- What's New
- Function Overview
- Getting Started
- User Guide
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
APIs
- AS Groups
- AS Configurations
- Instances
AS Policies
- Creating an AS Policy
- Creating an AS Policy (V2)
- Modifying an AS Policy
- Modifying an AS Policy (V2)
- Querying AS Policies Bound to an AS Group
- Querying AS Policies Bound to a Scaling Resource (V2)
- Querying AS Policies (V2)
- Querying an AS Policy
- Querying an AS Policy (V2)
- Executing, Enabling, or Disabling an AS Policy
- Deleting an AS Policy
- Batch Managing AS Policies
- AS Policy Execution Logs
- Scaling Action Logs
- Quotas
- Notifications
- Lifecycle Hooks
- Tags
- Planned Tasks
- API Version Query
- Application Examples
- Appendix
- Change History
- SDK Reference
FAQ
General
- What Are Restrictions on Using AS?
- Must I Use AS Together With ELB and Cloud Eye?
- Is AS Billed?
- Will an Abrupt Change in Monitoring Metric Values Trigger an Unnecessary Scaling Action?
- How Many AS Policies and AS Configurations Can I Create and Use?
- Can AS Automatically Scale Up or Down vCPUs, Memory, and Bandwidth of ECSs?
- What Is an AS Quota?
- How Do I Fix the Error "The key pair does not exist" When I Connect to an Instance?
- What Types of EIP and Shared Bandwidths Can Be Adjusted by AS?
- What Types of ECS and HECS Instances Can Be Scaled by AS?
- If the OS of an ECS Instance in an AS Group Is Upgraded, Can AS Automatically Add Instances with the Newest OS During the Next Scale-out Action?
- Can AS Add Yearly/Monthly ECS Instances When It Scales Out an AS Group?
- Can AS Increase Bandwidths as Required?
- AS Group
AS Policy
- How Many AS Policies Can I Enable?
- What Are the Conditions to Trigger an Alarm-based AS Policy?
- What Is a Cooldown Period and Why Is It Required?
- Can AS Scale Capacity Based on Custom Monitoring by Cloud Eye?
- What Monitoring Metrics for an AS Group Will Be Affected If VM Tools Are Not Installed on the Instances in the Group?
- What Can I Do If an AS Policy Fails to Be Enabled?
- How Do I Install the Agent on Instances in an AS Group to Use Agent Monitoring Metrics?
Instance
- How Do I Prevent Instances Manually Added to an AS Group from Being Automatically Removed?
- When There Are Multiple Flavors Included in the AS Configuration of an AS Group, What Order Are the Flavors Selected in During Scale-out Events?
- When an Instance Is Removed from an AS Group and Deleted, Is the Application Data Saved?
- Can I Add Yearly/Monthly ECS Instances to an AS Group?
- Can the System Automatically Delete the Instances Added Based on an AS Policy When They Are Not Required?
- What Is the Expected Number of Instances?
- How Do I Delete an ECS Instance Created in a Scaling Action?
- Will a Yearly/Monthly ECS Instance Be Deleted If It Becomes Unhealthy?
- How Do I Handle Unhealthy Instances in an AS Group?
- Why Instances in an AS Group Keep Failing Health Checks and Getting Deleted and Recreated?
- How Do I Prevent Instances from Being Automatically Removed from an AS Group?
- Why Is an Instance that Was Removed from an AS Group and Deleted Still Displayed in the ECS List?
- Do I Need to Bind an EIP to an Instance Before I Manually Add the Instance to an AS Group?
- Can I Apply the Configurations of an Existing Instance in an AS Group to Instances to Be Added in the Future?
- Will the System Bind a New EIP or an Existing One a Newly Added ECS Instance?
- How Can I Automatically Deploy My Application on an Instance?
- How Does Cloud-Init Affect the AS Service?
- Why Can't I Use a Key File to Log In to an ECS?
- Do I Need to Configure an EIP in an AS Configuration When a Load Balancer Has Been Enabled for an AS Group?
- How Do I Enable Automatic Initialization of EVS Disks on Instances that Have Been Added to an AS Group During Scaling Actions?
General
- Videos
- Glossary
More Documents
- Best Practices
- Quick Start
- AS Management
General
- Are ELB and Cloud Eye Mandatory for AS?
- Is AS Billed?
- Does an Abrupt Change on Monitoring Indicator Values Cause an Incorrect Scaling Action?
- What Is the AS Quota?
- Why is a message displayed indicating that the key pair does not exist and the operation is discontinued when several users under the same account operate AS resources?
- AS Group
AS Policy
- How Many AS Policies Can Be Enabled?
- What Are the Conditions to Trigger an Alarm in the AS Policy?
- What Is a Cooldown Period? Why Is It Required?
- Can AS Scale Capacity Based on Custom Monitoring of Cloud Eye?
- What Will Monitoring Metrics for an AS Group Be Affected If VM Tools Are Not Installed on ECSs?
- How Can I Install the Agent Plug-in on the Instances in an AS Group to Use Agent Monitoring Metrics?
Instance
- How Do I Prevent Instances Manually Added to an AS Group from Being Removed Automatically?
