to create a PV, see "Creating a storage volume" in Related Operations.
You do not need to specify this parameter in this example.
SFS Turbob
Click Select SFS Turbo. On the displayed page, select the SFS Turbo file system that meets your requirements and click OK.
Subdirectoryb
Determine whether to use subdirectories to create PVs. Enter the absolute path of a subdirectory, for example, /a/b. Ensure that the subdirectory is available.
PV Nameb
Enter the PV name, which must be unique in the same cluster.
Access Modeb
SFS Turbo volumes support only ReadWriteMany, indicating that a storage volume can be mounted to multiple nodes in read/write mode. For details, see Volume Access Modes.
Reclaim Policyb
Only Retain is available if you do not use subdirectories to create PVs. This indicates that the PV is not deleted when the PVC is deleted. For details, see PV Reclaim Policy. If you choose to use a subdirectory to create a PV, the value of this parameter can be Delete.
Subdirectory Reclaim Policyb
Determine whether to retain subdirectories when a PVC is deleted. This parameter must be used with PV Reclaim Policy and can be configured when PV Reclaim Policy is set to Delete.
- Retain: If a PVC is deleted, the PV will be deleted, but the subdirectories associated with the PV will be retained.
- Delete: After a PVC is deleted, the PV and its associated subdirectories will also be deleted.
Mount Optionsb
Enter the mounting parameter key-value pairs. For details, see Configuring SFS Turbo Mount Options.
a: The parameter is available when Creation Method is set to Use existing.
b: The parameter is available when Creation Method is set to Create new.
- Click Create to create a PVC and a PV.
You can choose Storage in the navigation pane and view the created PVC and PV on the PVCs and PVs tab pages, respectively.
- Create an application.
- Choose Workloads in the navigation pane. In the right pane, click the Deployments tab.
- Click Create Workload in the upper right corner. On the displayed page, click Data Storage in the Container Information area under Container Settings and choose Add Volume > PVC.
Mount and use storage volumes, as shown in Table 1. For details about other parameters, see Workloads.
Table 1 Mounting a storage volume Parameter
PVC
Select an existing SFS Turbo volume.
Mount Path
Enter a mount path, for example, /tmp.
This parameter specifies a container path to which a data volume will be mounted. Do not mount the volume to a system directory such as / or /var/run. This may lead to container errors. Mount the volume to an empty directory. If the directory is not empty, ensure that there are no files that affect container startup. Otherwise, the files will be replaced, leading to container startup failures or workload creation failures.NOTICE:If a volume is mounted to a high-risk directory, use an account with minimum permissions to start the container. Otherwise, high-risk files on the host may be damaged.
Subpath
Enter the subpath of the storage volume and mount a path in the storage volume to the container. In this way, different folders of the same storage volume can be used in a single pod. tmp, for example, indicates that data in the mount path of the container is stored in the tmp folder of the storage volume. If this parameter is left blank, the root path will be used by default.
Permission
- Read-only: You can only read the data in the mounted volumes.
- Read-write: You can modify the data volumes mounted to the path. Newly written data will not be migrated if the container is migrated, which may cause data loss.
In this example, the disk is mounted to the /data path of the container. The container data generated in this path is stored in the SFS Turbo file system.
- After the configuration, click Create Workload.
After the workload is created, the data in the container mount directory will be persistently stored. Verify the storage by referring to Verifying Data Persistence and Sharing.
Using an Existing SFS Turbo File System Through kubectl
- Use kubectl to access the cluster.
- Create a PV.
- Create the pv-sfsturbo.yaml file.
Example:
apiVersion: v1 kind: PersistentVolume metadata: annotations: pv.kubernetes.io/provisioned-by: everest-csi-provisioner name: pv-sfsturbo # PV name spec: accessModes: - ReadWriteMany # Access mode. The value must be ReadWriteMany for SFS Turbo. capacity: storage: 500Gi # SFS Turbo volume capacity csi: driver: sfsturbo.csi.everest.io # Dependent storage driver for the mounting fsType: nfs volumeHandle: <your_volume_id> # SFS Turbo volume ID volumeAttributes: everest.io/share-export-location: <your_location> # Shared path of the SFS Turbo volume everest.io/enterprise-project-id: <your_project_id> # Enterprise project ID of the SFS Turbo volume storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner persistentVolumeReclaimPolicy: Retain # Reclaim policy storageClassName: csi-sfsturbo # StorageClass name of the SFS Turbo file system mountOptions: [] # Mount options
Table 2 Key parameters Parameter
Mandatory
volumeHandle
Yes
ID of an SFS Turbo file system for creating a PV.
