Overview
Non-intrusive traffic management is a core function of Istio. With traffic management, you only need to focus on your own service logic rather than service access management. Traffic management enables you to:
- Dynamically modify load balancing policies for cross-service access, such as configuring consistent hashing to forward traffic to specific service pods.
- Distribute a certain proportion of traffic to a specific version of a service when the service has two online versions.
- Protect services, for example, limiting the number of concurrent connections and requests, and isolating faulty service pods.
- Dynamically modify the content of a service or simulate a service running fault.
ASM provides retry, timeout, connection pool, outlier detection, load balancing, HTTP header, and fault injection functions to meet traffic management requirements in most service scenarios.
Mesh Function |
Management Role |
Service Initiator |
Service Provider |
Route management |
Y |
N |
Load balancing |
Y |
N |
Tracing analysis |
Y |
Y |
Service authentication |
Y |
Y |
Observability data |
Y |
Y |
Retry |
Y |
N |
Rewrite |
Y |
N |
Redirection |
Y |
N |
Authorization |
N |
Y |
Fault injection |
Y |
N |
Timeout |
Y |
N |
Connection pool |
Y |
N |
Outlier detection |
Y |
N |
HTTP header |
Y |
N |
Traffic management cannot be performed for the service whose configuration diagnosis fails. For details about rectifying faults, see Manual Fixing Items or Auto Fixing Items.
