- What's New
Service Overview(2.0)
- What Is APM
- Functions
- Application Scenarios
- Basic Concepts
- Edition Differences
- Permissions Management
Metric Overview
- Exception
- Basic Monitoring
- C3P0 Connection Pool Monitoring
- Cassandra Monitoring
- ClickHouse Database
- DBCP Connection Pool Monitoring
- Druid Connection Pool Monitoring
- EsRestClient Monitoring
- GaussDB Database
- HBase Monitoring
- Hikari Connection Pool Monitoring
- Jetcd Monitoring
- MongoDB Monitoring
- MySQL Database
- ObsClient Monitoring
- Oracle Database
- PostgreSQL Database
- URLs
- External Calls
- Cache
- Agent Monitoring
- Tomcat Monitoring
- Message Queues
- RPC
- IoT
- Communication Protocol
- Privacy and Sensitive Information Protection Statement
- Data Collection
- Usage Restrictions
- Billing
- JavaAgent Updates
- Billing(2.0)
- Getting Started(2.0)
User Guide(2.0)
- Before You Start
- Application List
- CMDB Management
Application Metric Monitoring
- Overview
- Application Monitoring Details
Application Monitoring Configuration
- Configuration Details
- Configuring the MySQL Monitoring Item
- Configuring the HttpClient Monitoring Item
- Configuring the URL Monitoring Item
- Configuring the JavaMethod Monitoring Item
- Configuring the Druid Monitoring Item
- Configuring the ApacheHttpAsyncClient Monitoring Item
- Configuring the Redis Monitoring Item
- Configuring the Jedis Monitoring Item
- Configuring the HBase Monitoring Item
- Configuring the ApacheHttpClient Monitoring Item
- Configuring the Tomcat Monitoring Item
- Configuring the EsRestClient Monitoring Item
- Configuring the WebSocket Monitoring Item
- Configuring the KafkaProducer Monitoring Item
- Configuring the Hikari Monitoring Item
- Configuring the Exception Monitoring Item
- Configuring the Thread Monitoring Item
- Configuring the GC Monitoring Item
- Configuring the JVMInfo Monitoring Item
- Configuring the JVMMonitor Monitoring Item
- Configuring ProbeInfo Monitoring Item
- Monitoring Item Views
- Instance
- Collection Status
- Component Settings
- Tracing
- Application Topology
- URL Tracing
- Resource Tag Management
- Managing Tags
- Alarm Management
- AgentAgent Management
- Configuration Management
- System Management
- Change History
API Reference(2.0)
- Before You Start
- API Overview
- Calling APIs
- Examples
APIs
APM
- Querying the application list.
- Querying the Master Address
- Obtaining the AK/SK
- Searching for Components, Environments, and Agents in a Region
- Saving a Monitoring Item
- Querying the Monitoring Item List
- Querying All Agents of an Application
- Enabling or Disabling Collection for an Instance
- Deleting an Agent
- REGION
- CMDB
VIEW
- Querying Monitoring Item Configurations
- Querying the Trace Topology
- Querying Event Details
- Querying Span Data
- Obtaining All Data of a Trace
- Obtaining the Trend Graph
- Obtaining Summary Table Data
- Obtaining the Raw Data Table
- Obtaining Raw Data Details
- Obtaining the Instance Information
- Obtaining the Monitoring Item Information
- Obtaining the Details About a Monitoring Item
- AKSK
- ALARM
- TOPOLOGY
- TRANSACTION
- TRACING
APM
- Appendix
- Change History
- Best Practices(2.0)
- FAQs(2.0)
- Service Overview(1.0)
- Getting Started(1.0)
- Best Practices(1.0)
- User Guide
- API Reference
- SDK Reference
- General FAQs
- Consultation FAQs
Usage FAQs
- How Do I Obtain the AK/SK and Project ID?
- How Do I Obtain the AK/SK by Creating an Agency?
- What Can I Do If No Data Is Found or the Data Is Abnormal?
- How Do I Connect APM to Non-Web Programs?
- How Are Tracing Time Lines Drawn?
- How Does APM Collect Probe Data?
- How Does APM Collect Mesh Data?
- How Do I Calculate the Number of Used Instances?
- How Do I Connect the JBoss Server in Standalone Mode to APM?
- What Can I Do If I Cannot Search for Logs Based on Trace IDs?
- How Do I Deploy APM Probes in CCE Containers?
- What Can I Do If the SSH Tunnel Process Is Abnormal?
- How Can I Do If No Topology or Data Is Displayed After the ICAgent and Java Probes Are Installed?
- Why Are Tomcat Thread Metrics Not Displayed on the JVM Monitoring Page?
- Why Is the Allocated Memory Greater Than the Preset Maximum Memory on the JVM Monitoring Page?
- How Do I Determine Whether an ICAgent Has Been Bound in CCE?
More Documents
- User Guide (ME-Abu Dhabi Region)
- API Reference (ME-Abu Dhabi Region)
User Guide (2.0) (Kuala Lumpur Region)
Service Overview
- What Is APM
- Functions
- Basic Concepts
Metric Overview
- Metric Overview
- Exception
- Basic Monitoring
- GaussDB Database
- HBase Monitoring
- Jetcd Monitoring
- MySQL Database
- Oracle Database
- URLs
- External Calls
- Cache
- Agent Monitoring
- Tomcat Monitoring
- Message Queues
- RPC
- IoT
- Data Collection
- Getting Started
User Guide
- Before You Start
- Application List
- CMDB Management
- Overview
- Tracing
- URL Tracing
- Managing Tags
- Alarm Management
- Agent Management
- System Management
- FAQs
- Change History
Service Overview
Show all
Viewing Events
Events carry important information, informing you of the changes of Application Performance Management (APM) itself. Such changes do not necessarily cause exceptions. Events do not need to be handled.
Viewing Events
- Log in to the APM console.
- In the navigation pane, choose Alarm Center > Event List.
- View events on the Event List page.
- Set a time range to view events. There are two methods to set a time range:
Method 1: Use the predefined time label, for example, Last 1 hour, Last 6 hours, or Last 1 day. You can choose one based on service requirements.
Method 2: Customize a time range. You can specify 30 days at most.
- Set filter criteria and click Search to view the events in the time range.
You can click Reset to reset filter criteria.
- Perform the operations listed in Table 1 if needed.
