- What's New
- Product Bulletin
- Billing
- Getting Started
User Guide
- Application Service Mesh
- Buying a Service Mesh
- Mesh Management
- Service Management
- Gateway Management
- Grayscale Release
- Mesh Configuration
- Traffic Management
- Security
Best Practices
- Upgrading Data Plane Sidecars Without Service Interruption
- Service Governance for Dubbo-based Applications
- Reserving Source IP Address for Gateway Access
- Creating a Service Mesh with IPv4/IPv6 Dual Stack Enabled
- How Do I Query Application Metrics in AOM?
- Reducing the Agency Permissions of ASM Users
- Istio-ingressgateway HA Configuration
- Service Mesh Cluster
Mesh Management
- Why Cannot I Create a Mesh for My Cluster?
- Why Are Exclusive Nodes Still Exist After Istio Is Uninstalled?
- How Do I Upgrade ICAgent?
- How Do I Enable Namespace Injection for a Cluster?
- How Do I Disable Sidecar Injection for Workloads?
- What Can I Do If A Pod Cannot Be Started Due to Unready Sidecar
- How Do I Handle a Canary Upgrade Failure?
Adding a Service
- What Do I Do If an Added Gateway Does Not Take Effect?
- Why Does It Take a Long Time to Start the Demo Application in Experiencing Service Mesh in One Click?
- Why Cannot I Access the page of the Demo Application After It Is Successfully Deployed?
- Why Cannot I Select the Corresponding Service When Adding a Route?
- How Do I Inject a Sidecar for the Pod Created Using a Job or CronJob?
- Performing Grayscale Release
Managing Traffic
- Why Are the Created Clusters, Namespaces, and Applications Not Displayed on the Traffic Management Page?
- How Do I Change the Resource Requests of the istio-proxy Container?
- Does ASM Support HTTP/1.0?
- How Can I Block Access from Some IP Address Ranges or Ports for a Service Mesh?
- How Do I Configure max_concurrent_streams for a Gateway?
- How Do I Fix Compatibility Issues Between Istio CNI and Init Containers?
Monitoring Traffic
- Why Cannot I View Traffic Monitoring Data Immediately After a Pod Is Started?
- Why Are the Latency Statistics on the Dashboard Page Inaccurate?
- Why Is the Traffic Ratio Inconsistent with That in the Traffic Monitoring Chart?
- Why Can't I Find Certain Error Requests in Tracing?
- Why Cannot I Find My Service in the Traffic Monitoring Topology?
- How Do I Connect a Service Mesh to Jaeger or Zipkin for Viewing Traces?
- Videos
More Documents
- Getting Started
- User Guide
- Mesh Management
Adding a Service
Preparations
Before enabling Istio for a cluster, perform the following operations.
Creating a VPC
Virtual Private Cloud (VPC) provides a logically isolated, configurable, and manageable virtual network environment, improving resource security and simplifying network deployment.
- Log in to the VPC console.
- Click Create VPC in the upper right corner.
- Set the parameters as prompted and click Create Now.
Creating a Key Pair
Create a key pair for identity authentication upon remote node login.
- Log in to the Elastic Cloud Server (ECS) console.
- In the navigation pane, choose Key Pair. On the Key Pair page, click Create Key Pair in the upper right corner.
- Enter a key pair name and click OK.
- Manually or automatically download the private key file. The file name is the specified key pair name with a suffix of .pem. Securely store the private key file. In the dialog box displayed, click OK.
For security purposes, a key pair can be downloaded only once. Keep it secure to ensure successful login.
Creating a Load Balancer
A load balancer will be used as the external access entry of a service mesh, which will route the traffic to backend services.
- Log in to the Elastic Load Balance (ELB) console.
- Click Create Elastic Load Balancer in the upper right corner.
- VPC and Subnet: Select the VPC and subnet created in Creating a VPC, configure other parameters as prompted, and click Apply Now.
Creating a Cluster
- Log in to the Cloud Container Engine (CCE) console.
- In the navigation pane, choose Resource Management > Clusters. Then, click Create CCE Cluster in the upper right corner.
- On the Configure page, configure the following parameters and retain the default values for other parameters.
- Cluster Name: Enter a cluster name, for example, cluster-test.
- VPC and Subnet: Select the VPC and subnet created in Creating a VPC.
- Click Next: Create Node, configure the following parameters, and retain the default values for other parameters.
- Specifications: 4 vCPUs and 8 GB memory.
- Login Mode: Select the key pair created in Creating a Key Pair for identity authentication upon remote node login.
- Click Next: Install Add-on and select the add-ons to be installed in the Install Add-on step.
System resource add-on must be installed. Advanced functional add-on is optional.
- Click Next: Confirm. Read the product constraints and select I am aware of the above limitations. Review the configured parameters and specifications.
- Submit the order.
It takes about 6 to 10 minutes to create a cluster. You can click Back to Cluster List to perform other operations on the cluster or click Go to Cluster Events to view the cluster details.
(Optional) Creating a Namespace
- Log in to the CCE console.
- In the navigation pane, choose Resource Management > Namespaces. Then, click Create Namespace in the upper right corner.
- Enter the namespace name and select the created cluster.
- Click OK.
Creating a Workload and a Service
- Choose Workloads from the navigation pane, click the Deployments tab, click Create Deployment in the upper right corner.
- Create a workload and a Service by referring to CCE User Guide.