How to obtain: Log in to the CCE console, choose Service List > Storage > Scalable File Service, and select SFS Turbo. In the list, click the name of the target SFS Turbo file system. On the details page, copy the content following ID.
Yes
Shared path of the SFS Turbo volume.
Log in to the CCE console, choose Service List > Storage > Scalable File Service, and select SFS Turbo. You can obtain the shared path of the file system.
No
Enterprise project ID of the SFS Turbo volume.
How to obtain: On the SFS console, choose SFS Turbo in the navigation pane. Click the name of the SFS Turbo file system to interconnect. On the Basic Info tab, find and click the enterprise project to go to the console, and copy the ID.
mountOptions
No
Mount options.
If not specified, the following configurations are used by default. For details, see Configuring SFS Turbo Mount Options.
mountOptions: - vers=3 - timeo=600 - nolock - hard
Yes
A reclaim policy is supported when the cluster version is or later than 1.19.10 and the Everest version is or later than 1.2.9. For details, see PV Reclaim Policy.
Retain: When a PVC is deleted, both the PV and underlying storage resources will be retained. You need to manually delete these resources. After the PVC is deleted, the PV is in the Released state and cannot be bound to a PVC again.
storage
Yes
Requested capacity in the PVC, in Gi.
storageClassName
Yes
The StorageClass name of SFS Turbo volumes is csi-sfsturbo.
- Run the following command to create a PV:
kubectl apply -f pv-sfsturbo.yaml
- Create a PVC.
- Create the pvc-sfsturbo.yaml file.
apiVersion: v1 kind: PersistentVolumeClaim metadata: name: pvc-sfsturbo namespace: default annotations: volume.beta.kubernetes.io/storage-provisioner: everest-csi-provisioner everest.io/enterprise-project-id: <your_project_id> # Enterprise project ID of the SFS Turbo volume spec: accessModes: - ReadWriteMany # The value must be ReadWriteMany for SFS Turbo. resources: requests: storage: 500Gi # SFS Turbo volume capacity. storageClassName: csi-sfsturbo # StorageClass name of the SFS Turbo file system, which must be the same as that of the PV volumeName: pv-sfsturbo # PV name
Table 3 Key parameters Parameter
Mandatory
No
storage
Yes
The value must be the same as the storage size of the existing PV.
storageClassName
Yes
StorageClass name, which must be the same as the StorageClass of the PV in 1.
volumeName
Yes
PV name, which must be the same as the PV name in 1.
- Run the following command to create a PVC:
kubectl apply -f pvc-sfsturbo.yaml
- Create a file named web-demo.yaml. In this example, the SFS Turbo volume is mounted to the /data path.
apiVersion: apps/v1 kind: Deployment metadata: name: web-demo namespace: default spec: replicas: 2 selector: matchLabels: app: web-demo template: metadata: labels: app: web-demo spec: containers: - name: container-1 image: nginx:latest volumeMounts: - name: pvc-sfsturbo-volume # Volume name, which must be the same as the volume name in the volumes field mountPath: /data # Location where the storage volume is mounted imagePullSecrets: - name: default-secret volumes: - name: pvc-sfsturbo-volume # Volume name, which can be customized persistentVolumeClaim: claimName: pvc-sfsturbo # Name of the created PVC
- Run the following command to create a workload to which the SFS Turbo volume is mounted:
kubectl apply -f web-demo.yaml
After the workload is created, you can try Verifying Data Persistence and Sharing.
Using Subdirectories of an Existing SFS Turbo File System Through kubectl
- Create a PV.
Example:
apiVersion: v1 kind: PersistentVolume metadata: annotations: pv.kubernetes.io/provisioned-by: everest-csi-provisioner everest.io/reclaim-policy: retain-volume-only # When a PVC is deleted, the PV will be deleted but the subdirectories associated with the PV will be retained. This parameter is available only when subdirectories are used and the reclaim policy is Delete. name: pv-sfsturbo # PV name spec: accessModes: - ReadWriteMany # Access mode. The value must be ReadWriteMany for SFS Turbo. capacity: storage: 500Gi # SFS Turbo volume capacity csi: driver: sfsturbo.csi.everest.io # Dependent storage driver for the mounting fsType: nfs volumeHandle: pv-sfsturbo # PV name volumeAttributes: everest.io/share-export-location: <sfsturbo_path>:/<absolute_path> # Shared path and subdirectory of the SFS Turbo file system everest.io/enterprise-project-id: <your_project_id> # Enterprise project ID of the SFS Turbo volume storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner everest.io/volume-as: absolute-path # An SFS Turbo subdirectory is used. everest.io/sfsturbo-share-id: <sfsturbo_id> # SFS Turbo ID persistentVolumeReclaimPolicy: Retain # Reclaim policy, which can be set to Delete when subdirectories are automatically created storageClassName: csi-sfsturbo # StorageClass name of the SFS Turbo file system mountOptions: [] # Mount options
Table 4 Key parameters Parameter
Mandatory
volumeHandle
Yes
PV name when an SFS Turbo subdirectory is used to create the PV.
