- What's New
- Product Bulletin
- Billing
- Getting Started
User Guide
- Application Service Mesh
- Buying a Service Mesh
- Mesh Management
- Service Management
- Gateway Management
- Grayscale Release
- Mesh Configuration
- Traffic Management
- Security
Best Practices
- Upgrading Data Plane Sidecars Without Service Interruption
- Service Governance for Dubbo-based Applications
- Reserving Source IP Address for Gateway Access
- Creating a Service Mesh with IPv4/IPv6 Dual Stack Enabled
- How Do I Query Application Metrics in AOM?
- Reducing the Agency Permissions of ASM Users
- Istio-ingressgateway HA Configuration
- Service Mesh Cluster
Mesh Management
- Why Cannot I Create a Mesh for My Cluster?
- Why Are Exclusive Nodes Still Exist After Istio Is Uninstalled?
- How Do I Upgrade ICAgent?
- How Do I Enable Namespace Injection for a Cluster?
- How Do I Disable Sidecar Injection for Workloads?
- What Can I Do If A Pod Cannot Be Started Due to Unready Sidecar
- How Do I Handle a Canary Upgrade Failure?
Adding a Service
- What Do I Do If an Added Gateway Does Not Take Effect?
- Why Does It Take a Long Time to Start the Demo Application in Experiencing Service Mesh in One Click?
- Why Cannot I Access the page of the Demo Application After It Is Successfully Deployed?
- Why Cannot I Select the Corresponding Service When Adding a Route?
- How Do I Inject a Sidecar for the Pod Created Using a Job or CronJob?
- Performing Grayscale Release
Managing Traffic
- Why Are the Created Clusters, Namespaces, and Applications Not Displayed on the Traffic Management Page?
- How Do I Change the Resource Requests of the istio-proxy Container?
- Does ASM Support HTTP/1.0?
- How Can I Block Access from Some IP Address Ranges or Ports for a Service Mesh?
- How Do I Configure max_concurrent_streams for a Gateway?
- How Do I Fix Compatibility Issues Between Istio CNI and Init Containers?
Monitoring Traffic
- Why Cannot I View Traffic Monitoring Data Immediately After a Pod Is Started?
- Why Are the Latency Statistics on the Dashboard Page Inaccurate?
- Why Is the Traffic Ratio Inconsistent with That in the Traffic Monitoring Chart?
- Why Can't I Find Certain Error Requests in Tracing?
- Why Cannot I Find My Service in the Traffic Monitoring Topology?
- How Do I Connect a Service Mesh to Jaeger or Zipkin for Viewing Traces?
- Videos
More Documents
- Getting Started
- User Guide
- Mesh Management
Adding a Service
Grayscale Release
Creating a Grayscale Release Task
- Log in to the ASM console and click
in the asmtest mesh.
- Set Task Name to test and select servicetest created in Creating a Workload and a Service for Service. (Workload is automatically set to deptest.) Configure other basic information and grayscale version information and click Release.
Figure 1 Creating a grayscale release task
If you cannot select servicetest, check whether the service is normal. If the service is abnormal, fix the issues and try again.
- Click Configure Traffic Policy, set the policy type to Based on traffic ratio, and set the traffic ratio of v2 to 80%.
Figure 2 Configuring a traffic policy
- Click Deliver Policy.
It takes several seconds for the traffic policy to take effect. You can view the running of the grayscale version on the View Status page.
Switching All Traffic to the Grayscale Version
Check whether the number of resources in v2 matches that in v1. After confirming that v2 is able to serve all the traffic of v1, switch all the traffic from v1 to v2.
- On the Grayscale Release page, click test and then click Monitor and Manage Traffic.
- Click Take Over All Traffic next to v2.
Figure 3 Taking over all traffic
- Click OK. A message is displayed in the upper right corner, indicating that the traffic is taken over successfully.
Bringing the Original Version Offline
After v2 takes over all the traffic from v1, bring v1 offline to release its resources.
- On the displayed page, when the traffic percentage of v2 is 100%, v2 has taken over all traffic of v1. Click Terminate Task.
- Click OK.
The v1 version is brought offline and the test grayscale task is deleted.
