Updated on 2025-11-24 GMT+08:00
User Permissions
If you need to assign different permissions to employees in your enterprise to access your CBR resources, IAM is a good choice for fine-grained permissions management. IAM provides identity authentication, permissions management, and access control, helping you to control access to your cloud resources.
The system provides two types of permissions by default: user management permissions and resource management permissions.
  • User management permissions refer to the permissions to manage users, user groups, and user group permissions.
  • Resource management permissions refer to the permissions to control operations on cloud service resources.
For details, see System-defined Permissions.
