Scheduling Policies (Affinity/Anti-affinity)
Kubernetes supports node affinity and pod affinity/anti-affinity. You can configure custom rules to achieve affinity and anti-affinity scheduling. For example, you can deploy frontend pods and backend pods together, deploy the same type of applications on a specific node, or deploy different applications on different nodes.
Kubernetes affinity applies to nodes and pods.
- nodeAffinity: similar to pod nodeSelector, and they both schedule pods only to the nodes with specified labels. The difference between nodeAffinity and nodeSelector lies in that nodeAffinity features stronger expression than nodeSelector and allows you to specify preferentially selected soft constraints. The two types of node affinity are as follows:
- requiredDuringSchedulingIgnoredDuringExecution: hard constraint that must be met. The scheduler can perform scheduling only when the rule is met. This function is similar to nodeSelector, but it features stronger syntax expression. For details, see Node Affinity (nodeAffinity).
- preferredDuringSchedulingIgnoredDuringExecution: soft constraint that is met as much as possible. The scheduler attempts to find the node that meets the rule. If no matching node is found, the scheduler still schedules the pod. For details, see Node Preference Rules.
- Workload Affinity (podAffinity)/Workload Anti-affinity (podAntiAffinity): The nodes to which a pod can be scheduled are determined based on the label of the pod running on a node, but not the label of the node. Similar to node affinity, workload affinity and anti-affinity are also of requiredDuringSchedulingIgnoredDuringExecution and preferredDuringSchedulingIgnoredDuringExecution types.
Workload affinity and anti-affinity require a certain amount of computing time, which significantly slows down scheduling in large-scale clusters. Do not enable workload affinity and anti-affinity in a cluster that contains hundreds of nodes.
You can create the preceding affinity policies on the console. For details, see Configuring Load Affinity on the Console or Configuring Node Affinity on the Console.
- When creating a workload, click Scheduling in the Advanced Settings area. For details about how to create a workload, see Creating a Workload.
- Select a load affinity scheduling policy.
- Not configured: No load affinity policy is configured.
- Multi-AZ deployment preferred: Workload pods are preferentially scheduled to nodes in different AZs through pod anti-affinity.
- Forcible multi-AZ deployment: Workload pods are forcibly scheduled to different AZs and different nodes through pod anti-affinity. When this scheduling policy is used, if there are fewer nodes than pods or node resources are insufficient, the extra pods will fail to run.
- Custom policies: allow flexible scheduling of workload pods based on pod labels. For details about the supported scheduling policies, see Table 1. Select a proper policy type and click
to add a policy. For details about the parameters, see Table 2.
Table 1 Load affinity policies Policy
Type
Workload affinity
Required
Hard constraint, which corresponds to requiredDuringSchedulingIgnoredDuringExecution in YAML for specifying the conditions that must be met.
Select pods that require affinity by label. If such pods already run on a node in the topology key, the scheduler will forcibly schedule the created pods to that topology key.
NOTE:If multiple affinity rules are configured, multiple labels will be used to filter pods that require affinity, and the newly created pods must be affinity with all pods that meet the label filtering conditions. In this way, all pods that meet the label filtering conditions locate in the same topology key for scheduling.
Preferred
Soft constraint, which corresponds to preferredDuringSchedulingIgnoredDuringExecution in YAML for specifying the conditions that need to be met as much as possible.
Select pods that require affinity by label. If such pods already run on a node in the topology key, the scheduler will preferentially schedule the created pods to that topology key.
NOTE:If multiple affinity rules are configured, multiple labels will be used to filter pods that require affinity, and the newly created pods will be preferentially to be affinity with multiple pods that meet the label filtering conditions. However, even if no pod meets the label filter conditions, a topology key will be selected for scheduling.
Workload anti-affinity
Required
Select one or more pods that require anti-affinity by label. If such pods already run on a node in the topology key, the scheduler will not schedule the created pods to that topology key.
NOTE:If multiple anti-affinity rules are configured, multiple labels will be used to filter pods that require anti-affinity, and the newly created pods must be anti-affinity with all pods that meet the label filtering conditions. In this way, all the topology keys where the pods that meet the label filtering conditions locate will not be scheduled.
