- What's New
- Function Overview
- Getting Started
- User Guide
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
APIs
- AS Groups
- AS Configurations
- Instances
AS Policies
- Creating an AS Policy
- Creating an AS Policy (V2)
- Modifying an AS Policy
- Modifying an AS Policy (V2)
- Querying AS Policies Bound to an AS Group
- Querying AS Policies Bound to a Scaling Resource (V2)
- Querying AS Policies (V2)
- Querying an AS Policy
- Querying an AS Policy (V2)
- Executing, Enabling, or Disabling an AS Policy
- Deleting an AS Policy
- Batch Managing AS Policies
- AS Policy Execution Logs
- Scaling Action Logs
- Quotas
- Notifications
- Lifecycle Hooks
- Tags
- Planned Tasks
- API Version Query
- Application Examples
- Appendix
- Change History
- SDK Reference
FAQ
General
- What Are Restrictions on Using AS?
- Must I Use AS Together With ELB and Cloud Eye?
- Is AS Billed?
- Will an Abrupt Change in Monitoring Metric Values Trigger an Unnecessary Scaling Action?
- How Many AS Policies and AS Configurations Can I Create and Use?
- Can AS Automatically Scale Up or Down vCPUs, Memory, and Bandwidth of ECSs?
- What Is an AS Quota?
- How Do I Fix the Error "The key pair does not exist" When I Connect to an Instance?
- What Types of EIP and Shared Bandwidths Can Be Adjusted by AS?
- What Types of ECS and HECS Instances Can Be Scaled by AS?
- If the OS of an ECS Instance in an AS Group Is Upgraded, Can AS Automatically Add Instances with the Newest OS During the Next Scale-out Action?
- Can AS Add Yearly/Monthly ECS Instances When It Scales Out an AS Group?
- Can AS Increase Bandwidths as Required?
- AS Group
AS Policy
- How Many AS Policies Can I Enable?
- What Are the Conditions to Trigger an Alarm-based AS Policy?
- What Is a Cooldown Period and Why Is It Required?
- Can AS Scale Capacity Based on Custom Monitoring by Cloud Eye?
- What Monitoring Metrics for an AS Group Will Be Affected If VM Tools Are Not Installed on the Instances in the Group?
- What Can I Do If an AS Policy Fails to Be Enabled?
- How Do I Install the Agent on Instances in an AS Group to Use Agent Monitoring Metrics?
Instance
- How Do I Prevent Instances Manually Added to an AS Group from Being Automatically Removed?
- When There Are Multiple Flavors Included in the AS Configuration of an AS Group, What Order Are the Flavors Selected in During Scale-out Events?
- When an Instance Is Removed from an AS Group and Deleted, Is the Application Data Saved?
- Can I Add Yearly/Monthly ECS Instances to an AS Group?
- Can the System Automatically Delete the Instances Added Based on an AS Policy When They Are Not Required?
- What Is the Expected Number of Instances?
- How Do I Delete an ECS Instance Created in a Scaling Action?
- Will a Yearly/Monthly ECS Instance Be Deleted If It Becomes Unhealthy?
- How Do I Handle Unhealthy Instances in an AS Group?
- Why Instances in an AS Group Keep Failing Health Checks and Getting Deleted and Recreated?
- How Do I Prevent Instances from Being Automatically Removed from an AS Group?
- Why Is an Instance that Was Removed from an AS Group and Deleted Still Displayed in the ECS List?
- Do I Need to Bind an EIP to an Instance Before I Manually Add the Instance to an AS Group?
- Can I Apply the Configurations of an Existing Instance in an AS Group to Instances to Be Added in the Future?
- Will the System Bind a New EIP or an Existing One a Newly Added ECS Instance?
- How Can I Automatically Deploy My Application on an Instance?
- How Does Cloud-Init Affect the AS Service?
- Why Can't I Use a Key File to Log In to an ECS?
- Do I Need to Configure an EIP in an AS Configuration When a Load Balancer Has Been Enabled for an AS Group?
- How Do I Enable Automatic Initialization of EVS Disks on Instances that Have Been Added to an AS Group During Scaling Actions?
General
- Videos
- Glossary
More Documents
- Best Practices
- Quick Start
- AS Management
General
- Are ELB and Cloud Eye Mandatory for AS?
- Is AS Billed?
- Does an Abrupt Change on Monitoring Indicator Values Cause an Incorrect Scaling Action?
- What Is the AS Quota?
- Why is a message displayed indicating that the key pair does not exist and the operation is discontinued when several users under the same account operate AS resources?
- AS Group
AS Policy
- How Many AS Policies Can Be Enabled?
- What Are the Conditions to Trigger an Alarm in the AS Policy?
- What Is a Cooldown Period? Why Is It Required?
- Can AS Scale Capacity Based on Custom Monitoring of Cloud Eye?
- What Will Monitoring Metrics for an AS Group Be Affected If VM Tools Are Not Installed on ECSs?
- How Can I Install the Agent Plug-in on the Instances in an AS Group to Use Agent Monitoring Metrics?
Instance
- How Do I Prevent Instances Manually Added to an AS Group from Being Removed Automatically?
- What Are the Sequence of Selecting Flavors in Multi-Flavor AS Configuration?
- Will the Application Data on an Instance Be Retained After the Instance Is Removed from an AS Group and Deleted?
- Can I Add ECSs Charged in Yearly/Monthly Mode?
- Can Instances That Have Been Added Based on an AS Policy Be Automatically Deleted When They Are Not Required?
- How Do I Delete an ECS Created in a Scaling Action?
- Will a Yearly/Monthly ECS Be Deleted When the ECS Becomes Faulty?
