Creating a Bandwidth Scaling Policy
You can automatically adjust the your purchased EIP bandwidth and shared bandwidth using a bandwidth scaling policy. This section describes how to create an bandwidth scaling policy.
When creating a bandwidth scaling policy, you need to configure basic information. The system supports three types of bandwidth scaling policies: alarm-based, scheduled, and periodic.
The basic information for creating a bandwidth scaling policy includes the policy name, resource type, policy type, and trigger condition.
Creating an Alarm-based Bandwidth Scaling Policy
  2. Under Computing, click Auto Scaling. In the navigation pane on the left, choose Bandwidth Scaling.
  3. Click Create Bandwidth Scaling Policy.
  4. Set parameters, such as the policy name, policy type, and trigger condition. For details, see Creating a Bandwidth Scaling Policy.
    Table 1 Alarm policy parameters
    Example Value
    Region
    Specifies the region where the AS group resides.
    N/A
    Policy Name
    Specifies the name of the bandwidth scaling policy.
    The name consists of only letters, digits, underscores (_), and hyphens (-).
    N/A
    EIP
    Specifies the public network IP address whose bandwidth needs to be scaled.
    Currently, only pay-per-use EIPs can be scaled. Yearly/monthly EIPs cannot be used to create AS groups.
    N/A
    Policy Type
    Select Alarm.
    Alarm
    Alarm Rule
    You can use an existing alarm rule or create a new one. Alternatively, click Create Alarm Rule on the right side of the Alarm parameter and create an alarm rule on the Alarm Rules page. For details, see Creating an Alarm Rule.
    To create an alarm rule, configure the following parameters:
    • Rule Name
      Specifies the name of the new alarm rule, for example, as-alarm-7o1u.
    • Trigger Condition
      Select a monitoring metric and trigger condition based on the metric. Table 2 lists the supported monitoring metrics. An example value is Outbound Traffic Avg. > 100 bit/s.
    • Monitoring Interval
      Specifies the period for the metric, for example, 5 minutes.
    • Consecutive Occurrences
      Specifies the number of consecutive times, for example, one time, for triggering a scaling action during a monitoring period.
    N/A
    Scaling Action
    Specifies the execution action in the AS policy.
    The following scaling action options are available:
    • Add
      When a scaling action is triggered, the bandwidth is increased.
    • Reduce
      When a scaling action is triggered, the bandwidth is decreased.
    • Set to
      The bandwidth is set to a fixed value.
      The step (minimum unit for bandwidth adjustment) varies depending on the bandwidth value range. The bandwidth will be automatically adjusted to the nearest value according to the actual step.
      • If the bandwidth is less than or equal to 300 Mbit/s, the default step is 1 Mbit/s.
      • If the bandwidth ranges from 300 Mbit/s to 1000 Mbit/s, the default step is 50 Mbit/s.
      • If the bandwidth is greater than 1000 Mbit/s, the default step is 500 Mbit/s.
    N/A
    Cooldown Period
    Specifies a period of time in the unit of second after each scaling action is complete. During the cooldown period, scaling actions triggered by alarms will be denied. Scheduled and periodic scaling actions are not restricted.
    300
    Table 2 Monitoring metrics supported by the alarm policy
    Metric
    Inbound Bandwidth
    Indicates the network rate of inbound traffic.
    Inbound Traffic
    Indicates the network traffic going into the cloud platform.
    Outbound Bandwidth
    Indicates the network rate of outbound traffic.
    Outbound Traffic
    Indicates the network traffic going out of the cloud platform.
  5. After setting the parameters, click Create Now.
    The newly created bandwidth scaling policy is displayed on the Bandwidth Scaling page and is in Enabled state by default.
When creating an alarm-based bandwidth scaling policy, you can click Create Alarm Rule on the right of Rule Name to create an alarm rule. To do so, perform the following operations:
  1. Click Create Alarm Rule on the right of Rule Name to switch to the Alarm Rules page of Cloud Eye.
  2. On the Alarm Rules page, click Create Alarm Rule in the upper right corner.
  3. Set parameters based on Figure 1 and Table 3. For more information about how to set alarm rules, see Cloud Eye User Guide.
    Figure 1 Creating an alarm rule
    Table 3 Key parameters for creating an alarm rule
    Example Value
    Name
    Specifies the name of the alarm rule.
    alarm-bandwidth
    Resource Type
    Specifies the name of the service to which the alarm rule applies. Set this parameter to Elastic IP and Bandwidth.
    Dimension
    Specifies the item of the monitored service. Bandwidth scaling adjusts the bandwidth. Therefore, set this parameter to Bandwidths.
    Bandwidths
    Monitoring Scope
    Specifies the resources to which the alarm rule applies. Set this parameter to Specific resources. Search for resources by bandwidth name or ID, which can be obtained on the page providing details about the target EIP.
    Specific resources
    Method
    Select the method of creating an alarm. Set this parameter to Create manually.
    Create manually
    Alarm Policy
    Specifies the alarm policy for triggering the alarm rule. Set this parameter as required. For details about the monitoring metrics, see Table 2.
    N/A
  4. After setting the parameters, click Create.
  5. On the Create Bandwidth Scaling Policy page, click on the right of Rule Name, and select the created alarm rule.
Alternatively, create your desired alarm rule on the Cloud Eye page before creating a bandwidth scaling policy. Ensure that the specific resources selected during alarm rule creation are the bandwidth of the EIP selected for the bandwidth scaling policy to be created. After the alarm rule is created, you can select the rule when creating a bandwidth scaling policy.
Creating a Scheduled or Periodic Bandwidth Scaling Policy
  4. Set parameters, such as the policy name, policy type, and trigger condition. For details, see Table 4.
    Table 4 Scheduled or periodic policy parameters
    Example Value
    Region
    N/A
    Policy Name
    as-policy-p6g5
    EIP
    Specifies the public network IP address whose bandwidth needs to be scaled. This parameter is mandatory when Resource Type is set to EIP.
    N/A
    Policy Type
    Specifies the policy type. You can select a scheduled or periodic policy.
    If you select Periodic, you are required to configure two more parameters:
    • Time Range
      Specifies a time range during which the AS policy can be triggered.
    • Interval
      • One day
      • One week
      • One month
    N/A
    Triggered At
    Specifies a time at which the AS policy is triggered.
    N/A
    Scaling Action
    Specifies the action to be performed.
    • Add
    • Reduce
    • Set to
    N/A
    Cooldown Period
    300
