Node Disks
Check Items
Check the following items:
  • Check whether the key data disks on the node meet the upgrade requirements.
  • Check whether the /tmp directory has 500 MB available space.
Solution
During the node upgrade, the key disks store the upgrade component package, and the /tmp directory stores temporary files.
  • Scenario 1: Master node disks fail to meet the upgrade requirements.
    Contact technical support.
  • Scenario 2: Worker node disks fail to meet the upgrade requirements.
    Check the usage of each key disk. After ensuring that the available space meets the requirements, check again.
    • Disk partition of Docker: at least 1 GB of available space
      df -h /var/lib/docker
    • Disk partition of containerd: at least 1 GB of available space
      df -h /var/lib/containerd
    • Disk partition of kubelet: at least 1 GB of available space
      df -h /mnt/paas/kubernetes/kubelet
    • System disk: at least 2 GB of available space
      df -h /
  • Scenario 3: The available space of the /tmp directory on worker nodes is insufficient.
    Run the following command to check the usage of the file system where the /tmp directory is located. Ensure that the space is greater than 500 MB and check again.
    df -h /tmp
