containerd.sock
Check Items
Check whether the containerd.sock file is on the node. This file affects the startup of container runtime in the Euler OS.
Solution
Scenario: The Docker used by the node is the customized Euler-docker.
  1. Log in to the node.
  2. Run the rpm -qa | grep docker | grep euleros command. If the command output is not empty, the Docker used on the node is Euler-docker.
  3. Run the stat /run/containerd/containerd.sock command. If the file exists, Docker startup will fail.
  4. Run the rm -rf /run/containerd/containerd.sock command and perform the cluster upgrade check again.