Preferred
Select one or more pods that require anti-affinity by label. If such pods already run on a node in the topology key, the scheduler will preferentially schedule the created pods to other topology keys.
NOTE:If multiple anti-affinity rules are configured, multiple labels will be used to filter pods that require anti-affinity, and the newly created pods will be preferentially to be anti-affinity with multiple pods that meet the label filtering conditions. However, even if all topology keys involve the pods that require anti-affinity, a topology key will be selected for scheduling.
Table 2 Parameters for configuring load affinity/anti-affinity scheduling policies Parameter
Weight
This parameter is available only in a preferred scheduling policy. The weight ranges from 1 to 100. During scheduling, the scheduler adds the weight to the scores of other priority functions and schedules pods to the node with the largest total score.
Namespace
Namespace for which the scheduling policy takes effect.
Topology Key
A topology key (topologyKey) determines the range of nodes to be scheduled based on node labels. For example, if the node label is kubernetes.io/hostname, the range of nodes is determined by node name. Nodes with different names are in different topology keys. In this case, a topology key contains only one node. If the specified label is kubernetes.io/os, the range of nodes is determined by node OS. Nodes running different OSs belong to different topology keys. In this case, a topology key may contain multiple nodes.
After the node range is determined using the topology key, configure the policy for scheduling, including the label key, operator, and label value. The minimum unit for scheduling is a topology key. For example, if a node in a topology key meets the load affinity policy, all nodes in the topology key can be scheduled.
Label Key
When configuring a workload affinity or anti-affinity policy, enter the workload label to be matched.
Both default labels and custom labels are supported.
Operator
The following operators are supported:
- In: The label of the affinity or anti-affinity object is in the label value list (values field).
- NotIn: The label of the affinity or anti-affinity object is not in the label value list (values field).
- Exists: The affinity or anti-affinity object has a specified label key.
- DoesNotExist: The affinity or anti-affinity object does not have a specified label key.
Label Value
When configuring a workload affinity or anti-affinity policy, enter the value of the workload label.
- After the scheduling policy is added, click Create Workload.
- Select a node affinity scheduling policy.
- Not configured: No node affinity policy is configured.
- Node Affinity: Specify the nodes where workload pods are to be deployed. If no nodes are specified, the pods will be randomly scheduled according to the default cluster scheduling policy.
- Specified Node Pool Scheduling: Specify the node pools where workload pods are to be deployed. If no node pools are specified, the pods will be randomly scheduled according to the default cluster scheduling policy.
- Custom policies: allow flexible scheduling of workload pods based on node labels. For details about the supported scheduling policies, see Table 3. Select a proper policy type and click
to add a policy. For details about the parameters, see Table 4. You can also click Specify Node or Specify AZ to quickly select a node or AZ on the console for scheduling.
Specifying a node or AZ is also implemented through labels. The console frees you from manually entering node labels. The kubernetes.io/hostname label is used when you specify a node, and the failure-domain.beta.kubernetes.io/zone label is used when you specify an AZ.
Table 3 Node affinity settings Parameter
Required
Hard constraint, which corresponds to requiredDuringSchedulingIgnoredDuringExecution for specifying the conditions that must be met.
If multiple rules that must be met are added, scheduling will be performed when only one rule is met.
Preferred
Soft constraint, which corresponds to preferredDuringSchedulingIgnoredDuringExecution for specifying the conditions that need to be met as much as possible.
If multiple rules that are preferentially met are added, scheduling will be performed even if one or none of the rules is met.
Table 4 Parameters for configuring node affinity scheduling policies Parameter
Label Key
When configuring node affinity, enter the node label to be matched.
Operator
- Gt: (available only for node affinity) The label value of the scheduled node is greater than the list value (string comparison).
- Lt: (available only for node affinity) The label value of the scheduled node is less than the list value (string comparison).
Label Value
When configuring node affinity, enter the value of the node label.
