Step 2: Associate a Resource with the Vault
If you have already associated servers, file systems, or disks when creating a vault, skip this step.
After a server backup vault, SFS Turbo backup vault, or disk backup vault is created, you can associate servers, file systems, or disks with the vault to back up these resources.
- A vault can be associated with a maximum of 256 resources.
- The servers you plan to associate with a vault must have at least one disk attached.
- The vault and the resources you plan to associate with it must be in the same region.
- The total size of the resources to be associated cannot be greater than the vault capacity.
- Resources can be associated only when they are in the statuses in the table below.
Table 1 Resource statuses available for association Resource Type
Status
Cloud server
Running or Stopped
Cloud disk
Available or In-use
SFS Turbo file system
Available
- Log in to the CBR console.
- In the upper left corner, click
and select a region. - Click
and choose Storage > Cloud Backup and Recovery.
- Locate the target vault and click Associate Server, Associate File System, or Associate Disk.
- In the resource list, select the resources you want to associate with the vault. After resources are selected, they are added to the list of selected resources.
- Click OK. You can view the number of associated resources in the Associated Servers, Associated Disks, or Associated File Systems column.
After a new disk is added to the associated server, the system automatically identifies the new disk and backs up the new disk.