- How Should I Handle Abnormal Instances in an AS Group?
- What Can I Do If Instances in an AS Group Frequently Fail in Health Checks and Are Deleted and Then Created Repeatedly?
- How Do I Prevent ECSs from Being Removed from an AS Group Automatically?
- Why Is an Instance Removed and Deleted from an AS Group Still Displayed in the ECS List?
- What Can I Do to Enable My Application to Be Automatically Deployed on an Instance?
- How Can I Run Existing Services on an Instance Newly Added to an AS Group?
- Why Cannot I Use a Key File to Log In to an ECS?
- Do I Need to Configure an EIP in an AS Configuration When A Load Balancer Has Been Enabled in an AS Group?
- How Can I Enable Automatic Initialization of EVS Disks of Instances That Have Been Added in a Scaling Action to an AS Group?
General
- Change History
- Before You Start
- API Overview
- Calling APIs
- Getting Started
API
- AS Groups
- AS Configurations
- Instances in an AS Group
AS Policies
- Querying All AS Policies (V2)
- Querying AS Policy Details
- Querying Details of an AS Policy (V2)
- Performing Operations on AS Policies in Batches
- Quotas
- Notifications
- Lifecycle Hook
- Tag Management
- API Management
- Appendix
- Change History
User Guide (Paris Regions)
- Best Practices
- Quick Start
- AS Management
General
- AS Group
AS Policy
Instance
- Can AS Automatically Delete Instances Added Based on an AS Policy When They Are Not Required?
General
- Change History
- API Reference (Paris Regions)
- Best Practices
- Quick Start
- AS Management
General
- Is AS Billed?
- AS Group
AS Policy
Instance
General
- Change History
- Before You Start
- API Overview
- Calling APIs
- Getting Started
APIs
- AS Groups
- AS Configurations
AS Policies
- Quotas
- Notifications
- Lifecycle Hook
- Tag Management
- API Management
- Appendix
- Change History
User Guide (Ankara Region)
- Best Practices
- Quick Start
- AS Management
General
- AS Group
AS Policy
Instance
General
- Change History
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
APIs
- AS Groups
- AS Configurations
- Instances
AS Policies
- Quotas
- Notifications
- Lifecycle Hooks
- API Version Query
- Appendix
- Change History
Using an Existing ECS to Create an AS Configuration
You can use an existing ECS to rapidly create an AS configuration. In such a case, the parameter settings, such as the vCPUs, memory, image, disk, and ECS type in the AS configuration are the same as those of the selected ECS by default.
- Under Computing, click Auto Scaling. In the navigation pane on the left, choose Instance Scaling.
- Click Create AS Configuration.
- Set the parameters for the AS configuration. Table 1 lists the AS configuration parameters.
Table 1 AS configuration parameters Parameter
Example Value
Region
A region is where an AS configuration resides.
N/A
Name
Specifies the name of an AS configuration.
N/A
Configuration Template
Select Use specifications of an existing ECS and click Select ECS.
The ECS type, vCPUs, memory, image, and disk information in the AS configuration are the same as those of the selected ECS by default.
EIP
An EIP is a static public IP address bound to an ECS in a VPC. Using the EIP, the ECS provides services externally.
The following options are provided:- Do not use
An ECS without an EIP cannot access the Internet. However, it can still be used as a service ECS or deployed in a cluster on a private network.
- Automatically assign
An EIP with a dedicated bandwidth is automatically assigned to each ECS. The bandwidth size is configurable.
If you select Automatically assign, you need to specify Type, Bandwidth Type, Billed By, and Bandwidth.
Bandwidth Type
You can select Dedicated or Shared.
- Dedicated: The bandwidth can be used by only one EIP.
- Shared: The bandwidth can be used by multiple EIPs.
- This parameter is available only when EIP is set to Automatically assign.
- If you select Dedicated, you can select Bandwidth or Traffic for Billed By.
- The shared bandwidth can be billed only by bandwidth. You can select a shared bandwidth to which the EIP is to be added.
Shared
Login Mode
An ECS can be authorized using a key pair or a password.- Key pair
In this mode, keys are used for authenticating the users who attempt to log in to target ECSs. If you select this mode, create or import a key pair on the Key Pair page.
If you use an existing key, make sure that you have saved the key file locally. Otherwise, logging in to the ECS will fail.
- Password
In this mode, the initial password of user root (for Linux) or user Administrator (for Windows) is used for authentication. You can log in to an ECS using the username and its initial password.
Admin@123
Advanced Settings
This allows you to configure User Data Injection.
You can select Do not configure or Configure now.
N/A
User Data Injection
Enables the ECS to automatically inject user data when the ECS starts for the first time. This configuration is optional. After this function is enabled, the ECS automatically injects user data upon its first startup.
For details, see Elastic Cloud Server User Guide.
The following methods are available:
- As text: allows you to enter the user data in the text box below.
- As file: allows you to inject script files or other files when you create an ECS. If you select As file, the system automatically injects the files into a specified directory when creating an ECS.
- For Linux, specify the path for storing the injected file, for example /etc/foo.txt.
- For Windows, the injected file is automatically stored in the root directory of disk C. You only need to specify the file name, such as foo. The file name can contain only letters and digits.
- For Linux, if you use the password authentication mode, the user data injection function is unavailable.
- If the selected image does not support user data injection, the user data injection function is unavailable.
- Do not use
- After setting the parameters, click Create Now.
- If you want to use the newly created AS configuration, add it to the AS group. For details, see Replacing AS Configuration in an AS Group.
- (Optional) Enable the AS group.
If the AS group is in Disabled state, enable it. For details, see Enabling an AS Group.
