Updated on 2025-11-24 GMT+08:00
Viewing CBR Monitoring Data
This section describes the namespaces, metrics, and dimensions of CBR metrics reported to Cloud Eye. You can view the metrics and alarms generated by CBR on the Cloud Eye console or by calling APIs.
Namespace
SYS.CBR
Metrics
Table 1 CBR metrics
Metric ID
Metric Name
Value Range
Unit
Conversion Rule
Dimension
Monitoring Period (Raw Data)
used_vault_size
Used Vault Size
Used capacity of the vault
≥ 0
GB
1024 (IEC)
Vault
15 min
vault_util
Vault Usage
Capacity usage of the vault
0~100
N/A
Vault
15 min
Dimensions
Key
Value
instance_id
Vault name or ID.
You can obtain the vault name and ID by Querying Vaults.
Viewing Monitoring Statistics
  2. View the monitoring graphs using either of the following methods.
    • Choose Storage > Cloud Backup and Recovery. In the vault list, locate the vault whose monitoring data you want to view and choose More > View Monitoring Data in the Operation column.
    • Choose Management & Deployment > Cloud Eye > Cloud Service Monitoring > Cloud Backup and Recovery. In the vault list, click View Metric in the Operation column of the vault whose monitoring data you want to view.
  3. View the vault monitoring data by metric or monitored duration.
    For more information, see the Cloud Eye User Guide.