Workload node affinity rules are implemented using node labels. When a node is created in a CCE cluster, certain labels are automatically added. You can run the kubectl describe node command to view the labels. The following is an example:
$ kubectl describe node 192.168.0.212 Name: 192.168.0.212 Roles: <none> Labels: beta.kubernetes.io/arch=amd64 beta.kubernetes.io/os=linux failure-domain.beta.kubernetes.io/is-baremetal=false failure-domain.beta.kubernetes.io/region=****** failure-domain.beta.kubernetes.io/zone=****** kubernetes.io/arch=amd64 kubernetes.io/availablezone=****** kubernetes.io/eniquota=12 kubernetes.io/hostname=192.168.0.212 kubernetes.io/os=linux node.kubernetes.io/subnetid=fd43acad-33e7-48b2-a85a-24833f362e0e os.architecture=amd64 os.name=EulerOS_2.0_SP5 os.version=3.10.0-862.14.1.5.h328.eulerosv2r7.x86_64
In workload scheduling, common node labels are as follows:
- failure-domain.beta.kubernetes.io/region: region where the node is located
- failure-domain.beta.kubernetes.io/zone: availability zone to which the node belongs
- kubernetes.io/hostname: hostname of the node
Kubernetes provides the nodeSelector field. When creating a workload, you can set this field to specify that the pod can be deployed only on a node with the specific label. The following example shows how to use a nodeSelector to deploy the pod only on the node with the gpu=true label.
apiVersion: v1 kind: Pod metadata: name: nginx spec: nodeSelector: # Node selection. A pod is created on a node only when the node meets gpu=true. gpu: true ...
- requiredDuringSchedulingIgnoredDuringExecution: Kubernetes cannot schedule the pod unless the rule is met.
- PreferredDuringSchedulingIgnoredDuringExecution: Kubernetes tries to find a node that meets the rule. If a matching node is not available, Kubernetes still schedules the pod.
In these two types of node affinity, requiredDuringScheduling or preferredDuringScheduling indicates that the pod can be scheduled to a node only when all the defined rules are met (required). IgnoredDuringExecution indicates that any changes to the node label after Kubernetes schedules the pod will not affect the pod's running or cause it to be rescheduled. However, if kubelet on the node is restarted, kubelet will recheck the node affinity rule, and the pod will still be scheduled to another node.
The following is an example of configuring node affinity:
apiVersion: apps/v1 kind: Deployment metadata: name: gpu labels: app: gpu spec: selector: matchLabels: app: gpu replicas: 3 template: metadata: labels: app: gpu spec: containers: - image: nginx:alpine name: gpu resources: requests: cpu: 100m memory: 200Mi limits: cpu: 100m memory: 200Mi imagePullSecrets: - name: default-secret affinity: nodeAffinity: requiredDuringSchedulingIgnoredDuringExecution: nodeSelectorTerms: - matchExpressions: - key: gpu operator: In values: - "true"
In this example, the scheduled node must contain a label with the key named gpu. The value of operator is to In, indicating that the label value must be in the values list. That is, the key value of the gpu label of the node is true. For details about other values of operator, see Operator Values. Note that there is no such thing as nodeAntiAffinity because operators NotIn and DoesNotExist provide the same function.
The following describes how to check whether the rule takes effect. Assume that a cluster has three nodes.
$ kubectl get node NAME STATUS ROLES AGE VERSION 192.168.0.212 Ready <none> 13m v1.15.6-r1-20.3.0.2.B001-15.30.2 192.168.0.94 Ready <none> 13m v1.15.6-r1-20.3.0.2.B001-15.30.2 192.168.0.97 Ready <none> 13m v1.15.6-r1-20.3.0.2.B001-15.30.2
Add the gpu=true label to the 192.168.0.212 node.
$ kubectl label node 192.168.0.212 gpu=true node/192.168.0.212 labeled $ kubectl get node -L gpu NAME STATUS ROLES AGE VERSION GPU 192.168.0.212 Ready <none> 13m v1.15.6-r1-20.3.0.2.B001-15.30.2 true 192.168.0.94 Ready <none> 13m v1.15.6-r1-20.3.0.2.B001-15.30.2 192.168.0.97 Ready <none> 13m v1.15.6-r1-20.3.0.2.B001-15.30.2
Create the Deployment. You can find that all pods are deployed on the 192.168.0.212 node.
