Help Center/ Cloud Backup and Recovery/ User Guide (ME-Abu Dhabi Region)/ FAQs/ Restoration/ Can I Use a System Disk Backup to Recover an ECS?
Updated on 2025-11-24 GMT+08:00
Yes. Before the recovery, you need to detach the system disk to be recovered from the ECS.
You can also use a system disk backup to create an EVS disk.
Disks created using system disk backups can only be used as data disks on servers. They cannot be used as system disks.
