Comparison Between Cluster Types
Comparison
CCE provides different types of clusters for you to select. The following table lists the differences between them.
Category
Subcategory
CCE Standard
CCE Turbo
Positioning
Standard clusters that provide highly reliable and secure containers for commercial use
Next-generation clusters designed for Cloud Native 2.0, with accelerated compute, networking, and scheduling
Application scenario
For users who expect to use container clusters to manage applications, obtain elastic compute resources, and enable simplified management on compute, network, and storage resources
For users who have higher requirements on performance, resource utilization, and full-scenario coverage
Specification difference
Network model
Cloud native 1.0 networks: for scenarios where requirements on performance are not high and there are not so many containers
  • Tunnel network
  • Virtual Private Cloud (VPC) network
Cloud Native 2.0 networks: for scenarios where requirements on performance are high and there are many containers
Max networking scale: 2,000 nodes
hostPort
Supported
Not supported
Network performance
The container network is overlaid with the VPC network, causing certain performance loss.
The VPC network and container network are flattened into one for zero performance loss.
Network isolation
  • Tunnel network model: network policies supported for communications within a cluster
  • VPC network model: isolation not supported
Pods can be associated with security groups for isolation. This isolation policy, based on security groups, ensures consistent security isolation both within and outside of a cluster.
Container resource isolation
cgroups are used to isolate common containers.
  • VM-level isolation is supported for secure containers that run only on physical machines.
  • cgroups are used to isolate common containers.
Edge infrastructure management
Not supported
Management of CloudPond edge sites