Yes
Shared path of the SFS Turbo subdirectory.
Format:
{sfsturbo_path}:/{absolute_path}
How to obtain:
No
mountOptions
No
Mount options.
Yes
Delete: This parameter can be configured when subdirectories are automatically created, indicating that the PV is deleted when a PVC is deleted.
No
Whether to retain subdirectories when deleting a PVC. This parameter must be used with PV Reclaim Policy. This parameter is available only when the PV reclaim policy is Delete. Options:
- retain-volume-only: If a PVC is deleted, the PV will be deleted, but the subdirectories associated with the PV will be retained.
- delete: After a PVC is deleted, the PV and its associated subdirectories will also be deleted.
When a subdirectory is deleted, only the absolute path of the subdirectory configured in the PVC will be deleted. The upper-layer directory will not be deleted.
Yes
The value is fixed at absolute-path, indicating that a dynamically created SFS Turbo subdirectory is used.
Ensure Everest of v2.3.23 or later has been installed in the cluster.
Yes
storage
Yes
Requested capacity in the PVC, in Gi. If a subdirectory is used, this parameter serves no purpose other than for verification and must have a non-empty, non-zero value.
storageClassName
Yes
- Create a PVC.
Table 5 Key parameters Parameter
Mandatory
No
storage
Yes
storageClassName
Yes
volumeName
Yes
- View the deployed application and files.
- Run the following command to view the created pod:
kubectl get pod | grep web-demo
Expected output:web-demo-846b489584-mjhm9 1/1 Running 0 46s web-demo-846b489584-wvv5s 1/1 Running 0 46s
- Run the following commands in sequence to view the files in the /data path of the pods:
kubectl exec web-demo-846b489584-mjhm9 -- ls /data kubectl exec web-demo-846b489584-wvv5s -- ls /data
If no result is returned for both pods, no file exists in the /data path.
- Run the following command to create a file named static in the /data path:
kubectl exec web-demo-846b489584-mjhm9 -- touch /data/static
- Run the following command to check the files in the /data path:
Expected output:
static
- Verify data persistence.
- Run the following command to delete the pod named web-demo-846b489584-mjhm9:
kubectl delete pod web-demo-846b489584-mjhm9
Expected output:
pod "web-demo-846b489584-mjhm9" deleted
After the deletion, the Deployment controller automatically creates a replica.
The expected output is as follows, in which web-demo-846b489584-d4d4j is the newly created pod:web-demo-846b489584-d4d4j 1/1 Running 0 110s web-demo-846b489584-wvv5s 1/1 Running 0 7m50s
- Run the following command to check whether the files in the /data path of the new pod have been modified:
kubectl exec web-demo-846b489584-d4d4j -- ls /data
Expected output:
static
The static file is retained, indicating that the data in the file system can be stored persistently.
- Verify data sharing.
Expected output:web-demo-846b489584-d4d4j 1/1 Running 0 7m web-demo-846b489584-wvv5s 1/1 Running 0 13m
- Run the following command to create a file named share in the /data path of either pod: In this example, select the pod named web-demo-846b489584-d4d4j.
kubectl exec web-demo-846b489584-d4d4j -- touch /data/share
Check the files in the /data path of the pod.kubectl exec web-demo-846b489584-d4d4j -- ls /data
Expected output:
share static
- Check whether the share file exists in the /data path of another pod (web-demo-846b489584-wvv5s) as well to verify data sharing.
Expected output:
share static
After you create a file in the /data path of a pod, if the file is also created in the /data path of the other pod, the two pods share the same volume.
Related Operations
Operation |
Description |
Procedure |
Creating a storage volume (PV) |
Create a PV on the CCE console. |
Expanding the capacity of an SFS Turbo volume |
Quickly expand the capacity of a mounted SFS Turbo volume on the CCE console. |
Viewing events |
View event names, event types, number of occurrences, Kubernetes events, first occurrence time, and last occurrence time of the PVC or PV. |
Viewing a YAML file |
View, copy, or download the YAML file of a PVC or PV. |
