Updated on 2025-11-24 GMT+08:00
How Do I View My Backup Data?
You can check your backup data in the following ways:
You cannot check the data that is being backed up on the CBR console.
Cloud Server Backups
  1. Create an image from a server backup. For details, see Creating an Image from a Cloud Server Backup.
  2. Use the image to create a server. For details, see section "Creating an ECS from an Image" in the Image Management Service User Guide.
  3. Log in to the server to view the data.
Disk Backups
  1. Use the disk backup to create a disk. For details, see Creating a Disk from a Cloud Disk Backup.
  2. Attach the created disk to the new server. For details, see Section "Attaching a Non-shared Disk" in the Elastic Volume Service User Guide or Section "Attaching a Shared Disk" in the Elastic Volume Service User Guide.
SFS Turbo Backups
  1. Use the SFS Turbo backup to create a file system. For details, see Creating a File System from an SFS Turbo Backup.
  2. Mount the file system to a server.
    To mount the file system to a server, see section "Mounting an NFS File System to ECSs (Linux)" in the Scalable File Service Getting Started.