$ kubectl create -f affinity.yaml deployment.apps/gpu created $ kubectl get pod -o wide NAME READY STATUS RESTARTS AGE IP NODE gpu-6df65c44cf-42xw4 1/1 Running 0 15s 172.16.0.37 192.168.0.212 gpu-6df65c44cf-jzjvs 1/1 Running 0 15s 172.16.0.36 192.168.0.212 gpu-6df65c44cf-zv5cl 1/1 Running 0 15s 172.16.0.38 192.168.0.212
The preceding requiredDuringSchedulingIgnoredDuringExecution rule is a hard selection rule. There is another type of selection rule, that is, preferredDuringSchedulingIgnoredDuringExecution. It is used to specify which nodes are preferred during scheduling.
To achieve this effect, add a node attached with SAS disks to the cluster, add the DISK=SAS label to the node, and add the DISK=SSD label to the other three nodes.
$ kubectl get node -L DISK,gpu NAME STATUS ROLES AGE VERSION DISK GPU 192.168.0.100 Ready <none> 7h23m v1.15.6-r1-20.3.0.2.B001-15.30.2 SAS 192.168.0.212 Ready <none> 8h v1.15.6-r1-20.3.0.2.B001-15.30.2 SSD true 192.168.0.94 Ready <none> 8h v1.15.6-r1-20.3.0.2.B001-15.30.2 SSD 192.168.0.97 Ready <none> 8h v1.15.6-r1-20.3.0.2.B001-15.30.2 SSD
Define a Deployment. Use the preferredDuringSchedulingIgnoredDuringExecution rule to set the weight of nodes with the SSD disk installed as 80 and nodes with the gpu=true label as 20. In this way, pods are preferentially deployed on the nodes with the SSD disk installed.
apiVersion: apps/v1 kind: Deployment metadata: name: gpu labels: app: gpu spec: selector: matchLabels: app: gpu replicas: 10 template: metadata: labels: app: gpu spec: containers: - image: nginx:alpine name: gpu resources: requests: cpu: 100m memory: 200Mi limits: cpu: 100m memory: 200Mi imagePullSecrets: - name: default-secret affinity: nodeAffinity: preferredDuringSchedulingIgnoredDuringExecution: - weight: 80 preference: matchExpressions: - key: DISK operator: In values: - SSD - weight: 20 preference: matchExpressions: - key: gpu operator: In values: - "true"
After the deployment, there are five pods deployed on the node 192.168.0.212 (label: DISK=SSD and GPU=true), three pods deployed on the node 192.168.0.97 (label: DISK=SSD), and two pods deployed on the node 192.168.0.100 (label: DISK=SAS).
From the preceding output, you can find that no pods of the Deployment are scheduled to node 192.168.0.94 (label: DISK=SSD). This is because the node already has many pods on it and its resource usage is high. This also indicates that the preferredDuringSchedulingIgnoredDuringExecution rule defines a preference rather than a hard requirement.
$ kubectl create -f affinity2.yaml deployment.apps/gpu created $ kubectl get po -o wide NAME READY STATUS RESTARTS AGE IP NODE gpu-585455d466-5bmcz 1/1 Running 0 2m29s 172.16.0.44 192.168.0.212 gpu-585455d466-cg2l6 1/1 Running 0 2m29s 172.16.0.63 192.168.0.97 gpu-585455d466-f2bt2 1/1 Running 0 2m29s 172.16.0.79 192.168.0.100 gpu-585455d466-hdb5n 1/1 Running 0 2m29s 172.16.0.42 192.168.0.212 gpu-585455d466-hkgvz 1/1 Running 0 2m29s 172.16.0.43 192.168.0.212 gpu-585455d466-mngvn 1/1 Running 0 2m29s 172.16.0.48 192.168.0.97 gpu-585455d466-s26qs 1/1 Running 0 2m29s 172.16.0.62 192.168.0.97 gpu-585455d466-sxtzm 1/1 Running 0 2m29s 172.16.0.45 192.168.0.212 gpu-585455d466-t56cm 1/1 Running 0 2m29s 172.16.0.64 192.168.0.100 gpu-585455d466-t5w5x 1/1 Running 0 2m29s 172.16.0.41 192.168.0.212
In the preceding example, the node scheduling priority is as follows. Nodes with both SSD and gpu=true labels have the highest priority. Nodes with the SSD label but no gpu=true label have the second priority (weight: 80). Nodes with the gpu=true label but no SSD label have the third priority. Nodes without any of these two labels have the lowest priority.
