- What's New
- Product Bulletin
- Billing
- Getting Started
User Guide
- Application Service Mesh
- Buying a Service Mesh
- Mesh Management
- Service Management
- Gateway Management
- Grayscale Release
- Mesh Configuration
- Traffic Management
- Security
Best Practices
- Upgrading Data Plane Sidecars Without Service Interruption
- Service Governance for Dubbo-based Applications
- Reserving Source IP Address for Gateway Access
- Creating a Service Mesh with IPv4/IPv6 Dual Stack Enabled
- How Do I Query Application Metrics in AOM?
- Reducing the Agency Permissions of ASM Users
- Istio-ingressgateway HA Configuration
- Service Mesh Cluster
Mesh Management
- Why Cannot I Create a Mesh for My Cluster?
- Why Are Exclusive Nodes Still Exist After Istio Is Uninstalled?
- How Do I Upgrade ICAgent?
- How Do I Enable Namespace Injection for a Cluster?
- How Do I Disable Sidecar Injection for Workloads?
- What Can I Do If A Pod Cannot Be Started Due to Unready Sidecar
- How Do I Handle a Canary Upgrade Failure?
Adding a Service
- What Do I Do If an Added Gateway Does Not Take Effect?
- Why Does It Take a Long Time to Start the Demo Application in Experiencing Service Mesh in One Click?
- Why Cannot I Access the page of the Demo Application After It Is Successfully Deployed?
- Why Cannot I Select the Corresponding Service When Adding a Route?
- How Do I Inject a Sidecar for the Pod Created Using a Job or CronJob?
- Performing Grayscale Release
Managing Traffic
- Why Are the Created Clusters, Namespaces, and Applications Not Displayed on the Traffic Management Page?
- How Do I Change the Resource Requests of the istio-proxy Container?
- Does ASM Support HTTP/1.0?
- How Can I Block Access from Some IP Address Ranges or Ports for a Service Mesh?
- How Do I Configure max_concurrent_streams for a Gateway?
- How Do I Fix Compatibility Issues Between Istio CNI and Init Containers?
Monitoring Traffic
- Why Cannot I View Traffic Monitoring Data Immediately After a Pod Is Started?
- Why Are the Latency Statistics on the Dashboard Page Inaccurate?
- Why Is the Traffic Ratio Inconsistent with That in the Traffic Monitoring Chart?
- Why Can't I Find Certain Error Requests in Tracing?
- Why Cannot I Find My Service in the Traffic Monitoring Topology?
- How Do I Connect a Service Mesh to Jaeger or Zipkin for Viewing Traces?
- Videos
More Documents
- Getting Started
- User Guide
- Mesh Management
Adding a Service
Advantages
Ease of Use
The out-of-the-box usability allows you to use a service mesh without code rewrite or manual installation.
Built-in Canary Release and Blue-Green Deployment
- Deployment of the grayscale version and traffic switchover with a few clicks
- Configurable grayscale policy that can be set based on traffic ratio and request content (cookies, OSs, and browsers)
- One-stop health, performance, and traffic monitoring, achieving quantified, intelligent, and visualized grayscale release
Policy-based Intelligent Routing and Flexible Traffic Management
Load balancing, service routing, fault injection, and outlier detection policies can be intuitively configured. Microservice traffic management can be real-time, visualized, intelligent, and automated, requiring no modifications on your applications.
- Routing rules can be set based on weight and content to implement flexible grayscale release of applications.
- Load balancing achieves high availability for service processing.
- Outlier detection ensures stable and reliable links between services.
- Network persistent connection management saves resources and improves network throughput.
- Service security certification, authentication, and audit lay a solid foundation for service security assurance.
Enhanced Performance and Reliability
The performance and reliability of the control plane and data plane are enhanced based on the community version.
Multi-infrastructure
An O&M-free hosting control plane is provided. Unified service governance, grayscale release, security, and service running monitoring capabilities are supported. Unified service discovery and management of multiple infrastructure resources such as containers and VMs are provided.
Protocol Extension
The HTTP, gRPC, TCP, TLS, and Dubbo protocols are supported.
Traditional SDK Integration
Integration solutions for traditional microservice SDKs such as Spring Cloud and Dubbo are provided. Services developed using traditional microservice SDKs can be migrated to cloud-native containers and mesh running environments without major code modification.
