- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Enhanced Hyperledger Fabric BCS Management
- Best Practices
Developer Guide
- Overview
- Chaincode Development
- Application Development
- Demos
Blockchain Middleware APIs
- Overview
- Chaincode Invoking (OBT)
Chaincode Management
- Obtaining a Token
- Installing a Chaincode
- Instantiating a Chaincode
- Listing Installed Chaincodes
- Querying Version of a Specified Chaincode
- Querying Chaincode Installation Information
- Querying Chaincode Instantiation Information
- Querying an Appchain
- Listing Blocks
- Listing Transactions
- Querying Transaction Quantity
- Listing Block Transactions
- Querying Transaction Details
- Querying Peers
- Querying diskUsage of a Node
- Querying the System-Hosted Certificate Status
- Deleting a Chaincode
- Downloading a Report
- Distributed Identity (OBT)
- Trusted Data Exchange (OBT)
- Appendix
API Reference
- Before You Start
- API Overview
- Examples
- Calling APIs
APIs (Enhanced Hyperledger Fabric)
BCS Management
- Creating a BCS Service
- Querying Creation Status of a BCS Service
- Querying a BCS Service
- Modifying a BCS Service
- Creating Channels
- Querying Channel Information
- Adding Peers to a Channel
- Removing Organizations from a Channel
- Downloading Certificates
- Downloading the SDK Configuration
- Generating a User Certificate
- Unfreezing a User Certificate
- Freezing a User Certificate
- Querying Quotas
- Querying Flavors
- Querying Peer Information
- Querying Asynchronous Operation Results
- Querying the BCS Service List
- Deleting a BCS Service
- Removing a Peer from a Channel
- Deleting a Channel
- BCS Consortium
- BCS Monitoring
BCS Management
- Appendix
- Change History
- SDK Reference
- Billing
Instance Management
Consultation
- How Do I Determine Whether a Blockchain Is Necessary?
- What Underlying Framework Is Used for Huawei Cloud BCS?
- Can BCS Instances Deployed on the Public Cloud Access Blockchain Nodes on Other Clouds?
- What Competitive Advantages Does Huawei Cloud BCS Have?
- In Which Direction and What Capabilities Will Huawei Cloud BCS Develop?
- What Are the Specifications of VMs to Be Purchased for BCS?
- How Do I Get Access to the Partners of Huawei Cloud BCS for More Services?
- What Are the Differences Between Channel Isolation and Privacy Protection?
- How Well Does BCS Perform?
- Does BCS Support Customized Development?
- When Do I Need to Hibernate or Wake an Instance?
Service Usage
- Which Ports of a Security Group Are Opened When I Create a BCS Instance?
- How Do I Check Whether the ICAgent Is Installed for the Cluster?
- What Can I Do If I Can't Open the Blockchain Management Console?
- What Should I Do If My BCS Instance Remains in the Creating State?
- What Should I Do If a Peer Restarts Frequently with the Error Message "PanicDB not exist"?
- What Can I Do If the CPU Usage of a Blockchain Node Reaches 100%?
- Why Can't I Log In to the Blockchain Management Console?
- BCS.4009100: System Error
- How Can I Obtain Private Keys and Certificates for Enhanced Hyperledger Fabric Blockchains?
- Why Does Chaincode Instantiation Fail When I Deploy a Fabric v1.4 Instance Using a v1.19 CCE Cluster?
- Can All Blocks Be Saved As More and More Blocks Are Created?
What Can I Do If I Fail to Purchase a BCS Instance?
- General Checks
Detailed Checks
- CCE Cluster Quota Used Up
- Failed to Create a Cluster
- Failed to Create a PVC
- Cluster Already In Use
- SFS Turbo File System Quota Exceeded
- No EIP Bound
- CCE Is Abnormal
- Cluster Status Is Abnormal
- Subnet Unavailable
- Quick Deployment in Progress
- CCE Status Check Times Out
- Insufficient Master Nodes in the AZ of the CCE Cluster
Abnormal Instance Statuses
- What Can I Do If a BCS Instance Is in the Abnormal State?
