Monitoring Metrics
This section describes the monitoring metrics reported by AS to Cloud Eye and defines the namespace for the metrics. You can use Cloud Eye to query monitoring metrics and alarms generated by AS.
Namespace
SYS.AS
Monitoring metrics
Table 1 lists the AS metrics supported by Cloud Eye.
Table 1 AS metrics
Metric ID
Metric
Value Range
Monitored Object & Dimension
Monitoring Interval (Raw Data)
cpu_util
CPU Usage
CPU usage of an AS group
Formula: Total CPU usage of all ECSs in an AS group/Number of ECSs in the AS group
Unit: Percent
≥0%
Object: AS group
Dimension:
AutoScalingGroup
5 minutes
mem_util
Memory Usage
Memory usage of an AS group
Formula: Total memory usage of all ECSs in an AS group/Number of ECSs in the AS group
Unit: Percent
This metric is unavailable if the image has no VM Tools installed.
≥0%
Object: AS group
Dimension:
AutoScalingGroup
5 minutes
network_outgoing_bytes_rate_inband
Inband Incoming Rate
Number of incoming bytes per second on an ECS in an AS group
Formula: Total inband incoming rates of all ECSs in an AS group/Number of ECSs in the AS group
Unit: Byte/s
≥0 Byte/s
Object: AS group
Dimension:
AutoScalingGroup
5 minutes
instance_num
Inband Outgoing Rate
Number of outgoing bytes per second on an ECS in an AS group
Formula: Total inband outgoing rates of all ECSs in an AS group/Number of ECSs in the AS group
Unit: Byte/s
≥0
Object: AS group
Dimension:
AutoScalingGroup
5 minutes
disk_read_bytes_rate
Disks Read Rate
Number of bytes read from an AS group per second
Formula: Total disks read rates of all ECSs in an AS group/Number of ECSs in the AS group
Unit: Byte/s
≥0 Byte/s
Object: AS group
Dimension:
AutoScalingGroup
5 minutes
disk_write_bytes_rate
Disks Write Rate
Number of bytes written to an AS group per second
Formula: Total disks write rates of all ECSs in an AS group/Number of ECSs in the AS group
Unit: Byte/s
≥0 Byte/s
Object: AS group
Dimension:
AutoScalingGroup
5 minutes
disk_read_requests_rate
Disks Read Requests
Number of read requests per second sent to an ECS disk in an AS group
Unit: Request/s
≥0 request/s
Object: AS group
Dimension:
AutoScalingGroup
5 minutes
disk_write_requests_rate
Disks Write Requests
Number of write requests per second sent to an ECS disk in an AS group
Unit: Request/s
≥0 request/s
Object: AS group
Dimension:
AutoScalingGroup
5 minutes
cpu_usage
(Agent) CPU Usage
Agent CPU usage of an AS group
Formula: Total Agent CPU usage of all ECSs in an AS group/Number of ECSs in the AS group
Unit: Percent
0-100%
Object: AS group
Dimension:
AutoScalingGroup
1 minute
mem_usedPercent
(Agent) Memory Usage
Agent memory usage of an AS group
Formula: Total Agent memory usage of all ECSs in an AS group/Number of ECSs in the AS group
Unit: Percent
0-100%
Object: AS group
Dimension:
AutoScalingGroup
1 minute
load_average1
(Agent) 1-Minute Load Average
Average CPU load of all ECSs in an AS group in the last 1 minute Unit: none
≥0
Object: AS group
Dimension:
AutoScalingGroup
1 minute
load_average5
(Agent) 5-Minute Load Average
Average CPU load of all ECSs in an AS group in the last 5 minutes Unit: none
≥0
Object: AS group
Dimension:
AutoScalingGroup
1 minute
load_average15
(Agent) 15-Minute Load Average
Average CPU load of all ECSs in an AS group in the last 15 minutes Unit: none
≥0
Object: AS group
Dimension:
AutoScalingGroup
1 minute
gpu_usage_gpu
(Agent) GPU Usage
Agent GPU usage of an AS group
Formula: Total Agent GPU usage of all ECSs in an AS group/Number of ECSs in the AS group
Unit: Percent
0-100%
Object: AS group
Dimension:
AutoScalingGroup
1 minute
gpu_usage_mem
(Agent) Video Memory Usage
Agent GPU memory usage of an AS group
Formula: Total Agent GPU memory usage of all ECSs in an AS group/Number of ECSs in the AS group
Unit: Percent
0-100%
Object: AS group
Dimension:
AutoScalingGroup
1 minute
Monitoring metrics are classified into metrics with Agent and without Agent. For some OSs, you need to install the Agent to obtain the corresponding monitoring metrics. In this case, select the monitoring metrics with Agent, for example, (Agent) Memory Usage.
Dimension
Key
Value
AutoScalingGroup
AS group ID
