Updated on 2025-11-24 GMT+08:00
Deleting a Policy
You can delete policies if they are no longer needed.
At least one policy has been created.
  1. Log in to the CBR console.
    2. In the upper left corner, click and select a region.
    3. Click and choose Storage > Cloud Backup and Recovery.
  2. In the navigation pane, choose Policies.
  3. Click the Backup Policies tab, locate the row that contains the policy you want to delete, and click Delete.
    Deleting a policy will not delete the backups generated based on the policy. You can manually delete unwanted backups.
  4. Confirm the information and click . After the policy is deleted, the system displays a message in the upper right corner. If the policy does not exist in the policy list anymore, it is deleted successfully.