Node affinity rules affect only the affinity between pods and nodes. Kubernetes also supports configuring inter-pod affinity rules. For example, the frontend and backend of an application can be deployed together on one node to reduce access latency. There are also two types of inter-pod affinity rules: requiredDuringSchedulingIgnoredDuringExecution and preferredDuringSchedulingIgnoredDuringExecution.
For workload affinity, topologyKey cannot be left blank when requiredDuringSchedulingIgnoredDuringExecution and preferredDuringSchedulingIgnoredDuringExecution are used.
Assume that the backend of an application has been created and has the app=backend label.
$ kubectl get po -o wide NAME READY STATUS RESTARTS AGE IP NODE backend-658f6cb858-dlrz8 1/1 Running 0 2m36s 172.16.0.67 192.168.0.100
You can configure the following pod affinity rule to deploy the frontend pods of the application to the same node as the backend pods.
apiVersion: apps/v1 kind: Deployment metadata: name: frontend labels: app: frontend spec: selector: matchLabels: app: frontend replicas: 3 template: metadata: labels: app: frontend spec: containers: - image: nginx:alpine name: frontend resources: requests: cpu: 100m memory: 200Mi limits: cpu: 100m memory: 200Mi imagePullSecrets: - name: default-secret affinity: podAffinity: requiredDuringSchedulingIgnoredDuringExecution: - topologyKey: kubernetes.io/hostname labelSelector: matchExpressions: - key: app operator: In values: - backend
Deploy the frontend and you can find that the frontend is deployed on the same node as the backend.
$ kubectl create -f affinity3.yaml deployment.apps/frontend created $ kubectl get po -o wide NAME READY STATUS RESTARTS AGE IP NODE backend-658f6cb858-dlrz8 1/1 Running 0 5m38s 172.16.0.67 192.168.0.100 frontend-67ff9b7b97-dsqzn 1/1 Running 0 6s 172.16.0.70 192.168.0.100 frontend-67ff9b7b97-hxm5t 1/1 Running 0 6s 172.16.0.71 192.168.0.100 frontend-67ff9b7b97-z8pdb 1/1 Running 0 6s 172.16.0.72 192.168.0.100
The topologyKey field is used to divide topology keys to specify the selection range. If the label keys and values of nodes are the same, the nodes are considered to be in the same topology key. Then, the contents defined in the following rules are selected. The effect of topologyKey is not fully demonstrated in the preceding example because all the nodes have the kubernetes.io/hostname label, that is, all the nodes are within the range.
To see how topologyKey works, assume that the backend of the application has two pods, which are running on different nodes.
$ kubectl get po -o wide NAME READY STATUS RESTARTS AGE IP NODE backend-658f6cb858-5bpd6 1/1 Running 0 23m 172.16.0.40 192.168.0.97 backend-658f6cb858-dlrz8 1/1 Running 0 2m36s 172.16.0.67 192.168.0.100
Add the prefer=true label to nodes 192.168.0.97 and 192.168.0.94.
