Help Center/ Cloud Backup and Recovery/ User Guide (ME-Abu Dhabi Region)/ FAQs/ Capacity/ Why Does the Used Capacity of a Vault Change Only Slightly After I Deleted Unwanted Backups?
Updated on 2025-11-24 GMT+08:00
Symptoms
After unwanted backups are deleted from the vault, the used capacity of the vault decreases by only 1 GB to 2 GB.
Possible Causes
The backup mechanism of CBR:
  • By default, CBR performs a full backup for a resource for the first time and backs up all used data blocks. Subsequent backups are incremental. An incremental backup backs up only the data blocks changed since the last backup.
  • Each incremental backup is a virtual full backup. Correlated data blocks are indexed by using pointers.
  • When you delete a backup, no matter manually or automatically, only data blocks that are not referenced by other backups will be deleted.
Figure 1 Backup mechanism