- What Are the Sequence of Selecting Flavors in Multi-Flavor AS Configuration?
- Will the Application Data on an Instance Be Retained After the Instance Is Removed from an AS Group and Deleted?
- Can I Add ECSs Charged in Yearly/Monthly Mode?
- Can Instances That Have Been Added Based on an AS Policy Be Automatically Deleted When They Are Not Required?
- How Do I Delete an ECS Created in a Scaling Action?
- Will a Yearly/Monthly ECS Be Deleted When the ECS Becomes Faulty?
- How Should I Handle Abnormal Instances in an AS Group?
- What Can I Do If Instances in an AS Group Frequently Fail in Health Checks and Are Deleted and Then Created Repeatedly?
- How Do I Prevent ECSs from Being Removed from an AS Group Automatically?
- Why Is an Instance Removed and Deleted from an AS Group Still Displayed in the ECS List?
- What Can I Do to Enable My Application to Be Automatically Deployed on an Instance?
- How Can I Run Existing Services on an Instance Newly Added to an AS Group?
- Why Cannot I Use a Key File to Log In to an ECS?
- Do I Need to Configure an EIP in an AS Configuration When A Load Balancer Has Been Enabled in an AS Group?
- How Can I Enable Automatic Initialization of EVS Disks of Instances That Have Been Added in a Scaling Action to an AS Group?
General
- Change History
- Before You Start
- API Overview
- Calling APIs
- Getting Started
API
- AS Groups
- AS Configurations
- Instances in an AS Group
AS Policies
- Querying All AS Policies (V2)
- Querying AS Policy Details
- Querying Details of an AS Policy (V2)
- Performing Operations on AS Policies in Batches
- Quotas
- Notifications
- Lifecycle Hook
- Tag Management
- API Management
- Appendix
- Change History
User Guide (Paris Regions)
- Best Practices
- Quick Start
- AS Management
General
- AS Group
AS Policy
Instance
- Can AS Automatically Delete Instances Added Based on an AS Policy When They Are Not Required?
General
- Change History
- API Reference (Paris Regions)
- Best Practices
- Quick Start
- AS Management
General
- Is AS Billed?
- AS Group
AS Policy
Instance
General
- Change History
- Before You Start
- API Overview
- Calling APIs
- Getting Started
APIs
- AS Groups
- AS Configurations
AS Policies
- Quotas
- Notifications
- Lifecycle Hook
- Tag Management
- API Management
- Appendix
- Change History
User Guide (Ankara Region)
- Best Practices
- Quick Start
- AS Management
General
- AS Group
AS Policy
Instance
General
- Change History
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
APIs
- AS Groups
- AS Configurations
- Instances
AS Policies
- Quotas
- Notifications
- Lifecycle Hooks
- API Version Query
- Appendix
- Change History
Adding Tags to AS Groups and Instances
If you have many resources of the same type, you can use a tag to manage resources flexibly. You can identify specified resources quickly using the tags allocated to them.
Using a tag, you can assign custom data to each AS group. You can organize and manage AS groups, for example, classify AS group resources by usage, owner, or environment.
Each tag contains a key and a value. You can specify the key and value for each tag. A key can be a category associated with certain values, such as usage, owner, and environment.
For example, if you want to distinguish the test environment and production environment, you can allocate a tag with the key environment to each AS group. For the test environment, the key value is test and for the production environment, the key value is production. You are advised to use one or more groups of consistent tags to manage your AS group resources.
After you allocate a tag to an AS group, the system will automatically add the tag to the instances automatically created in the AS group. If you add a tag to an AS group or modify the tag, the new tag will be added to the ECSs automatically created in the AS group. Creating, deleting, or modifying the tag of an AS group will have no impact on the ECSs in the AS group.
Restrictions of Using Tags
- Each AS group can have a maximum of 10 tags added to it.
- Each tag contains a key and a value.
- You can set the tag value to an empty character string.
- If you delete an AS group, all tags of it will also be deleted.
Adding a Tag to an AS Group
- Under Computing, click Auto Scaling. In the navigation pane on the left, choose Instance Scaling.
- Click the AS group name. On the AS group details page, click the Tags tab and then click Add Tag.
- Set the parameters listed in Table 1.
Table 1 Tag naming rules Parameter
Requirement
Example Value
Tag Key
- The value cannot be empty.
- An AS group has a unique key.
- A key can contain a maximum of 36 characters, including digits, letters, underscores (_), hyphens (-), and Unicode characters from \u4e00 to \u9fff.
Organization
Tag Value
- The value can be an empty character string.
- A key can have only one value.
- A tag value can contain a maximum of 43 characters, including digits, letters, underscores (_), periods (.), hyphens (-), and Unicode characters from \u4e00 to \u9fff.
Apache
- Click OK.
Modifying or Deleting Tags of an AS Group
- Under Computing, click Auto Scaling. In the navigation pane on the left, choose Instance Scaling. Then click the AS Groups tab.
- Click the AS group name. On the Basic Information page, click the Tags tab.
- Locate the row that contains the tag and click Edit or Delete in the Operation column.
After clicking Edit, configure required parameters. For details, see Table 1.
After you click Delete, the added tag will be deleted.