$ kubectl label node 192.168.0.97 prefer=true node/192.168.0.97 labeled $ kubectl label node 192.168.0.94 prefer=true node/192.168.0.94 labeled $ kubectl get node -L prefer NAME STATUS ROLES AGE VERSION PREFER 192.168.0.100 Ready <none> 44m v1.15.6-r1-20.3.0.2.B001-15.30.2 192.168.0.212 Ready <none> 91m v1.15.6-r1-20.3.0.2.B001-15.30.2 192.168.0.94 Ready <none> 91m v1.15.6-r1-20.3.0.2.B001-15.30.2 true 192.168.0.97 Ready <none> 91m v1.15.6-r1-20.3.0.2.B001-15.30.2 true
If the topologyKey of podAffinity is set to prefer, the node topology keys are divided as shown in Figure 2.
affinity:
podAffinity:
- topologyKey: prefer
labelSelector:
matchExpressions:
- key: app
operator: In
values:
- backend
During scheduling, node topology keys are divided based on the prefer label. In this example, 192.168.0.97 and 192.168.0.94 are divided into the same topology key. If a pod with the app=backend label runs in the topology key, even if not all nodes in the topology key run the pod with the app=backend label (in this example, only the 192.168.0.97 node has such a pod), frontend is also deployed in this topology key (192.168.0.97 or 192.168.0.94).
$ kubectl create -f affinity3.yaml deployment.apps/frontend created $ kubectl get po -o wide NAME READY STATUS RESTARTS AGE IP NODE backend-658f6cb858-5bpd6 1/1 Running 0 26m 172.16.0.40 192.168.0.97 backend-658f6cb858-dlrz8 1/1 Running 0 5m38s 172.16.0.67 192.168.0.100 frontend-67ff9b7b97-dsqzn 1/1 Running 0 6s 172.16.0.70 192.168.0.97 frontend-67ff9b7b97-hxm5t 1/1 Running 0 6s 172.16.0.71 192.168.0.97 frontend-67ff9b7b97-z8pdb 1/1 Running 0 6s 172.16.0.72 192.168.0.97
Workload Anti-Affinity (podAntiAffinity)
Unlike the scenarios in which pods are preferred to be scheduled onto the same node, sometimes, it could be the exact opposite. For example, if certain pods are deployed together, they will affect the performance.
For workload anti-affinity, when requiredDuringSchedulingIgnoredDuringExecution is used, the default access controller LimitPodHardAntiAffinityTopology of Kubernetes requires that topologyKey can only be kubernetes.io/hostname. To use other custom topology logic, modify or disable the access controller.
The following is an example of defining an anti-affinity rule. This rule divides node topology keys by the kubernetes.io/hostname label. If a pod with the app=frontend label already exists on a node in the topology key, pods with the same label cannot be scheduled to other nodes in the topology key.
apiVersion: apps/v1 kind: Deployment metadata: name: frontend labels: app: frontend spec: selector: matchLabels: app: frontend replicas: 5 template: metadata: labels: app: frontend spec: containers: - image: nginx:alpine name: frontend resources: requests: cpu: 100m memory: 200Mi limits: cpu: 100m memory: 200Mi imagePullSecrets: - name: default-secret affinity: podAntiAffinity: requiredDuringSchedulingIgnoredDuringExecution: - topologyKey: kubernetes.io/hostname # Topology key of the node labelSelector: # Pod label matching rule matchExpressions: - key: app operator: In values: - frontend
Create an anti-affinity rule and view the deployment result. In the example, node topology keys are divided by the kubernetes.io/hostname label. The label values of nodes with the kubernetes.io/hostname label are different, so there is only one node in a topology key. If a topology key contains only one node where a frontend pod already exists, pods with the same label will not be scheduled to that topology key. In this example, there are only four nodes. Therefore, there is one pod which is in the Pending state and cannot be scheduled.
$ kubectl create -f affinity4.yaml deployment.apps/frontend created $ kubectl get po -o wide NAME READY STATUS RESTARTS AGE IP NODE frontend-6f686d8d87-8dlsc 1/1 Running 0 18s 172.16.0.76 192.168.0.100 frontend-6f686d8d87-d6l8p 0/1 Pending 0 18s <none> <none> frontend-6f686d8d87-hgcq2 1/1 Running 0 18s 172.16.0.54 192.168.0.97 frontend-6f686d8d87-q7cfq 1/1 Running 0 18s 172.16.0.47 192.168.0.212 frontend-6f686d8d87-xl8hx 1/1 Running 0 18s 172.16.0.23 192.168.0.94
Operator Values
You can use the operator field to set the logical relationship of the usage rule. The value of operator can be:
