Help Center/
Cloud Container Engine/
User Guide (ME-Abu Dhabi Region)/
Workloads/
Logging In to a Container
If you encounter unexpected problems when using a container, you can log in to the container to debug it.
Notes and Constraints
- When kubectl is used in CloudShell, permissions are determined by the logged-in user.
- When using CloudShell to access a CCE cluster or container, you can open up to 15 instances concurrently.
- The kubectl certificate in CloudShell is valid for one day. You can reset its validity period by accessing CloudShell through the CCE console.
Using kubectl
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Run the following command to view the created pod:
kubectl get pod
The example output is as follows:NAME READY STATUS RESTARTS AGE nginx-59d89cb66f-mhljr 1/1 Running 0 11m
- Query the container name in the pod.
kubectl get po nginx-59d89cb66f-mhljr -o jsonpath='{range .spec.containers[*]}{.name}{end}{"\n"}'
The example output is as follows:container-1
- Run the following command to log in to the container-1 container in the nginx-59d89cb66f-mhljr pod:
kubectl exec -it nginx-59d89cb66f-mhljr -c container-1 -- /bin/sh
- To exit the container, run the exit command.
Parent topic: Workloads