- What Can I Do If a BCS Instance Is in the Unknown State?
- What Can I Do If a BCS Instance Is in the EIP abnormal State?
- What Can I Do If a BCS Instance Is in the Frozen or Cluster frozen State?
- What Can I Do If the BCS Instance and the peer-xxx StatefulSet Are Abnormal After an Organization or a Peer Is Added?
- Other Issues
Consultation
- Chaincode Management
- Data Storage to the Blockchain
- Demos and APIs
- O&M and Monitoring
- Consortium Management
- Videos
More Documents
- Managing Enhanced Hyperledger Fabric Instances
BCS FAQs
Instance Management
Consultation
- What Underlying Framework Is Used for BCS?
- What Competitive Advantages Does BCS Have?
- What Are the Specifications of VMs to Be Created for BCS?
Service Usage
- Abnormal Instance Statuses
- Other Issues
Consultation
- Demos and APIs
Instance Management
BCS FAQs
- Change History
- Developer Guide (ME-Abu Dhabi Region)
Functions
BCS provides the following functions to help you quickly deploy blockchains featuring security, high efficiency, and cost-effectiveness.
Instance Deployment
You can create resources when deploying a blockchain system, without a need to prepare resources required by the system in advance.
- The blockchain network configuration and deployment are completed in minutes, instead of days.
- Underlying technological details are masked. You do not need to care about the underlying technology implementation and platform construction.
- You can create consortium or private blockchains.
Instance Management
You can view the running statuses of your BCS instances and perform operations on them, for example, adding organizations, upgrading, and obtaining client configurations.
You can manage chaincodes on the graphical user interface (GUI) throughout the entire chaincode lifecycle, including installation, instantiation, and upgrade.
Block Browser
In the block browser, you can query the block and transaction quantities and details, peer statuses, and performance data for blockchain maintenance.
Ledger Storage
File database (GoLevelDB) and NoSQL (CouchDB) are available for ledger storage.
- File database: Historical transaction data is stored in the blockchain, and status data is stored in LevelDB.
- NoSQL: Transaction and status data are stored in CouchDB.
Consensus Algorithms
BCS supports two consensus algorithms for different scenarios.
- Raft (CFT): A crash fault tolerance (CFT) algorithm that tolerates faults at a maximum of (N – 1)/2 orderers, where N indicates the total number of orderers. It also supports Fabric v2.2.
- FBFT: The fast Byzantine fault tolerance (FBFT) algorithm. It requires 4 to 10 orderers for transaction ordering and tolerates faults at a maximum of (N – 1)/3 orderers, where N indicates the total number of orderers. It also supports Fabric v2.2.
Consortium Member and Organization Management
- A consortium initiator can dynamically invite other tenants to conveniently and quickly set up a consortium blockchain.
- You can dynamically add peer organizations to a BCS instance.
Auto Scaling of Nodes
You can scale nodes as required, without rebooting systems.
Contract Scan
Automatic analysis tools are provided to ensure the smart contract safety from the source. Based on the vulnerabilities and issues commonly found in consortium blockchain smart contracts, the check reports and solutions are generated to help users and developers audit code security, detect risks, and resolve problems.
Privacy Protection
- In each channel, members are assigned different access permissions to certain data, ensuring the data privacy of members within a channel.
- Different channels are also isolated from each other, protecting block data of all members in a channel from other channels.
Application Access
Applications can access blockchain networks using software development kits (SDKs) and RESTful APIs.
- SDK configuration files can be downloaded. After simple configuration, an application can be connected to a blockchain network.
- Applications can invoke chaincodes through RESTful APIs. The policy of multi-organization endorsement is supported.
Monitoring and O&M
BCS connects to the monitoring platform to monitor data and resources in real time and generate alarms and notifications when necessary.
- Automated O&M: BCS actively upgrades the underlying blockchain platform and updates patches to seamlessly integrate with the O&M system.
- Enterprise-grade monitoring: Multi-dimensional monitoring is performed on clusters 24/7, and user-defined alarms can be reported through multiple channels.
